    Duet Web Control 2.0.0-RC5
    Duet Web Control
    23
    87
    10.4k
    • NicoLab28undefined
      NicoLab28
      Keyboard issues (arrows and others) in the editor
      Print time wrong under S3d, tells me 1h 0s instead of 1h 35m
      No print time, after printing, when you arrive late.
      The time of the simultation not updated.
      Bug on the selected tool, it appears in dark mode, but not in light. I still have not validated everything, but it seems that in dark mode, it always displays tool 0 even unsorted.
      • chrishammundefined
        chrishamm administrators @appjaws
        I just figured out why the inputs stop working, it's due to an update of the 3D library THREE that somehow blocks keyboard inputs once an instance of it is created. I will provide RC6 with a downgraded version of THREE later today.
        @appjaws said in Duet Web Control 2.0.0-RC5:
        The connect / disconnect button is missing
        At the moment the Connect / Disconnect button is only available when running from localhost. I will add an option as soon as multi-machine support has been fully added (should be no big deal since the backend is already finished).
        @wilriker said in Duet Web Control 2.0.0-RC5:
        @chrishamm: one thing that I always do and that never works - but worked in DWC1 - is to use ESC to close the editor without saving.
        Good point, I'll add this again in RC6.
        @garyd9 said in Duet Web Control 2.0.0-RC5:
        @chrishamm
        Very minor issue with Duet Web Control 2.0.0-RC5:
        1. The interface shouldn't give the option to "simulate file" or "start file" while it's already simulating a file. (It also should disable those options if a print is already running, but I didn't check that.)
        or
        1. If disabling the options isn't possible, it should pop up the resulting duet error message ("Error: M37: cannot simulate while a file is being printed")
        Good point, these options will be hidden in RC6 if a file print is in progress.
        @kraegar said in Duet Web Control 2.0.0-RC5:
        RC5 is more stable than RC4 for me, but the files menu is now more annoying with the single click / double click mechanics. And I can't find any way to navigate back up in the directory tree, other than to refresh the page.
        You can go up by clicking on the links that are displayed above the file list once you enter a sub-directory. I understand the concept of click/double-click needs to be changed for touch devices (which I will do in RC6) but what's the problem with activating items via double-click on a standard PC?
        @nicolab28 said in Duet Web Control 2.0.0-RC5:
        Thanks for the bug report concerning the active tool highlighting, it will be fixed in RC6. Are the keyboard issues related to the height map problem I mentioned? The print stats will remain on the jobs page after a print finishes in RC6.
        Duet software engineer
        wilrikerundefined NicoLab28undefined kraegarundefined 3 Replies Last reply Reply Quote 0
        • wilrikerundefined
          wilriker @chrishamm
          @chrishamm said in Duet Web Control 2.0.0-RC5:
          Mainly because we are all used to using single-clicks to open the editor/start the print.
          Manuel
          My Tool Collection
          AlexLinundefined 1 Reply Last reply Reply Quote 0
            NicoLab28 @chrishamm
            I was not in the heightmap, but in the macro editor. But I may be open at one point the heightmap.
            I also noticed that I could not edit gcode anymore in the top bar. Neither do F5, I had to close the window for it to work again. So it's probably the same problem.
            I must say that the DWC window is open 24/24, by the way, when I turn off the printer, and that I turn it on, the temperature curves are extremely long, it seemed to me that it resynchronized on the last minutes.
            To check that library three.js do not have this problem too.
            • AlexLinundefined
              AlexLin @wilriker
              @wilriker yeah first couple of times I was annoyed but you get used to it. And it probably more common to select with one click and open/print with 2..
              • kraegarundefined
                kraegar @chrishamm
                @chrishamm Might be a personal thing. I find it unintuitive.
                The "go up a directory" wasn't appearing for me previously, but is now. May have been due to a restart being needed or something odd.
                Co-Creator of the RailcoreII CoreXY printer
                https://www.thingiverse.com/thing:2407174
                • garyd9undefined
                  garyd9 @chrishamm
                  @chrishamm
                  More feedback on RC5 (used with Chrome 72.0.3626.119 on 64-bit windows):
                  Every now and then (and I can't seem to figure out steps to repeat) aspects of the UI stop working or disappear. Two areas I've seen so far:
                  1. The ability to move to a parent directory in the "G-Code Jobs" (the navigation breadcrumb disappears.)
                  2. The ability to manually type a heater temperature. (The drop down works to change temp, but clicking/highlighting the active temp and typing a new temp doesn't work - the page doesn't seem to see any keystrokes.)
                  Edit: Both of the above two issues can be resolved by reloading the page (F5 on Win10/64.)
                  Another issue which is disturbing is that the page doesn't update when it's not in the foreground. To be specific, with Chrome 72.0.3626.119 on 64-bit windows, if I have DWC2 in a tab, and another page in another tab - DWC only updates if the DWC tab is in front. This results in the title of the page (which shows the percent complete) NOT updating. Once the DWC tab is brought to the front, DWC plays "catchup" with any graphs and percentages. (It's actually amusing to watch.)
                  DWC1 would update even if not the foreground tab (which meant I could at least monitor the percent complete of a print job while doing things in other tabs.)
                  "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
                  • ctilley79undefined
                    ctilley79 @deckingman
                    @deckingman said in Duet Web Control 2.0.0-RC5:
                    @pkos Unfortunately, Prusa version of Slic3R is becoming more and more biased towards it being used with Prusa firmware and every release sees this integration becoming tighter and tighter.
                    So should we expect RepRap firmware to be changed to support a specific slicer? To my mind, the slicer should be firmware agnostic but Prusa Slic3R has started doing things differently.
                    I disagree with this statement. For example, they added the option to upload directly to a Duet WiFi from within slic3r pe. Not sure how your statement is in the least bit accurate.
                    Phaedruxundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @ctilley79
                      @ctilley79 the upload to duet feature was a contribution from a forum user here. They didn't expend much energy to bring you that.
                      I think most of the difference is because Marlin is just so pervasive. Not only do their own printers run Marlin but so does the majority of other users printers.
                      • garyd9undefined
                        garyd9
                        Some more minor RC5 issues:
                        When printing something that hasn't been simulated, "Current Job - Status" shows a time estimate based on simulation. (I'm guessing that it's actually showing the useless time WAG that my slicer generates? Is so, should the label be "based on slicer" instead of "based on simulation"?)
                        While simulating a print, "Current Job - Status" is showing an estimation "based on simulation." (Again, I'm guessing that this number is actually based on the slicer WAG if the file hasn't been simulated before.) Even if there was an accurate simulated time in the gcode file, this number should be BLANK while simulating (as it can't possibly make sense.)
                        • samlogan87undefined
                          samlogan87
                          @chrishamm I think I have found another issue. I don't remember if this did it in the v1 DWC but if a job finishes, the baby stepping doesn't clear. It seems that when you relevel your bed and do not clear the baby stepping, it sets the zero point at the particular baby stepping height and you need to baby step down again to suit the print.
                          Custom Core-XY
                          DocTruckerundefined 1 Reply Last reply Reply Quote 0
                          • DocTruckerundefined
                            DocTrucker @samlogan87
                            @samlogan87 Think that's a firmware rather than DWC issue. There's been some discussion about it recently.
                            I've still got to get my head around why baby stepping exists rather than just having a wrapper around say 'G10 P0 Z...' for the first tool.
                            • deckingmanundefined
                              deckingman @ctilley79
                              @ctilley79 said in Duet Web Control 2.0.0-RC5:
                              Fair enough. You are entitled to your opinion. Mine is based on certain facts so I'd be interested to know what yours is based on. Let's leave aside the upload to Duet feature because that's common to both versions of slic3r and as @Phaedrux pointed out, the request for that integration originated here on these forums, not from Prusa.
                              I use mixing hot ends. So I might have say a 5 colour Diamond hot end with 5 filaments fully loaded at all times, each filament being driven by a single extruder. A tool can use any number of these extruders so for example to produce say Orange, I can mix Red and Yellow. Or if I wanted say dark Green, I might use Blue, Yellow and Black. And so forth.
                              So having 10 or more tools defined is not unreasonable. Plain "vanilla" slicr3r" doesn't care about this. For multi coloured objects, I can assign any tool number to any part. Even tool number 9,999 if I wanted to. All the slicer has to do is insert the correct tool number at the appropriate point in the file, which "vanilla" slic3r does admirably well.
                              Prusa printers don't have mixing hot ends. For multi colour printing, they use their own MMU unit. So the concept of mixing hot ends is alien to Prusa and they have disabled some of the features of slic3r in their version. For example, Prusa slic3r won't allow me to assign any tool to an object part if that tool number is greater than the number of extruders defined in the printer profile. It assumes that every tool must have a single extruder - not only does it assume that - it forces me to set up my printer that way. So if I want to assign say tools 3, 7 and 9 to parts of an object, I'd first have to define a printer profile with 10 extruders even though only 5 physically exist. Then to make matters worse, the slicer can put filament specific commands into the gcode file. But for that to work, every tool has to have a single filament assigned to it and every fiaments has to have a "profile".
                              So if I define a tool as say tool 15, I don't need to do anything differently using "vanilla" slic3r. If I want to use that on PE Slic3R, I'd have to define a machine with 15 or more extruders, and the set up filament profiles for 15 different filaments, even though they may all be combinations of the same PLA.
                              So, in my opinion PE Slic3R is becoming too biased towards Prusa printers and I continue to hold that opinion.
                              fmaundefined 1 Reply Last reply Reply Quote 0
                              • fmaundefined
                                fma @deckingman
                                I agree. Another annoying example: if you choose Marlin as flavor, it always set speed/accel/jerk params defined in Slic3rPE...
                                But this does not mean that a slicer and a firmware teams should not work together: I think it is mandatory to introduce new robust features. And it is possible to do it without breaking compatibility with other firmwares; it is just a matter of options to turn on/off.
                                And once these features are there, other firmware teams may add them.
                                Frédéric
                                  deckingman @fma
                                  @fma Yes. It'd be nice to see the Duet team, or someone closely allied to them, write a slicer. I wouldn't be at all averse to using a RRF specific slicer - one that is actually tailored specifically to our firmware and which would evolve as the firmware continues to do.
                                  • fmaundefined
                                    fma
                                    Maybe E3D's Pathio, as they chose the Duet for their tool changing machine? But hoping they won't make the same mistakes as Prusa did on Slic3rPE!
                                    Frédéric
                                      deckingman @fma
                                      @fma AFAIK, Pathio is (or will be) another "universal" slicer, which is fine.
                                      I wouldn't necessary say that Prusa have made any mistakes. It's just that it's closely aligned to Prusa's printers and way of doing things - which is fair enough. Nobody has to use it. I guess people choose to use it because they perceive some benefit in some of the features it offers. For me, the price I have to pay if I wanted to use those features is losing functionality in other respects and that functionality is more important than the new "features". So the price I have to pay is too high.
                                      What we need is a Slic3R DE - "Duet Edition" rather than PE which is Prusa Edition.☺
                                      • Red Sand Robotundefined
                                        Red Sand Robot
                                        So I updated to RC5 because I was also having an issue where my mesh grid height map would not display, but RC5 has not fixed this issue either.
                                        The software compensation for printing is still working like a charm, I would just like to see the actual height map so I can tell if my gantry is parallel to my print bed.
                                        almost an engineer
                                        • AlexLinundefined
                                          AlexLin @Red Sand Robot
                                          @red-sand-robot agree I always have to switch back to reprap.html to perform levelling and see the updated mesh.Previously I got 'no file found' but F5 helped... , now it doesn't work at all
                                          I think this such a vital function that it should be fixed before release
                                            chrishamm administrators @kraegar
                                            Fair enough, I'll change that again in RC6.
                                            Yes, that makes sense. I will introduce a new column for the slicer-based estimation. When simulating a file both the slicer-based and simulation-based estimations will be hidden.
                                            @samlogan87 said in Duet Web Control 2.0.0-RC5:
                                            This is more a configuration issue than an issue with DWC - the values it displays are correct so you may want to clear the babystepping in your end G-code.
                                            @Red-Sand-Robot @AlexLin Can you provide your heightmap.csv so I can try to reproduce your problem? I haven't had any issues with it so far. RC6 will also reload the heightmap automatically once 'heightmap.csv' shows up in a G-code response.
