    CoreXY - X-Axis Vibration Issues
    49
    7.2k
    • Syko_Symaticundefined
      Syko_Symatic
      Hi all,
      I have recenetly finished building my first CoreXY printer. I have built several printers in the past (Prusa Style, Ultimaker Style and an IDEX) but I am struggling with the vibration I am having on the X-Axis.
      Both X and Y are on linear rails and I have measured them with a dial to be as parallel as possible. However, it still seems that the X-axis rail is binding (possibly) and that is the source of my vibration issues?
      Does anyone have any advice on this? Could it be a belt tension issue?
      I would appreciate any input!
      Thanks,
      zaptaundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        initialy i had the x rail fixiated but it cause loud vibrations on some moves.
        i removed the fixiation and now the x rail can move slightly back and forth and the vibrations are gone.
        see https://www.thingiverse.com/thing:2839395
        the rail is just prevented from sliding out completly by a screw
          Syko_Symatic
          It's definitely something I can look at. I will have to model some sort of clamp for the rail. How does it stay "square" if it is allowed to move?
          • Vetiundefined
            Veti
            its allowed to move in one direction to counteract slight alignment issues but it can not rotate.
            Syko_Symaticundefined 2 Replies Last reply Reply Quote 0
              Syko_Symatic
              I think I understand, I am trying to look at your thingiverse link but the site is sooooo slow a the moment!
              Gearundefined 1 Reply Last reply Reply Quote 0
                Syko_Symatic @Veti
                @veti OK! So I have created a quick and dirty solution! I am going to print it in a few minutes and we will see if that solves the issue!
                  Syko_Symatic @Veti
                  @veti So unfortunately it didn't help. My solution wasn't perfect by any means but it didn't change at all. Hmm... any other ideas? I know without the belts in ran perfectly, so it's obviously being pulled by the belts (as I understand is pretty normal with corexy).
                  • deckingmanundefined
                    deckingman @Syko_Symatic
                    @syko_symatic Difficult to advise without a bit more information. All we know is that it's a CoreXY. Can you post some pictures -especially showing the belt arrangements. A bit better description of the problem would also help.
                    Without having much to go on, I could make a shot in the dark and say that it might might be uneven belt tension that is imparting a twisting force which in turn is causing the guides to bind. The "classic" CoreXY belt patter usually shows the X carriage belts being quite a distance either side of the centre line of the X carriage. So if your belts are aligned like that, and the tension is uneven, then you might be getting a twisting force, which might be causing the guides to bind. I use stacked belts running along the centre line of the X carriage but you may not be able to do that easily.
                    Syko_Symaticundefined 1 Reply Last reply Reply Quote 0
                    • Vetiundefined
                      Veti
                      also check that there is no twisting of the belts on direction change.
                      i.e make a gcode file with rapid 5mm movement back and forth at high speed and look at the belts during this.
                        Syko_Symatic @deckingman
                        @deckingman Thanks, I will try and add some more info.
                        The belt arrangment is stacked and looks almost exactly like e3d's tool changer machine. I have included a short video from the other night. The noise isn't an issue in that video as it doesn't occur until it's moving a little faster.
                        Link
                        I have tried increasing and decreasing belt tension to no avail. Could it possibly be motor setting related?
                        • Vetiundefined
                          Veti
                          create a gcode that can replicate the noise.
                          Then while its making the noise try to narrow down the location.
                          the frame looks like it could be resonating at certain frequencies.
                            Syko_Symatic @Veti
                            @veti It definitely sounds like it's coming from the x-axis carriage. I am going to give tuning the acceleration and max speed a go. Any suggestions of a good starting point?
                            • mrehorstdmdundefined
                              mrehorstdmd
                              Is the X axis linear guide a "preload" type? How is the X axis rail mounted so that it can slide? If it is free to move, it may be free to rattle, depending on how it's mounted.
                              • Vetiundefined
                                Veti
                                how stable is the x carriage? Push the nozzle in different directions and see if there is play.
                                Also check the fans. I had some fans that created a rattle caused by the blades moving inside the fan at higher speeds. and banging on the casing
                                  Syko_Symatic @mrehorstdmd
                                  @mrehorstdmd yes it’s preloaded. It is secured to a cross-brace by a few cap head screws.
                                  • fcwiltundefined
                                    fcwilt
                                    It's hard to tell from the video but are the belts on either side of the X slide parallel to the slide?
                                      Syko_Symatic @fcwilt
                                      @fcwilt as best as I can get them. I’m going to try re-aligning everything again. Annoying, but I am going to wait for some new gates pulleys from E3D to make sure everything is the best it can be.
                                      Or maybe I will re-align it all first? I can’t decide. Either way I will keep trying.
                                      • fcwiltundefined
                                        fcwilt @Syko_Symatic
                                        @syko_symatic
                                        Well I think it has to be something about your build.
                                        I built a D-Bot CoreXY printer and it has no binding issues at all. BUT it uses wheels-on-extrusion tech, not slides.
                                        My next CoreXY will try slides.
                                          @fcwilt my thoughts exactly hence the slight rebuild. At least I can do it by only removing the top plate!
                                          • Gearundefined
                                            Gear @Syko_Symatic
                                            @syko_symatic just press f5 untill it loads ...
