    Duet 3 Mainboard 6HC - initial production run.
    243
    33.7k
    • fotomasundefined
      fotomas @dc42
      I am probably slow here but I have read the hardware overview and it is not clear if a Raspnerry Pi I needed to use the web interface?
      Has the duet 3 network.connectivity on it's own, wired or wireless?
      The hardware overview states the following, and what is referred as "It" marked in bold? The duet 3 or a Raspbeery Pi.
      The Duet 3 mainboard has a dedicated high speed SPI bus to a single board computer (SBC). The reference implementation is a Raspberry Pi 3B or newer. The SBC provides the user interface (via a browser based control application called Duet Web Control, or a third party application). It also provides a network interface via the local network or VPN depending on how it is configured.
        T3P3Tony administrators @fotomas
        @fotomas The Ethernet network interface is mainly there for future support for EtherCat. and also for people who it does not make sense to use a SBC (like the OEMs that David mentioned that have multiple Duets controlled directly from a single computer). It would be possible to use the Duet 3 without a SBC, and just use the Network interface (assuming the uSD card holder is populated), but we are not recommending it because you loose out on all the development we are planning for the SBC (e.g better UI performance, better networking and plugins).
        fotomasundefined 1 Reply Last reply Reply Quote 1
        • fotomasundefined
          fotomas @T3P3Tony
          @t3p3tony thank you.
          • martinkundefined
            martink
            Is it possible to power the MCU from EXT 5V (to allow it to shut off motors and heaters by turning off the 24V PSU), or has that been replaced by the SBC->5V setup?
            • wilrikerundefined
              wilriker @martink
              @martink said in Duet 3 Mainboard 6HC - initial production run.:
              That's still possible.
              Manuel
              My Tool Collection
              martinkundefined 1 Reply Last reply Reply Quote 0
              • martinkundefined
                martink @wilriker
                @wilriker Great, thanks for confirming!
                • Knaudlerundefined
                  Knaudler
                  screws for Power ?
                  something like this would be nice:
                  https://www.wago.com/de/leiterplattenanschluss/klemmenleiste-fuer-leiterplatten/p/2716-102
                  DocTruckerundefined dc42undefined 2 Replies Last reply Reply Quote 1
                  • DocTruckerundefined
                    DocTrucker @Knaudler
                    @knaudler Potential cost issues apart these are better. No loosening issues as the springs keep the correct loading on the contacts.
                    • LeonMFundefined
                      LeonMF
                      I've already bought my board (looking forward to it!). I totally didn't even read the specs before buying so I'm now catching up on the whole SBC thing. 🙂
                      So, with the new SBC interface, does that mean that the PanelDue is deprecated? Is/will there be another touchscreen replacement to fill the gap?
                      Also, is there any reason to avoid or go for a Pi 4 over the 3+?
                      Current: Railcore II ZLT w/Duet 3 and Hemera hot end.
                      Retired: Robo3D R1,BI V2.5 Delta updated to BerryBot magnets, bespoke carriages and Duet Ethernet, M3D Promega;
                      Phaedruxundefined wilrikerundefined T3P3Tonyundefined JoergS5undefined 4 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @LeonMF
                        @leonmf said in Duet 3 Mainboard 6HC - initial production run.:
                        I just got my hands on a 2Gb Pi 4 and I'm quite pleased with it. The biggest improvement IMO is the change to the ethernet and USB ports. In the Pi 4 you get actual gigabit ethernet speeds and actual USB3 speeds, whereas with the Pi3b+ the ethernet port was hung off the USB hub and shared their limited USB2 bandwidth. It made certain i/o tasks painful.
                        The big CPU upgrade is nice as well as the added ram. I doubt that will really become critical for running the duet, but given the minor cost disparity, I would say that the Pi 4 will have more longevity, especially if you ever wanted to repurpose it.
                        • wilrikerundefined
                          wilriker @LeonMF
                          @leonmf In addition to what @Phaedrux said the requirements have been changed to "RPi 3B or newer" which of course also includes the latest RPi 4B. Maybe the product page has not been updated after that change.
                          This originally simply was because at the time prototyping tests began RPi 3B+ was the most recent version.
                          Manuel
                          My Tool Collection
                            T3P3Tony administrators @LeonMF
                            @leonmf in addition to the good points about Raspberry pi versions already made, regarding the screen: The idea is that there are a multitude of HDMI and direct interface touch screen available for Raspberry Pi so you have much more choice. at the simplest level you can have DWC running on the touch screen in a maximised browser but i am sure there will be a range of UI options developed to suite different screen and requirements. The advantage of doing this on the SBC is its much easier to make UI changes than on the PanelDue.
                            • LeonMFundefined
                              LeonMF
                              Thanks everyone!
                              @T3P3Tony I had this argument with the M3D team when they argued that the PanelDue was a waste of time. 🙂
                              The PanelDue is certainly limited in what it does and how it operates but that's part of the benefit. Fundamentally, it just works and the M3D argument of buying a cheap tablet and using it as a UI completely missed the point that you just need the ability to poke a jog or home button without the drama of maybe the tablet went to sleep or the UI wasn't built for touch.
                              But... if you're saying that there will likely be a touch friendly UI that works with the SBC and the SBC being operational is required for the unit then I likely have little to complain about!
                              • LeonMFundefined
                                LeonMF
                                Posted in a separate comment for clarity.
                                Some time ago, I used to run my home automation system on Raspberry Pi. Then, after that, I ran my home audio on Raspberry Pis. They did work pretty well but were more prone to corruption than I'd like.
                                The beauty of an embedded board like the Duet 2 is that powering it down and back up meant that it was still going to come back up fine.
                                My experience with Raspberry Pis were that they are a full OS and don't particularly love being shut down without going through a clean shutdown. Something that a device with an off-switch isn't all that great for. Perhaps my early experiences with Raspberry Pis reflect a fear about dirty shutdown corruption that isn't a reality any more. Do I have any reason to be concerned on this or are my fears several years out of date?
                                Phaedruxundefined JoergS5undefined Danalundefined 3 Replies Last reply Reply Quote 2
                                • minimundefined
                                  minim
                                  It will be fun to see the improvement but I don't fancy the idea of a SBC at all. I kinda need it for the stepper drivers on nema 23s.. Time will tell if SBC was the correct decision I guess 🙂
                                    A Former User
                                    I was actually thinking about that the other day, most of the issues can be mitigated by having the system run with the majority of the operating system as read-only under normal operations. I don't know what is planned, but it quite doable to make the Duet 3 image fairly resilient with respect to unexcpected shutdowns.
                                      I may be lucky, but I have never shut down a pi cleanly. Always just pulled the power on the poor little things. Never had any ill effects.
                                      DocTruckerundefined 1 Reply Last reply Reply Quote 1
                                        DocTrucker @Phaedrux
                                        @phaedrux think this is more like to be a problem if the DWC solution on the computer does some heavy background processing like simulation.
                                        • JoergS5undefined
                                          JoergS5 @LeonMF
                                          @leonmf so maybe it's better to setup the operating system as read-only, similar to http://hallard.me/raspberry-pi-read-only/
                                          and held the non volatile data in a separate storage.
                                            Good points. One way to go is to have the power configured so the Raspi does not shut down, or at least is in charge of the shutdown. So power off just sets the printer into a low power sleep mode where the 24V is off and only a little 5V is used to keep the Pi idling... When you turn a modern TV or whatever that is what happens...
