    Printerboard reboots when trying to print a file
    reboot duet maestro troubleshooting help printing timeout
    • jottesman
      jottesman last edited by
      So I set up my Duet Maestro on a a printer recently and had no issues (that I couldn't easily fix myself).
      However today when I go to print a file, as soon as it starts the file, the board appears to reboot and I get a pop-up with the following error message:
      The connection between the browser and your machine has been interrupted.
      Reason: Request Timeout
      Please wait while a new connection is being established..."
      There appears to be no issues up to the point of trying to print a file, I can upload files, move axis, control heaters but as soon as I go to print any file, even those that had previously worked flawlessly, I encounter this problem.
      Here is the output from the M122 command
      4:35:59 PMM32 "Geckooooo.gcode"
      File Geckooooo.gcode selected for printing
      4:32:23 PMM122
      RepRapFirmware for Duet 2 Maestro version 2.02RC5(RTOS) running on Duet Maestro 1.0
      Board ID: 08DAM-9F9DA-MWNS8-6J9DA-3SW6R-141UW
      Used output buffers: 3 of 20 (8 max)
      Static ram: 21236
      Dynamic ram: 96672 of which 0 recycled
      Exception stack ram used: 188
      Never used ram: 12976
      Tasks: NETWORK(ready,456) HEAT(blocked,1356) MAIN(running,3672) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:00:26 ago, cause: power up
      Last software reset at 2018-12-02 15:12, reason: User, spinning module GCodes, available RAM 13596 bytes (slot 0)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      SD card 0 detected, interface speed: 15.0MBytes/sec
      MCU temperature: min 24.5, current 25.7, max 26.0
      Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, read errors 0, write errors 0, ifcount 6, reads 1039, timeouts 0
      Driver 1: standstill, read errors 0, write errors 0, ifcount 6, reads 1039, timeouts 0
      Driver 2: standstill, read errors 0, write errors 0, ifcount 6, reads 1039, timeouts 0
      Driver 3: standstill, read errors 0, write errors 0, ifcount 6, reads 1039, timeouts 0
      Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 1039, timeouts 0
      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1044
      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1044
      Date/time: 2018-12-02 16:32:22
      Slowest loop: 69.98ms; fastest: 0.06ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Bed heaters = 0, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 5.40ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      4:32:11 PMConnection established!
      4:32:03 PMDisconnected.
      4:31:55 PMM32 "Geckooooo.gcode"
      4:31:30 PMConnection established!
      4:31:27 PMPage Load complete!
      Any help or advice would be greatly appreciated, I have tried re-uploading the firmware and the web Interface zip with no luck and haven't found anyone with a similar problem on the forums yet.
        The M122 report includes:
        This indicates that the reboot was caused by loss of power. Did you run the M122 command immediately after the problem occurred? If so then some command in the print file is causing your PSU to be overloaded and cut out. I suggest you test the heaters, and motors again, first individually, then run them all at the same time.
        Another possibility is that you have wired the endstop switches incorrectly and they are shorting +3.3V to ground; but if that is the case then you will get resets when you try to home the printer.
        • UnderDoneSushi
          UnderDoneSushi last edited by UnderDoneSushi
          @dc42 I just got this error also,
          it then reconnects, the printer was just sitting there idling, I had homed the XYZ axis but nothing else. Just sitting there looking at the DWC. Looking over the M122 I am going to assume my wifi connection is very poor?
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC5(RTOS) running on Duet WiFi 1.02 or later
          Board ID: 08DGM-956GU-DJ3SN-6J1FA-3SD6Q-KURMG
          Used output buffers: 3 of 20 (15 max)
          Static ram: 27284
          Dynamic ram: 98488 of which 0 recycled
          Exception stack ram used: 376
          Never used ram: 4924
          Tasks: NETWORK(ready,328) HEAT(blocked,1232) MAIN(running,3596) IDLE(ready,200)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:15:10 ago, cause: power up
          Last software reset at 2018-12-11 23:23, reason: User, spinning module GCodes, available RAM 4908 bytes (slot 3)
          Error status: 0
          MCU temperature: min 34.5, current 34.6, max 34.7
          Supply voltage: min 12.2, current 12.3, max 12.4, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2018-12-17 23:45:20
          Cache data hit count 3375536241
          Slowest loop: 1.10ms; fastest: 0.08ms
          Scheduled moves: 9, completed moves: 9
          Segments left: 0
          === Network ===
          Slowest loop: 157.72ms; fastest: 0.08ms
          • WiFi -
            Network state is running
            WiFi firmware version 1.21RC4(08b3)
            WiFi MAC address 5c:cf:7f:76:67:2f
            WiFi Vcc 3.38, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 15296
            WiFi IP address 10.51.108.101
            WiFi signal strength -73dBm, reconnections 0, sleep mode modem
            Signal strength of -73dBm is marginal for the WiFi module. Please see https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors.
