    BLTouch V3.0 Information, Setup, and O'Scope Pictures
    27
    4.3k
    • Vetiundefined
      Veti
      @pipersw said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
      Logic voltage Free Zmin
      if the duet works best with 5v logic and the ramps boards also need 5v, what is the point of the new default?
      • piperswundefined
        pipersw
        The Duet is 3.3V input, but the input allow up to 30V for input because internal diodes clamp to 3.3V.
        But it's more clean to output 3.3V signal from the BLtouch I think, because it's the native voltage.
        Just add a pull-up resistor to 3.3V.
        • zaptaundefined
          zapta @JadonM
          The first waveform seems to have ac coupling. I presume that the oscilloscope was set to DC coupling.
          https://forum.duet3d.com/assets/uploads/files/1554913522808-homing-logic-free.jpg
          JadonMundefined 1 Reply Last reply Reply Quote 0
          • JadonMundefined
            JadonM @zapta
            @zapta said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
            All the measurements were done with DC coupling. I'm thinking the weird waveform might be the result of no pull-up resistor, as referred to by @pipersw.
            I've done some more measurements, this time with the BLTouch's output connected to the board and o'scope. Before I had it connected to the o'scope alone. This yielded much different results. Does the Duet Maestro have a built-in pull-up resistor?
            Above is with the output connected to the board in "Logic Free" mode. This waveform looks much more sensible and is at around 3V, not the previous 1V when it was unconnected.
            This is with the BLTouch in the 5V Logic Mode, but to my suprise, it seems to only show about 3V. Is that because of the clamping diodes, @pipersw?
            zaptaundefined piperswundefined 2 Replies Last reply Reply Quote 0
            • zaptaundefined
              zapta @JadonM
              @jadonm said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
              Not an expert, but it may be this: https://i.imgur.com/jPdCPKm.png
              From second page of this PDF https://github.com/T3P3/Duet/blob/master/Duet2/Duet2Maestro_v1.0/Duet2Maestro_Schematic_v1.0.pdf
                The Z probe input of the Maestro has an internal pull up resistor inside the microcontroller, value about 100K. I am fairly sure that it is enabled when you select BLTouch probe mode, but I will check.
                piperswundefined 1 Reply Last reply Reply Quote 0
                • piperswundefined
                  pipersw @JadonM
                  @jadonm Yes, it's the clamping diode whose stuck at 3.3V.
                  • piperswundefined
                    pipersw @dc42
                    @dc42 said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
                    On schematic of Maestro, there is a external 10k pull-up, so the internal pull-up of the processor is don't care if enabled or not, because it's around 10k in all case.
                      dc42 administrators @pipersw
                      If you mean R62, that's a 10K series resistor, not a pullup resistor.
                      I have confirmed that the internal pullup resistor is enabled when BLTouch mode is selected.
                      • piperswundefined
                        pipersw @dc42
                        @dc42 No, if I take the picture https://i.imgur.com/jPdCPKm.png, I mean R70.
                          That's the Z endstop connector, not the Z probe connector.
                          • piperswundefined
                            pipersw
                            you are right !
                            • cabal2000undefined
                              cabal2000
                              I have a V3 bltouch installed as per setup guide for the Maestro. When I turn on the board to BL blinks with an error, I have to turn the board off and on several times before it will do a self test. No resistor is used.
                              zaptaundefined JamesMundefined 2 Replies Last reply Reply Quote 0
                              • zaptaundefined
                                zapta @cabal2000
                                @cabal2000, was the bed too close to the nozzle when you turn it on? If the BLT doesn't have sufficient mechanical clearance on power up, it enters an error state and blinks. I added to my homeall script a BLT error reset command I found in one of the threads here.
                                M280 P3 S160 I1
                                cabal2000undefined 1 Reply Last reply Reply Quote 0
                                • JamesMundefined
                                  JamesM @cabal2000
                                  @cabal2000 My newest BLTouch does the same thing for me but it will work after turning the printer off and back on once.
                                    cabal2000 @zapta
                                    @zapta Nozzle is no where close to the bed, pin is free. But I will be adding the reset command. Thanks man
                                    • jaurandundefined
                                      jaurand
                                      @JadonM Would you be able to share which pins you are using for your setup? I am having some odd issues and want to try to emulate your setup.
                                      • JadonMundefined
                                        JadonM @jaurand
                                        @jaurand said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
                                        Absolutely! I would love to have some novel wiring scheme that would solve all your problems, but unfortunately, I've just followed the wiki! 🙂 I have the Maestro, which takes different wiring than the Wifi, Ethernet, or Duet3.
                                        My wiring is all on the Z-probe connector and consists of:
                                        BLTouch Out - Maestro In
                                        GND - GND
                                        Control - MOD
                                        5V - 5V
                                        Hopefully that is a help to you, and feel free to ask me any other questions you have!
                                        • jaurandundefined
                                          jaurand
                                          @JadonM Thank you for the o'scope images
                                          I followed this setup https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/ for duet wifi and am unsure about the pins to use for bltouch error reset and 5V logic mode for the duet wifi
                                          I keep getting a flashing red duty cycle and when i run mesh bed it runs for a bit then the probe stays in the up position.
                                          • JadonMundefined
                                            JadonM @jaurand
                                            I'm sorry, but I don't think I know enough about the Duet and BLTouch to answer your question. I would recommend making a new thread with all the details and one of the much more knowledgeable regulars can help you.
                                            Sorry that I can't help you!
