    lines in the printed parts
    617
    • JV
      JV last edited by
      Hello everyone
      I have a little problem with my printed parts.
      there are some lines in the perimeter of my printed parts.
      I would to know if that depends of the slicer (3d simplify) or may be depends about the hardware.
      I have servomotors with encoders so i don't think that is a problem about them.
      My outline printer speed (perimeter) is very slow (35 mm/s) and the curious thing is that the lines came out in a layer and after that desapear and came out later in other layer
      in some printed parts came out very often and in other parts less.
      As you can see in the foto a curious thing is that the lines came out in diferent zones in the same layer.
      depends may be about the nozzle clog in that moment??
      thanks guys
      • Martin1454
        Martin1454 last edited by
        Could look like a clog, how is your retraction settings? - Or maybe a temperature instability - Have you looked at your temperature graph while it prints?
        • JV
          JV last edited by
          Hi Martin
          I use a Dyze extruder Pro Kit
          The extruder builder gives a retraction speed parameter between 25 and 35mm/s and a retraction distance between 0,5 and 2mm
          My settings:
          Retraction distance 1,4
          retraction speed 35mm/s
          I have an acceleration M201 800mm/s2... Maybe is too high?
          The temperature looks very stable
          Martin1454 1 Reply Last reply Reply Quote 0
          • Martin1454
            Martin1454 @JV last edited by
            @jv said in lines in the printed parts:
            Hi Martin
            My settings:
            Those values looks just fine - normally when you go above 2.5mm retraction that clogging starts happening at retraction.
            Can you hear stepper skipping steps when it happens, or does the nozzle just not extrude material at that point?
            JV 1 Reply Last reply Reply Quote 0
            • JV
              JV @Martin1454 last edited by
              @martin1454
              i send the print program last night and i wasn't near to the macchine in that moment.
              i will clean the noozle using the cold pull procedure to exclude clogging.
              i will keep you updated,i think that the clogging, can be the problem.
              Thank you very much for your help
              • Veti
                Veti last edited by
                Check the dimension of your filament. i had a filament where for a small section it went down to 1.6mm which causes artefacts.
                also check that the slicer actualy has a layer there. i had curious results in cura where an entire layer was missing. the resulting print had similar artefacts like the red circles ones.
                • Stephen6309
                  Stephen6309 last edited by
                  Chack your filament coming off the reel, I get those layers when the filament jams up on the reel.
                    Looks kind of like an underrun after a long travel move. How fast are you traveling?
                    • JV
                      JV @Veti last edited by
                      HI @veti
                      I'll check the diameter of the material but at the moment i saw that in some cases i have diference of diameter with maximun +- 0.02mm.
                      If an entire layer missing, i think is a huge problem, i check the simulation and there are no missing layers.
                      I did a very thorough check and i saw that there is no less material, but looks like the layer was moved 0.3mm back in the Y axes and the next layer was ok
                      • JV
                        JV @Phaedrux last edited by
                        Hi @phaedrux
                        In the positioning moving speed parameter i have 60000mm/s
                        but i have servomotors so the positioning must be perfect and the distance between the most distance points is relative short.
                        • JV
                          JV @Stephen6309 last edited by
                          Hi @stephen6309
                          Interesting, i'm using a 30 euro/Kg material, is not the most espensive material but i think is not cheap so i hope that the spool doesn't have this kind of problems, i'll chek that .
                          I saw that the extruder that i'm using ( Dyze Extruder) had a high pushing force (9kg) with their traction system so i think that is enough to pull the filament if it jams up on the reel
                          • Edgars Batna
                            Edgars Batna last edited by Edgars Batna
                            I get this sort of stuff when I enable pressure advance and I too have a setup with a rather large pushing force and just about moderate retraction. What are your extruder steps/mm and PA, if any?
                            If you print the same gcode twice, do you get the lines at exactly the same spot?
                            • JV
                              JV last edited by
                              Hi @edgars-batna
                              I disactivate the pressure advance because i had problems after i change the extruder.
                              this part is too big to do it twice😌
                              when i'll have the same problem with a little part, i will do the test.
                              Thanks
