    Firmware 2.02 Release candidate 3 now available
    Firmware installation
    31
    104
    16.2k
    • zerspaner_gerdundefined
      zerspaner_gerd @k3lag
      @k3lag said in Firmware 2.02 Release candidate 3 now available:
      @dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Since upgrading whenever I scroll down in DWC it automatically scrolls back up a couple seconds later. Very irritating. I'm using Safari 12.0. This hasn't been a problem with any previous version. It seems to print fine however.
      I have that too (with Chrome).
      It depends on the screen size, I noticed.
      Here are two pictures see scroll bar
      jump back (100%)
      scrolling works (110%)
      But I already had it with the previous version DWC 1.22.1
      Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
      • k3lagundefined
        k3lag
        I was using 1.22 and never noticed a problem. I reverted back to 1.22.3 and it behaved the same as the .4b1. However, I figured out that it is related to 'scaling' the web page. If I use the buttons in my browser to either shrink or enlarge the page the problem occurs. It does not occur if it's not being scaled. It appears others have seen the same thing in other browsers. I don't have this problem with any other web pages that I've noticed.
        • BlueDustundefined
          BlueDust @Adrian52
          @adrian52 I also see that the Print Again is missing, and it is super annoying. I keep testing the same parts after making small adjustments, pause, cancel, print again etc... And this got annoying the first time I printed after updating the firmware and web interface.
          Fun, that 3 letter word with "u" in the middle.
            I've seen an error message on the PanelDue console that hasn't shown up in the Gcode console.
            Wifi reported error: incomplete write wifi reported error: incomplete write It shows up twice like that.
            It happened once while trying to download a gcode file from the DWC. The download failed in the browser as well.
            Then it happened again uploading a Gcode file. But the gcode file seems to have uploaded correctly.
            When I saw the error message I checked the DWC console which was up and running but nothing was there.
            I then ran a M122 to see the diagnostics and the DWC reloaded and the printer paused for a second mid print and then carried on. When the DWC reloaded I ran M122 again. This time it worked. But doesn't seem to show anything amiss. Nothing was logged to the PanelDue console.
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet WiFi 1.02 or later
            Board ID: 08DDM-9FAM2-LW4SD-6JKF0-3SN6N-T2ZBY
            Used output buffers: 1 of 20 (20 max)
            Static ram: 28532
            Dynamic ram: 98720 of which 12 recycled
            Exception stack ram used: 512
            Never used ram: 3296
            Tasks: NETWORK(ready,328) HEAT(blocked,1184) MAIN(running,3484)
            Owned mutexes:
            Last reset 02:13:18 ago, cause: power up
            Last software reset at 2018-10-15 13:21, reason: User, spinning module GCodes, available RAM 3480 bytes (slot 0)
            Error status: 4
            Free file entries: 9
            MCU temperature: min 44.5, current 44.9, max 45.3
            Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0
            Driver 0: ok, SG min/max 0/1007
            Driver 1: ok, SG min/max 0/254
            Driver 2: standstill, SG min/max 0/222
            Driver 3: ok, SG min/max 0/240
            Date/time: 2018-10-21 16:43:25
            Slowest loop: 4.63ms; fastest: 0.07ms
            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 150, MinFreeDm: 150, MaxWait: 0ms, Underruns: 0, 0
            Scheduled moves: 191830, completed moves: 191800
            Bed compensation in use: mesh
            Heater 0 is on, I-accum = 0.2
            Heater 1 is on, I-accum = 0.4
            Segments left: 1
            Stack records: 3 allocated, 0 in use
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is doing "G1 X186.602 Y122.915 E0.08193" in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 182.79ms; fastest: 0.08ms
            HTTP sessions: 1 of 8
            - WiFi -
            Network state is running
            WiFi firmware version 1.21
            WiFi MAC address 5c:cf:7f:ef:4a:74
            WiFi Vcc 3.31, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 13216
            WiFi IP address 10.10.0.63
            WiFi signal strength -40dBm, reconnections 0, sleep mode modem
            Socket states: 0 2 0 0 0 0 0 0
            === Expansion ===
            • Synapsisundefined
              Synapsis
              I have been using it without any real problem but a funny one.
              While I was connected I had to turn my router off. When the router was back online the duet reconnected but the web interface would not connect again, even after a refresh of the page. I closed the browser and reopened it, but nothing it would not connect to the duet.
              I had to turn the duet off then on and all was back to normal.
              • timcurtis67undefined
                timcurtis67
                If you have a panel due try sending an M552 S1to restart the Wifi.
                See https://duet3d.dozuki.com/Wiki/GCode#Section_M552_Set_IP_address_enable_disable_network_interface
                • chrishammundefined
                  chrishamm administrators @Adrian52
                  @adrian52 Thanks for the note, I'll fix this shortly.
                  @k3lag I'm afraid I cannot reproduce this. I tried it on Firefox (Win+Linux), Edge and Safari (OS X) but it never scrolls up for me. Can you check if the toggling the option "Always show info area and menu" on the Settings makes a difference?
                  Edit: There you go - v1.22.4 is now official: https://github.com/chrishamm/DuetWebControl/releases/tag/1.22.4
                  Duet software engineer
                  k3lagundefined 1 Reply Last reply Reply Quote 0
                  • k3lagundefined
                    k3lag @chrishamm
                    I can't duplicate now either. It was consistent for a few days now suddenly it seems fine. I'll let you know if the problem returns and I'll pay attention to any change in circumstances that may cause it.
                    • k3lagundefined
                      k3lag @k3lag
                      It just started doing it again and I noticed what's going on but I don't know why. My printers name on the network is "bigbox.local". If the URL in address bar is "bigbox.local" it does not exhibit the problem. Somehow the URL is changing to "bigbox.local." (notice the "." at the end) and when it is that way it scrolls back to the top after scrolling down. I'm not sure where the extra "." is coming from. If I manually put the "." on the end when it's working correctly the behavior will start as well. For some reason the extra "." is getting added to the end of URL on its own somehow.
                      • BlueDustundefined
                        BlueDust
                        Z Baby Stepping doesn't seem to work any more.
                        I just updated DWC to 1.22.4 to see if that would fix it, and it did not.
                        Current version
                        Firmware Electronics: Duet Ethernet 1.02 or later
                        Firmware Version: 2.02RC3(RTOS) (2018-10-17b2)
                        Web Interface Version: 1.22.4
                        Is anyone else having this problem?
                        garyd9undefined 1 Reply Last reply Reply Quote 0
                        • garyd9undefined
                          garyd9 @BlueDust
                          @bluedust said in Firmware 2.02 Release candidate 3 now available:
                          It seems to be working for me from both the 1.22.4 DWC (that was just put out today) and from the PanelDue 1.22 released a couple days ago. (It's annoying from the Paneldue due to the "response" popups, but it seems to work.)
                          What symptoms are you seeing that suggest it's not working?
                          "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
                          BlueDustundefined 1 Reply Last reply Reply Quote 0
                          • claustroundefined
                            claustro
                            M557 now supports a P parameter to set the number of X and Y points, as an alternative to using the S parameter to set the spacing
                            So I can write M557 X30:260 Y15:245 P9
                            Instead M557 X30:260 Y15:245 S57.5
                            and the firrmware automatically calculate probe point spacing right?
                            i
                              dc42 administrators @claustro
                              @claustro said in Firmware 2.02 Release candidate 3 now available:
                              i
                              Yes, that's correct.
                              Googliolaundefined 1 Reply Last reply Reply Quote 0
                              • fmaundefined
                                fma @k3lag
                                Could it be related to this bug? https://www.thingiverse.com/thing:2448907
                                On previous versions of Chromium, I was able to set the 'enable-scroll-anchoring' to true, and it fixed the problem. But in recent versions, this flag does not exists anymore, and the bug came back (on Thingiverse, I didn't try Duet latest firmware).
                                Frédéric
                                • BlueDustundefined
                                  BlueDust @garyd9
                                  @garyd9
                                  I press the neagtive or positive buttons and the nozzle doesn't get any closer or further from the bed. I use this all thr time adjust the squish during the first layer.
                                  I didn't reboot my printer a second time after installing the 3rd beta of the firmware. I will do that when I get home and see if that fixes it.
                                  • garyd9undefined
                                    garyd9 @BlueDust
                                    @garyd9
                                    How big are your baby steps configured for? Does DWC claim that the baby steps are taking place? (It shows the current babystep.) On mine, I never actually measured the nozzle distance to ensure that the babysteps were happening, but I know that I'm about 0.04mm too high on my manual level, and if I don't babystep, everything curls up.
                                    • SupraGuyundefined
                                      SupraGuy
                                      I hadn't thought much about this, but I'm seeing something similar.
                                      Baby steps are configured as 0.05mm, but I'm not seeing any effect on the machine. It changes the compensation factor on the DWC, (I had it showing up to a full 3mm of compensation at one point) but it didn't move the Z axis motors at all, so far as I could see.
                                      My last few prints, I just stopped using it, because I thought that it might be something in my Z speed/acceleration settings not letting it get started for such a small move.
                                      This started when I upgraded to 2.02RC2, still happening with RC3, however I also changed my Z lead screws when I upgraded to 2.02RC2 from 5mm/0.8mm lead to 8mm/8mm lead (4000 steps/mm to 400 steps/mm.) I had assumed that it had to do with the change in lead screws. I don't have those values from my config.g in front of me at the moment.
                                      Lead screw driven printer, powered by Duet 2 Wifi
                                      MPCNC powered by Duet 2 Wifi
                                      CoreXY printer driven by Duet 3 6HC
                                      LowRider CNC powered by Duet 2 Wifi
                                      • BlueDustundefined
                                        BlueDust @garyd9
                                        @garyd9
                                        Default change is .05mm and it does say its changed. Usually I change this value from .25 to .35. After a 5 point calibration, start a print, change this Z level to around .25 / .35 to get a good squish going.
                                        Usually stays pretty close to that initial adjustment after many 5 point calibrations until I power off/on again. And then I have to make this adjustment again.
                                        Right now when I push the button - or + no changes are made, and as such, my prints don't always stick. This was working a 2 days ago. Appears like it stopped a day or two after I installed beta 3. I don't reboot the machine often so I may have rebooted it for the first time after installing the beta, but emergency stopping a print or something, that started this issue... Just saying that possible. Will reboot again when I get home. If that doesn't fix it will reinstall the current beta and if that doesn't help may reinstall beta 2 to confirm, as it was working for me.
                                        Thanks
                                        • garyd9undefined
                                          garyd9 @BlueDust
                                          @bluedust
                                          WARNING: What follows is a WAG. Well, and educated WAG, but still a guess.
                                          I wonder what the actual gcode DWC is sending - in particular if its actually sending a M290 R0 or M290 R1.
                                          I wonder this because there's a commit that appears to be functionally different for R0. Previously, it would call PushBabyStepping(val - current). Now it's calling PushBabyStep(val)
                                          I really don't understand the code I'm looking at, and my initial impression is that this change fixes a bug where the absolute mode (R0) was doing relative changes instead of absolute changes.
                                          garyd9undefined tjb1undefined 2 Replies Last reply Reply Quote 0
                                            The only change made to baby stepping in RRF 2.03RC3 is to remove the limit of +/-1mm change when using absolute mode.
                                            Old code:
                                            const bool absolute = (gb.Seen('R') && gb.GetIValue() == 0);
                                            float difference = (absolute) ? fval - currentBabyStepZOffset : fval;
                                            difference = constrain<float>(difference, -1.0, 1.0);
                                            currentBabyStepZOffset += difference;
                                            New code:
                                            float difference;
                                            if (absolute)
                                            	difference = fval - currentBabyStepZOffset;
                                            	currentBabyStepZOffset = fval;
                                            else
                                            	difference = constrain<float>(fval, -1.0, 1.0);
