    Dead after using reprap configurator
    710
    • MKR2
      MKR2 last edited by
      Hi all
      I was so stupid not to take a backup before I overwritten the files on the sd card that came with my Duet wifi.
      When I recieved the duet and panelduo 7i I powered it up and the screen was showing splash screen and then the controlpanel.
      The touch screen did not work so I made a new configuration on the reprap configurator and copied the new files to sys folder on sd card.
      Now the screen is blank (black) when I turn the duet on.
      Where can I download the factory files (files in sys folder), i just cant find them anywere?
      • Veti
        Veti last edited by
        you can mount the sd card on your computer and just modify or replace the config files there.
        MKR2 1 Reply Last reply Reply Quote 1
        • MKR2
          MKR2 @Veti last edited by MKR2
          @veti
          Thank you for your reply.
          Can you tell me if the PanelDue need to be activated in the config?
          I can connect to and controll the Duet wifi via my browser but the display is just a black screen.
          • aidar
            aidar last edited by aidar
            PanelDue will show splashscreen and controlpanel even if it is not connected to anything but 5v (for example via USB or 4 wire connector). Assuming Paneldue itself works. You can test it with connecting to USB. If it works that way then its probably connection problem or your Duet doesnt output 5V power.
            When PanelDue is live - i mean its power up but doesnt communicate with duet, then you should check baud rate for both, PanelDue and duet. See also https://duet3d.dozuki.com/Wiki/Gcode#Section_M575_Set_serial_comms_parameters
            • MKR2
              MKR2 @aidar last edited by MKR2
              @aidar
              Thank you, I connected the PanelDue to PC via usb and I can hear it connect but the screen is blank.
              When i push reset on the PanelDue i can hear it reconnect (windows sound).
              The screen was reddish (not white as seen on pictures) the first time I turned it on, so I expect it to be allmost dead on arrival, bummer.
              • aidar
                If it connects to windows, you should check what it is in device manager in windows. Sounds like you could try to reinstall PanelDue firmware.
                https://miscsolutions.wordpress.com/paneldue/ - scroll down there to "Testing the board and updating the firmware" .
                • MKR2
                  @aidar
                  It is shown as 'Bossa Program Port'
                  • aidar
                    That means no main firmware is installed. So follow instruction above and install firmware into PanelDue. As you have PanelDue 7i, you need this file https://github.com/dc42/PanelDueFirmware/releases/download/1.22.1/PanelDue-5.0i-7.0i.bin
                    • MKR2
                      MKR2 last edited by
                      It worked !!
                      Thank You, you have saved my day 🙂
                      One last question, the background color is allmost purple (not white) is that normal?
                      • aidar
                        No, its not normal. Please post picture of it here, best from setup page of PanelDue as it has color palette. If its not normal, then i hope David will tell you what to do next .
                        MKR2 2 Replies Last reply Reply Quote 1
                        • MKR2
                          @aidar
                          Okay, I have placed a piece of white copy paper behind the display to give some kind of 'whitebalance'.
                          MKR2 1 Reply Last reply Reply Quote 0
                          • MKR2
                            MKR2 @MKR2 last edited by MKR2
                            I have found the problem, it is the ribbon cable that is broken (cracked).
                            I will return it.
                            Again, thank you for your help.
                            • MKR2
                              EDIT: I found the forum: https://forum.duet3d.com/category/4/order-discussion
                              "Just recieved an email from E3D.
                              I need an Duet admin on this forum to confirm that the problem is the ribbon cable.
                              Do I have to make a new post some were specifik or maybe send an email to admin?"
                                Is the ribbon cable problem easily visible, and if so, can you post a photo here?
                                • MKR2
                                  MKR2 @dc42 last edited by
                                  Yes, here is a photo.
                                    Yes it does look damaged. I approve a warranty replacement.
