    Firmware 2.02 Release candidate 3 now available
    Firmware installation
    31
    104
    15.7k
    • garyd9undefined
      garyd9 @garyd9
      Like I said (typed...)
      @garyd9 said in Firmware 2.02 Release candidate 3 now available:
      I really don't understand the code I'm looking at, and my initial impression is that this change fixes a bug where the absolute mode (R0) was doing relative changes instead of absolute changes.
      For some reason when I was staring at the diff, it wasn't clicking in my head and I wanted to be clear about that when I posted. I had intended to followup when I got home, but I'm married with children. (I think that explains everything.)
      I did see some weirdness with babystepping last night myself, but that was a case of the paneldue reporting an offset of 0.00 while DWC was reporting -0.02. I think DWC was correct, but it's very difficult to measure 0.02mm while the nozzle is moving.
      "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
      BlueDustundefined 1 Reply Last reply Reply Quote 0
      • tjb1undefined
        tjb1 @garyd9
        @bluedust
        WARNING: What follows is a WAG. Well, and educated WAG, but still a guess.
        I wonder what the actual gcode DWC is sending - in particular if its actually sending a M290 R0 or M290 R1.
        I wonder this because there's a commit that appears to be functionally different for R0. Previously, it would call PushBabyStepping(val - current). Now it's calling PushBabyStep(val)
        You can see what DWC is sending the Duet by opening the Developer Tools for your browser (usually F12), select the Network tab and then click any of the buttons and you'll see something along the lines of http://ip_address/rr_gcode?gcode=
        • BlueDustundefined
          BlueDust @garyd9
          @garyd9
          I would expect it to be impossible (or close to) to measure those small changes. I just print and change it during that first layer and see the difference. But even changing it 1mm + or - doesn't do anything anymore. And that should make big obvious changes to the print.
          I am back to recalibrating Z with every power on (before I discovered the baby stepping button). Not a big deal, just takes more time.
          Thanks for looking into this.
          Fun, that 3 letter word with "u" in the middle.
          • 3DOesteundefined
            3DOeste
            Hi, I have a problem when running G29 to probe the bed. For some reason the moving speed between probe point it's extremely slow. I have M558 P9 H3 F100 T2000, but no matter what T value I put, it always moves at 1.7mm/s.
            It was working fine last time I used it, and I sincerely don't remember to have modified anything else (but perhaps I did...)
            Any clue?
            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @3DOeste
              @3doeste do you have the max speed limited in your config?
              3DOesteundefined 1 Reply Last reply Reply Quote 0
              • 3DOesteundefined
                3DOeste @Phaedrux
                @phaedrux Hi, this is my config.g, Don't mind the comments, I never change them.
                M111 S0 ; Debugging off
                G21 ; Work in millimetres
                M555 P0 ; Set firmware compatibility to look like RRF
                M564 S1 H1 ; limit movement within axis boundaries, forbid movement of axes that have not been homed
                M667 S1 ; Select CoreXY mode
                M208 X284 Y289 Z296 S0 ; Set axis maxima
                M574 X1 Y1 S0 ; Set active low endstops
                ; M574 Z0
                ; M558 P0
                ; BL Touch
                M307 H3 A-1 C-1 D-1
                M557 X0:284 Y0:289 S20
                G31 X-51.13 Y37.24 Z1.4 P25
                M376 H5
                M92 X100 Y100 Z800 E801,81 ; Set steps per mm
                M566 X600 Y600 Z12 E250 ; Set maximum instantaneous speed changes (mm/min)
                M203 X18000 Y18000 Z1200 E1200 ; Set maximum speeds (mm/min)
                M201 X3000 Y3000 Z250 E250 ; Set accelerations (mm/s^2)
                M906 X1500 Y1500 Z1500 E1400 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                M563 P0 D0 H1 ; Define tool 0
                M572 D0 S0.05 ; Set pressure advance
                M550 PIDITEC 3DPro ; Set machine name
                M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
                M552 P192.168.5.111 S1 ; Enable network and set IP address
                M553 P255.255.255.0 ; Set netmask
                M554 P192.168.5.1 ; Set gateway
                M586 P0 S1 ; Enable HTTP
                M586 P1 S0 ; Disable FTP
                M586 P2 S0 ; Disable Telnet
                ; CPU Temp
                M912 P0 S-3
                M106 P1 S0.7 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M106 P2 S0.7 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  dc42 administrators @3DOeste
                  @3doeste said in Firmware 2.02 Release candidate 3 now available:
                  Any clue?
                  Run M558 without parameters, to check that the T2000 value in config.g has been read properly.
                  • garyd9undefined
                    garyd9
                    Are there any restrictions on the commands usable in M600 macro? (filament-change.g ) I tried it tonight and when it hit the M600 macro, everything froze. The macro contained the following commands:
                    M83
                    G1 E-4 F2500
                    G91
                    G1 Z20 F5000
                    G90
                    G1 X0 Y85 F5000
                    M291 P"Change Filament"
                    M300 P5000
                    None of the moves in the filament-change.g were run as far as I could tell. It appeared to just freeze when it hit the M600. The paneldue and DWC showed a paused state, but the movement buttons and resume buttons (on both UI's) didn't do anything. The only thing I was able to do was "emergency stop" (which did work.)
                    garyd9undefined 1 Reply Last reply Reply Quote 0
                    • BlueDustundefined
                      BlueDust @BlueDust
                      Fyi
                      I just installed a previous version of the firmware and the baby steps are working.
                      • 3DOesteundefined
                        3DOeste @dc42
                        @dc42 I just done that and it’s not reading it, it shows the dame value as F, but even then it moves at 1.7mm/s.
                        M558
                        Z Probe type 9, input 0, invert no, dive height 3.0mm, probe speed 100mm/min, travel speed 100mm/min, recovery time 0.00 sec, heaters normal, max taps 10, max diff 0.01�
                        • kuhnikuehnastundefined
                          kuhnikuehnast
                          About the strange notice that a motor not seems to be connected properly... As I did some tests yesterday, the message only popped up during the G32 command...? Maybe this could be a hint to find a possible problem / solution?
                            M558
                            1.7mm/sec is about 100mm/min, so that explains it. The question is, why does it have the travel speed set to 100 instead of 2000. Do you have any M558 commands in any other files, for example homing files? If you reboot the Duet and run M558 before you home the printer or run any other commands, does it report 100 or 2000 ?
                              dc42 administrators @kuhnikuehnast
                              @kuhnikuehnast said in Firmware 2.02 Release candidate 3 now available:
                              Did you get this message when running 2.02RC3, or only with 2.02RC2 ? You don't appear to have mentioned it before in this thread.
                              kuhnikuehnastundefined 1 Reply Last reply Reply Quote 0
                                kuhnikuehnast @dc42
                                @dc42 said in Firmware 2.02 Release candidate 3 now available:
                                oh, sorry. I got on RC2 as a "red window- alert". On RC3 I now get a "yellow window" that disappears after a few seconds:
                                Warning: motor phase A may be disconnected reported by driver(s) 0
                                Warning: motor phase B may be disconnected reported by driver(s) 0
                                But the print and anything else works fine...?
                                  Thanks.
                                  • Is this on a Duet WiFi, Ethernet, or Maestro?
                                  • Are you able to identify which command in your bed.g file provokes it?
                                  • Is driver 0 driving the X motor as usual, or have you used M584 to re-map another axis or extruder to driver 0?
                                  • What current do you have that motor set to?
                                    kuhnikuehnast @dc42
                                    Thanks.
                                    It is a Duet Wifi (1.03), it is the X motor, current is set to 800 (same motor as on y). I just tried to figure out what exactly is causing the message but it is really strange! It only pops up sometimes. But if, then it almost always pops up if I start a print. Then after the G32 command and somewhere around the G29. If I don't print, I can move all axis, home all axis etc... (I can even execute my S3D- start-script...?)
                                    As slicer I use S3D, here is the start-script:
                                    G21 		; metric values
                                    G90 		; absolute positioning
                                    M82 		; set extruder to absolute mode
                                    G28 		; home axis
                                    G32 		; auto bed compensation
                                    ; G28 Z		; home z
                                    M98 PClean_Nozzle.g 	;
                                    G29 		; mesh bed levelling
                                    G92 E0 		; zero the extruded length
                                    G1 X20.0 Y20.0 Z0.2 F7800 	; start point for starting line
                                    G1 X140.0 Y20.0 E10 F800 	; extrude 8mm filament along 110mm movement in x
                                    G1 X150.0 Y20.0 Z0 F7800 	; separation move Z0 to keep up nozzle preasure
                                    G92 E0 		; zero the extruded length again
                                    and here the Clean_Nozzle.g file:
                                    ; go to start point
                                    G0 X225 Y68 Z10 F9000		; Z not yet to prevent crash
                                    M564 S0				; allow negative Z-value
                                    G0 Z4.5				; start point reached
                                    G91 				; relative positioning
                                    ; start X0 Y0 front left
                                    G0 X15  Y13 F6000 		; 1. move
                                    G0 X-15 Y14 F6000 		; 2. move
                                    G0 X15  Y13 F6000 		; 3. move
                                    G0 X-15 Y0 F7000 		; end back left
                                    M564 S1				; denie negative Z
                                    G1 Z5				; lift Z at the end
                                      Perhaps it's the nozzle cleaning script? Can you try running it a few times?
                                      You can ignore the message, because the firmware doesn't do anything apart form warn you when the drivers report open circuit motors - but obviously it's annoying.
                                      • paulowiskundefined
                                        paulowisk @k3lag
                                        @k3lag uncheck "always show info area and main menu" option in user interface in DWC.
                                        k3lagundefined 1 Reply Last reply Reply Quote 0
                                        • k3lagundefined
                                          k3lag @paulowisk
                                          @paulowisk said in Firmware 2.02 Release candidate 3 now available:
                                          Problem was stray '.' at end of the URL for my printer. I finally found the stray '.', it was in bookmark for the printer. Not sure how it got there but problem solved.
                                          • 3DOesteundefined
                                            3DOeste @dc42
                                            @dc42 Hi, it turns out I had an M558 on both my homeall and homez. I simply add the correct values at the end of the macro and problem solved.
                                            One thing I noticed by accident is that the bed levelling, after homing all axes, crush in Y. Since I never used it, the coordinates are wrong, but anyway is it normal to go beyond the limits established?
