    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    52.7k
    • InSanityundefined
      InSanity
      Let's not forget auto power off of ATX supply after cool down of hot end option. Priorities really are going to vary widely from user to user. #7 for example wouldn't gain me a thing, someone using a delta on the other hand might love it.
      19, 3 ,6, 15, 20, 11, 12, 1
      Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
      • appjawsundefined
        appjaws
        9. Auto-park of motors when power is lost. This will help prevent motors getting out of sync when multiple motors are used to drive a single axis.
        16. Feed-forward temperature control to predict the effect of turning the print cooling fan on or increasing the extrusion rate, and therefore reduce the temperature fluctuation.
        13. Automatic advance of changes in the colour mix when using a mixing hot end. See deckingman's blog.
        3. Logging of various events, including print start/pause/resume/cancel/end, and error messages.
        On a coreXY printer it is very important that the 2 belt tensions are the same. I was wondering if this can be indicated somehow by comparing the power needed to move each of the XY motors and either then relying on the user to mechanically adjust the tension or better still compensate automatically by adjusting the power of the motors, of course this would only be effective if the tensions of the 2 belts were very close in the first place.
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
          @(In)Sanity:
          I've just added that as #19. I also added #20 which I had forgotten about.
            @appjaws:
            Unless one of the belts is over-tight or extremely loose, I don't think it would be possible to use the stall detection to compare the belt tensions.
            Can you devise a test print that would show up any asymmetry in the movement?
            • yngndrwundefined
              yngndrw
              In no particular order:
              2. Better network security
              6. Live monitoring of TMC2660 driver - Including live position updates as they move, rather than just at the end of the move
              12. Better support for CNC machines - I've not tried the Duet with my CNC machine, but from what I've seen there's nothing to handle spindles. It would also be nice to have a little hardware module to convert the PWM output to a 0-10V output for the spindle speed
              20. Ability to control an electronics cooling fan thermostatically
              • Dougal1957undefined
                Dougal1957
                David
                1, 2, 6, 7, 12 is my vote?
                • Simspeedundefined
                  Simspeed
                  5, 4, 9, 7, 13 My four new Z motors arrived so I'll soon be ready to implement #5.
                  Custom C-Beam H-Bot - Hard mount 560mm x 800mm MIC 6 bed plate - 3mm PEI print surface- 120v mains silicone bed heater (3 zones) - 800mm Z axis - polycarbonate enclosure - (4) .09° Nema 23s (Z) - .09° Nema 17s (XY) - Bondtech extruders - E3D Cyclops hotend, 24V power supply
                  • deckingmanundefined
                    deckingman
                    My personal preference would be 1, 13, 16, 17, 20.
                    • 3dprinting meatheadundefined
                      3dprinting meathead
                      5. True bed levelling using 2, 3 or possibly 4 independently-driven Z motors and a Z probe
                      would that square up the x axis to the bed? like for an i3, probe z at left and right, and then move each z motor independently to make the x axis parallel to the points probed?
                      If this question is too off topic, just disregard.
                      If I can learn it, than anyone can learn it.
                      • roboduetundefined
                        roboduet
                        1. WiFi server, specially FTP support. I'm missing it after moving from Duet 0.6
                        3. Logging.
                        7. Dynamic microstepping to switch from x16 interpolated mode.
                        15. Support for 12864 displays.
                        16. Better temperature control
                        XX. Automatic firmware update from web interface (download firmware directly from internet, check md5 or sha hash and update if hashsum is ok). Plus check for updates button in DWC.
                        • tomasfundefined
                          tomasf
                          19
                          20
                          16
                            3dprinting meathead
                            14
                            8
                            in no particular order
                            • hairy_kiwiundefined
                              hairy_kiwi
                              3. Logging… of Temperature values also?
                              15. Support for PanelOne 20x4 text displays, or possibly 12864 mono graphics displays. Especially if useful/required for controlling a machine away from its usual WiFi network?
                              5. True bed levelling... The 2 z-motor solution would be sufficient for my current setup.
                              1. Reworked WiFi server code... Not sure I understand the limitations of the current code base well enough, but anyway.
                              17. Filament and printing time odometers.
                              • Huguesundefined
                                Hugues
                                …And a filament monitor support based from rotary encoder
                                • caphectorundefined
                                  caphector
                                  I'd love to see support for the Prometheus-style multi-filament hot ends as well. Both Prometheus and Prusa have made them. They retract filament when it's not in use and then advance the alternate filament. I think the only big change would be to filament movement distances.
                                  • demonio669undefined
                                    demonio669
                                    • Allow M117 to send message via email
                                    • start and stop printing macros (o allow to send email when the print begins and ends)
                                    • tomwang256undefined
                                      tomwang256
                                      18 - i accidently broke off my usb connector on the paneldue 😞
                                      • windieselundefined
                                        windiesel
                                        19
                                        • T3P3Tonyundefined
                                          T3P3Tony administrators
                                          @caphector:
                                          13, 1, 7, 2, 15
                                          These are already supported. The retraction length can be set either in the slicing software or the tool change gcode.
                                          www.duet3d.com
                                          • pjr3Dundefined
                                            pjr3D
                                            My vote(s):
                                            1 - There is a need to be more tenacious about finding and then keeping a connection where there are many competing wifi routers. It is the most frustrating aspect at the moment especially in the evening when everyone in the area is going online!
                                            7 - Dynamic stepping for my delta …
                                            16 - Better temp control is always good.
                                            18 - This is mostly a convenience but would be handy.
                                            17 - Helps to keep track of usage for maintenance etc.
