    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    50.8k
    • timcurtis67undefined
      timcurtis67
      A nice feature for aligning hotends on IDEX printers would be a G31 hole probe routine. Where you could G31 probe X and Y in positive & negative directions (with multi touch) and then position in the center. Not sure how close the DuetWifi is to running out of resources for adding features but this would be a nice one.
      One could then use a ring type gauge mounted on a piezo disk to pick up the touches. It can be done manually right now but an automatic routine would make life easier.
      Any thoughts on that David?
        @timcurtis67:
        I'm sorry, I don't understand what you mean by a "hole probe routine".
          timcurtis67
          I mean having a steel cylinder with a precision hole bored through it mounted on a Piezo disk. The hole is larger than the hotend nozzle.
          The way the routine would work is you would jog the nozzle roughly over the center of the hole. Then drop enough of the nozzle tip in below the top of the cylinder. Enough so the cone shape would make contact with the inside edge of the cylinder if it were moved in any direction in X or Y.
          Then call up a G31 S-3 (or whatever parameter you choose). The printer would then move in X+ till it reads a contact (just like a Z probe move). When stopped record position, Then move back to start point. Probe in X- until another contact is read. record position position, subtract first stop point from second stop point (X+ pos. - X- pos.) then move to the resulting position. Basically moving the the center of the 2 stops in X.
          Then do the same probes in Y+ & Y-. Do the calculation for y and move to that new center point.
          Repeat X probes to ensure the true center of X again.
          Now if you run the same routine on the second hotend then the difference in positions between the two hotends is what would get entered in G10 X Y for the second tool.
          Does that make sense?
          • BPisLifeundefined
            BPisLife
            • MitchDundefined
              MitchD
              Would it be possible to make the Paneldue play a tune when the print finishes? This just makes the whole experience a bit more friendly, especially when we show off the printers at maker faires etc.
              dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
              • Quadcellsundefined
                Quadcells
                17
                1
                Thanks
                /quadcells
                  dc42 administrators @MitchD
                  @mitchd said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                  I think it should already be possible, using a combination of M300 and G4.
                  DADIYundefined 1 Reply Last reply Reply Quote 0
                  • audryhomeundefined
                    audryhome @dc42
                    @dc42 Implement G29 T1 tag to list the height table, this makes it possible to communicate with Bed Level Visualizer
                    see https://plugins.octoprint.org/plugins/bedlevelvisualizer/ for info.
                    All Octoprint users will love this I guess.
                    Low priority since this exists in the DUET GUI as a workaround.
                    • rhkleinundefined
                      rhklein
                      Didn't I read somewhere that it is already implemented or was it a wishlist too? (firmware not Deckingmans script)
                      • DADIYundefined
                        DADIY @dc42
                        @dc42 This is already possible, I have the following in my end gcode -
                        ;Play beep beep beep to show print ended.
                        M300 P500 S5000
                        G4 P400
                        M300 P500 S5000
                        G4 P400
                        M300 P500 S5000
                        G4 P400
                        M300 P500 S5000
                          Phaedrux Moderator @MitchD
                          @mitchd If you're looking for a little jingle when a print is finished and not just a beep, try this one:
                          ; Play a triumphant tune to celebrate a successful print.
                          M400			; Clear queue before jingle
                          G4 S1
                          M300 P250 S750
                          G4 P251
                          M300 P200 S1250
                          G4 P201
                          M300 P250 S750
                          G4 P251
                          M300 P200 S1250
                          G4 P201
                          M300 P250 S2500
                          G4 P251
                          M300 P150 S2000
                          G4 P151
                          M300 P150 S2500
                          G4 P151
                          M300 P350 S3700
                          G4 P351
                          M400
                          jnolan72undefined 1 Reply Last reply Reply Quote 0
                          • jnolan72undefined
                            jnolan72 @Phaedrux
                            That is too cool
                            @phaedrux said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                            G4 S1
                            M300 P250 S750
                            G4 P251
                            M300 P200 S1250
                            G4 P201
                            M300 P250 S750
                            G4 P251
                            M300 P200 S1250
                            G4 P201
                            M300 P250 S2500
                            G4 P251
                            M300 P150 S2000
                            G4 P151
                            M300 P150 S2500
                            G4 P151
                            M300 P350 S3700
                            G4 P351
                            M400
                              Phaedrux Moderator @jnolan72
                              @jnolan72 If you like that one I have another one for printer start up and another for right before the print starts.
                              I've tried to program more complex tunes but the more commands you send the more likely the system is to miss a tone or stutter. The buffer can only handle so much I guess. Hence having to issue an M400 before and after. This is more noticeable at printer startup than it is say before or after a print.
                              ; Startup Tune. Placed at the end of config.g
                              M400
                              G4 S2
                              M300 P200 S2000
                              G4 P201
                              M300 P200 S2250
                              G4 P201
                              M300 P200 S2000
                              G4 P201
                              M300 P200 S2855
                              G4 P201
                              M300 P200 S2500
                              G4 P201
                              M300 P200 S2200
                              G4 P201
                              M300 P200 S2500
                              G4 P201
                              M300 P200 S2900
                              G4 P201
                              M300 P300 S3500
                              G4 S1
                              M400
                              ; Lucky tune to start print off on the right foot. Placed in slicer start g-code.
                              M300 P200 S1000
                              G4 P201
                              M300 P200 S1250
                              G4 P201
                              M300 P200 S1100
                              G4 P201
                              M300 P200 S2000
                              G4 P201
                              M300 P200 S1500
                              G4 P201
                              M300 P200 S1000
                              G4 P201
                              M300 P200 S1300
                              G4 P201
                              M300 P200 S1000
                              G4 P201
                              M300 P300 S1500
                              G4 S1
                              M400
                              • mgrimes1907undefined
                                mgrimes1907
                                • Coffeeundefined
                                  Coffee
                                  Thanks guys for the beeps and tunes! My old Creatbot beeps and I was missing that on this new build.
                                  Phaedruxundefined 1 Reply Last reply Reply Quote 1
                                    Phaedrux Moderator @Coffee
                                    @coffee Last one... Inspired by my Roomba
                                    ; Charge.g
                                    ; Duh nuh nun nah nah naah Charge!
                                    M400
                                    G4 S1
                                    M300 P295 S520
                                    G4 P295
                                    M300 P250 S650
                                    G4 P250
                                    M300 P250 S750
                                    G4 P250
                                    M300 P285 S850
                                    G4 P450
                                    M300 P285 S850
                                    G4 P285
                                    M300 P625 S1100
                                    G4 S1
                                    M400
                                    Coffeeundefined 1 Reply Last reply Reply Quote 0
                                    • SnowCrashundefined
                                      SnowCrash
                                      If this is still relevant, these are my picks:
                                      1
                                      20
                                      Thanks!
                                      • Coffeeundefined
                                        Coffee @Phaedrux
                                        @phaedrux THANKS !!!
                                        • resamundefined
                                          resam
                                          @SnowCrash did you follow all the recent Firmware releases?
                                          As far as I can tall, all the picks you listed are already implemented to some degree.
                                          @dc42 as this threads continues to grow and grow, I would recommend closing it, and opening a fresh one after 2.0 and 1.21.1 is released.
                                          SnowCrashundefined 1 Reply Last reply Reply Quote 1
                                            SnowCrash @resam
                                            @resam said in Firmware wishlist and priorities for Duet WiFi and Duet Ethernet:
                                            Thanks @resam! That's great news 🙂
                                            To your question, I haven't been following the recent firmware releases for the simple reason that I only got my DuetWifi a short while ago and it already had the latest firmware already installed.
                                            However, I'm definitely planning on doing so in the future.
