    Problem by connecting to duetwifi from browser
    • DR8
      DR8 last edited by
      So the problem that i have is that I can't connect with the IP adress to the duet board. I followed all the steps presented here: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7?lang=en. Panel Due shows ,,Connected" Wifi module is connected to the access point........ IP adress:......... And when I type in the browser the specific IP adress i get no page found
      3DPMicro 1 Reply Last reply Reply Quote 0
        Which firmware version are you using, and which browser?
        On some tablets and smartphones you need to type http:// in front of the IP address in the address bar, because otherwise the browser defaults to https.
        • 3DPMicro
          3DPMicro @DR8 last edited by
          @dr8
          I had the same issue with my Duet Ethernet. Possibly some useful information here. https://forum.duet3d.com/topic/4226/dwc-won-t-open-what-am-i-missing-solved.
          • DR8
            DR8 last edited by DR8
            Unfortunately, i was not so careful and I did not had the WWW folder on the SD card. That's why it did not work.
            T3P3Tony 1 Reply Last reply Reply Quote 2
            • T3P3Tony
              T3P3Tony administrators @DR8 last edited by
              @dr8 Thanks for your report. Its good to know the reason and no doubt this will help others!
              Duet Hardware Designer
              www.duet3d.com
