    Duet Ethernet with 24v fan
    fan0 cooling duet3d ethernet
    3.2k
    • Bewarenundefined
      Bewaren
      Just tested it, doesnt seem too no. Do I need to take off one of the jumpers??
      • Bewarenundefined
        Bewaren @Phaedrux
        @phaedrux Tested the heatsink cooler fan on all connectors and it works on them, so unsure if the issue is the voltage for the print fan
          See the link above about connecting fans. It Explains.
            Are you sure the fan is 24v?
            If it doesn't work on the always on port it may be dead.
            Bewarenundefined 3 Replies Last reply Reply Quote 0
            • Bewarenundefined
              Bewaren @Phaedrux
              @phaedrux 24V DC fan, 2 pin output, wired up correctly, very confused as to what the issue could be now, the link shows how to use a 12v fan on a 24v output as far as I can tell, but I am very new to the technical terms used so may be misinterpreting it.
              • Bewarenundefined
                Bewaren @Phaedrux
                @phaedrux Tried 3 different fans now, none of them worked, ideas?
                • Bewarenundefined
                  Bewaren @Phaedrux
                  @phaedrux one thing I have noticed is the hotend cooling fan on the heat sink is in fact 12v and does function correctly but seems to be running faster than anticipated, when powered via 12v it is significantly slower than the current setup, so I am assuming it is a 24v output from the board however unsure as to how this is happening as I would imagine it would break the fan
                    Phaedrux Moderator @Bewaren
                    @bewaren said in Duet Ethernet with 24v fan:
                    You need a buck converter to supply a 12v line into the v_fan jumper pin. But then all your fans need to be 12v.
                    If you have some 24v and some 12v you're going to have some issues. The hotend fan is being over volted and while it is working now it's likely to burn out when you least want it to happen.
                    Make sure the fans are all the same voltage and supply them with the correct voltage. It's as simple as that.
                    Bewarenundefined 1 Reply Last reply Reply Quote 0
                    • Bewarenundefined
                      Bewaren @Phaedrux
                      @phaedrux Alright ill order a 24v fan for the hotend heatsink to solve that issue then, so any idea on what else I could try to get the print fan working?, it's 24v, I've tried 3 of them now with no luck on the always on pins and the fan0 to fan2 pins, I'm certain it isn't the fans them selves, the pins work fine when I try power the 12v fan but they over voltage the fan, however the 24v fan simply doesn't do anything. Suggestions?
                      Phaedruxundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                        Suggestions?
                        What exactly is your M106 fan command in config.g right now?
                        If you send M106 P0 S1 H-1 in the gcode console does it turn on?
                          deckingman @Bewaren
                          @bewaren You also need to have tool selected. The easiest way to do that is to add T0 to the end of your config.g file.
                          dc42undefined Bewarenundefined 2 Replies Last reply Reply Quote 0
                            dc42 administrators @deckingman
                            @deckingman said in Duet Ethernet with 24v fan:
                            If the print cooling fan is connected to the Fan0 output, you don't need to select a tool to run it.
                            @Bewaren, does the fan run if you connect it to an always-on fan output?
                            M106 P0 S0.1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            That line in config.g was wrong. The H without a number after it will be interpreted as H0. Remove the H, or change it to H-1.
                            • Bewarenundefined
                              Bewaren @Phaedrux
                              @phaedrux M106 P0 S0 I0 F500 H-1 this is my current fan command
                              • Bewarenundefined
                                Bewaren @deckingman
                                @deckingman Tool is selected yes, still nothing though
                                • Bewarenundefined
                                  Bewaren @dc42
                                  @dc42 M106 P0 S0 I0 F500 H-1 is the line now, still no luck, it also doesn't work even when connected to the always-on fan outputs, but I have tried 3 different fans, all brand new, very unlikely all 3 are faulty.
                                  • Bewarenundefined
                                    Bewaren
                                    @phaedrux Tried sending M106 P0 S1 H-1, it did nothing
                                    • Bewarenundefined
                                      Bewaren
                                      Tried another pack of 24v fans and a 12v fan, 12v fan was over voltaged but worked, 24v fans did nothing, is there somewhere I have to define that the fans I am using are 24v?
                                      Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                        @bewaren it really seems like the 24v fans are dead.
                                        Can you setup a test with just power from the 24v PSU directly to the fans to remove the duet completely from the equation?
                                        If the 12v fans work but the 24v don't then it must be the 24v fan that isn't working. You can carefully measure the voltage on the fan pins to verify.
                                          dc42 administrators @Bewaren
                                          Tried another pack of 24v fans and a 12v fan, 12v fan was over voltage but worked, 24v fans did nothing, is there somewhere I have to define that the fans I am using are 24v?
                                          Are you sure that you have the VFAN jumper set to VIN, not to 5V?
                                          • Bewarenundefined
                                            Bewaren @dc42
                                            @dc42 I am unsure, what pins should I have the jumper on?, its currently on the two right hand pins if looking at it from: https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/YN2oahyGpcPNN1Pw.huge | assuming that the jumper in question is the 3 pin one central to the 5 fan pins.
