    2 Z motors, to endstops
    1.9k
    • SupraGuyundefined
      SupraGuy
      It appears to me that you have most of the groundwork done. I'm still able to auto-level using the probe, so this isn't going to be my solution.
      You will want to add Z and U to your M574 endstop definitions.
      The U endstop should be connected to the E1 (drive 4) endstop.
      I don't know offhand the correct way to handle the homez.g and homeall.g files from that point. My expectation would be to "lift" the U axis by a small amount to ensure that the Z endstop homes first, then use a G0 S1 Z-300 to home the Z axis, then G0 S1 U-5 to home the U axis afterwards, but then there is very probably a better way to do that.
      Using this logic, homez.g might look like:
      ;homez.g
      G91                 ; relative positioning
      G1 U2 S2 F3000      ; Raise the "U" axis by 2mm -- home Z first please.
      G1 Z-300 S1 F300    ; Home the Z endstop
      G1 U-3 S1 F300      ; home the U endstop
      G1 Z3 F6000         ; Lift a few mm
      G1 Z-5 F300 S1      ; Re-home to the Z switch
      It won't deal with much of a difference between U and Z, it will error if U was more than 1mm higher than Z, and could get ugly if U was more than 2mm lower than Z.
      Lead screw driven printer, powered by Duet 2 Wifi
      MPCNC powered by Duet 2 Wifi
      CoreXY printer driven by Duet 3 6HC
      LowRider CNC powered by Duet 2 Wifi
      • Torroundefined
        Torro
        Hi.
        Thanks. In the guide is described, how to split Z to U and Z for homing. It's on the list for Today
        • Torroundefined
          Torro
          paste and copy from the guide. just changed 3 to 4
          unfortunately, the endstops are not delivered. i hope for tomorrow...
          i´ll test asap
          M584 Z2:4 U4 P4 ; split z control
          G1 S1 Z-350 U-350 F1000
          G1 Z5 U5 F500
          G1 S1 Z-10 U-10
          M584 Z2:4 P3 ; combine Z
          G90
          G92 Z0
          • aidarundefined
            aidar
            This might help : https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18?lang=en
            • Torroundefined
              Torro
              Hi there,
              i got it working. but not with drive 2&4. U didn´t move. tried a few things, no luck. So i changed it to 2&3 for Z and 4 for the extruder. worked immediately. i don´t know why, but it´s ok. maybe drive 4 has to be the V axis?
              now, there is one small issue. when i power on the printer, i have to home Z first. when i try to home X or Y before, nothing happens???
              what could that be?
              config.g and homing files:
              homez
              M584 Z2 U3 P4 ; split z control
              G1 S1 Z-350 U-350 F2000
              G1 Z5 U5 F400
              G1 S1 Z-10 U-10
              M584 Z2:3 P3 ; combine Z
              G90
              G92 Z0
              homey
              G1 S1 Y-300 F5000 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F3600 ; go back a few mm
              G1 S1 Y-206 F360 ; move slowly to Y axis endstop once more (second pass)
              G90 ; absolute positioning
              homex
              G1 S1 X-300 F5000 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F360 ; go back a few mm
              G1 S1 X-206 F360 ; move slowly to X axis endstop once more (second pass)
              homeall
              G1 S1 X-300 Y-300 F5000 ; move quickly to X or Y endstop and stop there (first pass)
              G1 S1 X-300
              G1 S1 Y-300
              G1 X10 Y10 F6000 ; go back a few mm
              G1 S1 X-20 F360 ; move slowly to X axis endstop once more (second pass)
              G1 S1 Y-20 ; then move slowly to Y axis endstop
              M98 Phomez.g
              config.g
              M569 P2 S1 ; Drive 2 goes forwards Z @ Xmax
              M569 P3 S1 ; Drive 3 goes forwards Z @ Xmin
              M569 P4 S1 ; Drive 4 goes forwards
              M584 X0 Y1 Z2:3 U3 E4 P3 ; two Z motors connected to driver outputs Z and E0 Hide U
              M350 X16 Y16 Z16 U16 E16 I1 ; Configure microstepping with interpolation
              M92 X80.00 Y80.00 Z160 U160 E420.00 ; Set steps per mm
              M566 X900.00 Y900.00 Z12.00 U12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
              M203 X30000.00 Y30000.00 Z4000.00 U4000.00 E4000.00 ; Set maximum speeds (mm/min)
              M201 X1500.00 Y1500.00 Z500.00 U500.00 E10000.00 ; Set accelerations (mm/s^2)
              M906 X800.00 Y800.00 Z800.00 U800.00 E800.00 I40 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S3000 ; Set idle timeout
              M208 X0 Y-1 Z0 S1 ; Set axis minima
              M208 X240 Y260 Z288 S0 ; Set axis maxima
              M574 X1 Y1 S0 ; Set active high endstops
              M574 Z1 U1 S1
              aidarundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              • aidarundefined
                aidar @Torro
                @torro said in 2 Z motors, to endstops:
                This sounds like your Z motor is connected to X (drive 0) connector. If you home Z, what DWC shows? Homed X i guess.
                • Torroundefined
                  Torro
                  No, all is running correct AFTER i homed Z.
                  nothing moves if Z is not homed.
                  • aidarundefined
                    aidar
                    Please post your full config.g as well as config-override.g, (those on duet sd card, not somewhere in your computer, to eliminate possibilty that your backup ones in computer are not up to date)
                    • Torroundefined
                      Torro
                      no config-override in the system.
                      ; generated by RepRapFirmware Configuration Tool v2 on Sat Nov 24 2018 10:45:17 GMT+0100 (Mitteleuropäische Normalzeit)
                      M80
                      M667 S1 ; Select CoreXY mode
                      M550 P"MKC" ; Set machine name
                      M552 S1 ; Enable network
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      ; Specials
                      M307 H2 A-1 C-1 D-1 ; disable the heater functionality
                      M569 P2 S1 ; Drive 2 goes forwards Z @ Xmin
                      M569 P4 S1 ; Drive 4 goes forwards Z @ Xmax
                      M584 X0 Y1 Z2:3 U3 E4 P3 ; two Z motors connected to driver outputs Z and E1 Hide U
                      M574 Z1 U1 S1
                      ;M558 P1 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed;
                      ;G31 P500 X0 Y50 Z1.45
                      ;M557 X20:220 Y70:240 S20 ; Define mesh grid
                      M305 P0 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
                      M143 H0 S130 ; Set temperature limit for heater 0 to 120C
                      M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                      M307 H1 A438.2 C134.9 D3.9 B0
                      M106 P2 T45:55 H100:101:102 ; Set fan 2 value,
                      M912 P0 S-3,5
                      M563 P0 D0 H1 ; Define tool 0
                      ; Automatic power saving
                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                      • aidarundefined
                        aidar
                        Ok, config seems to be ok. So what exactly happens if you send G28 from DWC gcode console? If nothing moves, there should be some response message from duet why nothing moves. What that message says?
                        • Torroundefined
                          Torro
                          Just started a print...
                          yesterday, there was no message from DWC.
                          A click on "home all" did nothing, but i couldn´t move the motors by hand anymore.
                          will test G28 asap
                          • Torroundefined
                            Torro
                            after powering up the printer, a single G28 without any parameter does nothing. the circle in the "send" button spins and spins and spins. when i click "emergency stop", a message "homing failed" appears.
                            then i homed only Z. works. after that, G28 works without any issue, same as the button "homeall"
                            • aidarundefined
                              aidar
                              That is odd. You are not supposed to be able home Z at all before X and Y are not homed. What firmware version are you using and what version of DWC?
                              • Torroundefined
                                Torro
                                Duet Web Control 2.0.0-RC3
                                Electronics: Duet WiFi 1.02 or later
                                Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.02(RTOS) (2018-12-24b1)
                                Duet WiFi Server Version: 1.22
                                  Phaedrux Moderator @Torro
                                  homeall
                                  G1 S1 X-300
                                  G1 S1 Y-300
                                  M98 Phomez.g
                                  Try changing M98 Phomez.g to G28 Z
                                  Torroundefined 1 Reply Last reply Reply Quote 0
                                  • Torroundefined
                                    Torro
                                    Ok. I will try.
                                    • Torroundefined
                                      Torro
                                      I didn't test it yet, but i have an idea, i could put the home Z order on top in the first line. I Guess it works... 🙂
                                      • thweundefined
                                        thwe
                                        On my CoreXY also with 2 Z-Motors and 2 Endstops (1 for Z and 1 for U - Drive 2 and 3) i have to home Z also at first.
                                        Only for example - without any garanty - see my homeall.g:
                                        ; ##############  homeall.g -> called to home all axes  ##############
                                        M98 Phomez.g                 ; X homing
                                        M98 Phomex.g                 ; Y homing
                                        M98 Phomey.g                 ; Z homing
                                        G90
                                        ; #################    checking trigger height + Z null adjusting    #################
                                        G1 X144 Y150 F12000
                                        G1 Z20 F1800
                                        G1 Z15 F1200
                                        G1 Z10 F600
                                        T0
                                        G30                            ; Probe the bed at the current XY position, set the Z coordinate to the probe trigger height
                                        G4 P200
                                        G1 Z50 F1800
                                        ; END OF FILE
                                        and my homez.g:
                                        ; ##############  homez.g -> called to home the Z axis  ##############
                                        M584 Z2 U3 P4               ; Split Z into 2 (Z+U)
                                        G1 S1 Z999 U999 F600        ; Move the bed down in the Z direction. S1 to stop if endstop is triggered
                                        G1 S2 Z-3 U-3 F600          ; Move the bed up 3mm in the -Z direction, ignore if axis are not homed
                                        G1 S1 Z9 U9 F200            ; Move slowly in the +Z direction again to stop exactly at the homing switch
                                        M400                        ; Wait for current moves to finish
                                        G4 P100
                                        G1 S2 Z0.00 U0.00 F200      ; Compensation the limit switch from z-axis drive 2 (!!can be adjusted here!!)
                                        G4 P100
                                        M584 Z2:3 P3                ; Join U to Z again
                                        G4 P100
                                        G92 Z282.00                 ; set position of Z relativ to the bed (!!must be adjusted here!!)
                                        G90                         ; Back to absolute mode
                                        G1 S2 Z270 F900
                                        ; End of file
                                        Thomas
                                        • Torroundefined
                                          Torro
                                          Good to know. Thanks!
                                          • Torroundefined
                                            Torro @Phaedrux
                                            @phaedrux said in 2 Z motors, to endstops:
                                            homeall
                                            G1 S1 X-300
                                            G1 S1 Y-300
                                            M98 Phomez.g
                                            Same behaviour. I just put the m98 phomez. G in the first line of homeall.g
                                            Now it works as expected
