    Firmware 2.0RC2b/1.21.1 RC2b released
    Firmware installation
    19
    52
    7.3k
    • Dr_Ju_Juundefined
      Dr_Ju_Ju
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1100 I50 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S90 ; Set idle timeout
      Julian,
      Old goat, learning new things….
        At 1A the stepper drivers won't get hot enough to trigger the thermal warning. See my earlier reply.
        • Dr_Ju_Juundefined
          Dr_Ju_Ju
          I unstand what you are saying, so unless I drive the motors above their normal operating currents, then the fan will never come on.
          But according to the datasheet (https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2660_datasheet.pdf) section 11.3, a flag is set when the chip reaches 100 degrees (OTPW), is this not trapped, so that external cooling can be applied ??
          Granted this is not optimal, but as there is no local temperature probe, its all that's available to monitor the temperature of the Duet board, and effect some forced cooling.
          Julian,
          whosrdaddyundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • whosrdaddyundefined
            whosrdaddy @Dr_Ju_Ju
            @dr_ju_ju : the board does a such a good job dissipating the heat of the drivers that 1A is not enough to overheat the drivers, hence it won't trip the flag...
            • ShadowXundefined
              ShadowX
              Just lower the temperature threshold or have the fan be connected to an "always on" connection. Case closed. Next subject.
              • r123undefined
                r123 @r123
                @r123 said in Firmware 2.0RC2b/1.21.1 RC2b released:
                Is there a post somewhere explaining the virtues of an RTOS-based firmware? For developer and end-user alike?
                @r123 nobody knows?
                  dc42 administrators @Dr_Ju_Ju
                  @dr_ju_ju said in Firmware 2.0RC2b/1.21.1 RC2b released:
                  Yes that's the over temperature warning flag that we monitor as I described in my earlier reply. You need more than 2A motor current to set it off.
                  • timcurtis67undefined
                    timcurtis67
                    So far Idex is working well. Here is a short video and picture using ditto printing of 2 sets of parts.
                    https://photos.app.goo.gl/LogVpsspHeL29Qih2
                    • mperdueundefined
                      mperdue
                      When i level my bed before a print i’m Getting the following message, “Number of calibration factors (0) not equal to number of lead screws (4)”
                      These are the probes that I’m doing. this worked on 1.19 so I’m not sure what’s up with this.
                      G30 P0 X30 Y280 Z-999 ; probe near back left lead screw
                      G30 P1 X390 Y280 Z-999
                      G30 P2 X390 Y25 Z-999
                      G30 P3 X30 Y25 Z-999 S4 ; probe near a leadscrew and calibrate 4 motors
                      • mperdueundefined
                        mperdue
                        Anyone have any ideas on the leveling issue?
                          The Z value in your G30 commands should be -9999 or -99999, not -999.
                            Firmware 2.0RC5 is out, so I have started a new thread for it and I am closing this thread.
