    PanelDue7i
    PanelDue
    13
    17
    2.6k
    • T3P3Tonyundefined
      T3P3Tony administrators
      Well it has been a long time coming but we have finally received the production versions of our PanelDue7i
      This is an integrated PanelDue and 7 Inch LCD panel, commissioned after struggling to find a high enough quality LCD panel with low failure rates at a reasonable price. The best solution turned out to specify and buy a custom order. so we did!
      Available on our web shop (https://www.duet3d.com/IntegratedPanelDue) and Filastruder now (https://www.filastruder.com/collections/electronics/products/paneldue-7i).
      www.duet3d.com
      • DocTruckerundefined
        DocTrucker
        Great! Do you accept purchase order numbers from companies or is it a case by case basis?
        Edit: I've dropped you an email on your gmail contact us address.
        • mcoleundefined
          mcole
          Looks very nice. Well done.
          SolidWorks user, crazy inventer and they pay me too!
          • JuJuDeltaundefined
            JuJuDelta
            This looks great, ordered one for my Kossel XL+
            Please let me know when/if you have a 3D printed case STL for it.
            T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
            • pogo1213undefined
              pogo1213
              Will there be a other sizes offered in this configuration?
                @pogo1213:
                Not in the near future. If our experience with the 7" version is good, we may eventually commission a 5" version.
                • Qdeathstarundefined
                  Qdeathstar
                  For us, is it better to buy from you or filastruder?
                  • T3P3Tonyundefined
                    @Qdeathstar:
                    If you are US based then Filastruder, If UK then Duet3d.com otherwise check the shipping and exchange rates.
                    www.duet3d.com
                    • Danalundefined
                      Danal
                      Where would I find a mechanical drawing, and/or a .brd file, for the new PanelDue 7i?
                      I have one, wanting to print a case/mount for it. I can measure it… but I'd rather work from a drawing.
                      • Quadcellsundefined
                        Quadcells
                        Where can I find the physical dimensions and or drawings. I would like to design a case for it unless you have one already designed.
                        /quadcells
                        /quadcells
                        • elmoretundefined
                          elmoret
                          Drawings added to the Filastruder site:
                          https://www.filastruder.com/products/paneldue-7i
                            Quadcells
                            @elmoret:
                            Thank you!
                            /quadcells
                            • pabomanundefined
                              paboman
                              I need dimensions to get the 7" LCD into solidworks, maybe someone already did the 3D…?
                              • Drammyundefined
                                Drammy
                                Has anyone built a case for this yet?
                                If so, care to share? I'm a complete novice at 3d object design; wouldn't know where to start..
                                • Drammyundefined
                                  Drammy
                                  Scratch that last request - just found this…
                                  https://www.thingiverse.com/thing:2818424
                                  • LumberjackEngineeringundefined
                                    There's a few PanelDue 7i cases out there. I myself am partial to this one (https://www.thingiverse.com/thing:2799628), but that's because I designed it heehee. It's not as thin as it could be though, so if that's what you're looking for the one you linked is probably a better fit for you.
                                    • Drammyundefined
                                      Drammy
                                      @LumberjackEngineering:
                                      Wish I'd seen this one first - looks great and I like the fact you have the mounting bracket included and button for the reset button. Hmmm, decision to make… throw away the already printed one and print this or stick with what I have...
