    Non planar layers
    55
    3.9k
      A Former User @peirof
      @peirof
      Cant remember, i will try to find the article again, i read it last night on one of the 3d printing blogs.
      • sinned6915undefined
        sinned6915
        and how different is this than a hexapod with 5 axis?
        sounds like someone is trying to patent the ESC key again
        • fmaundefined
          fma @A Former User
          @calvinx said in Non planar layers:
          There is a possible issue of this already having being patented by another company which might stop it being used freely............
          Are you sure this will stop us for non commercial use?
          Frédéric
          • JoergS5undefined
            JoergS5 @fma
            @fma I had the same idea, and a question: how about building a DIY 3D printer with patented technology and then printing and selling 3D printed parts in a shop. Is this allowed?
            • fmaundefined
              fma
              Good question ; I don't know...
              Frédéric
                A Former User
                Hi
                I found the Article.
                Possible patent infringement
                peirofundefined 1 Reply Last reply Reply Quote 1
                • peirofundefined
                  peirof @A Former User
                  @calvinx broken link?
                  Scachiundefined 1 Reply Last reply Reply Quote 0
                  • fmaundefined
                    fma
                    No, the link works fine...
                    Frédéric
                    • Scachiundefined
                      Scachi @peirof
                      @peirof works for me
                      • JoergS5undefined
                        JoergS5
                        I am not a lawyer, but I looked into the patend and saw it was abandoned in 2015, and there is an article https://smallbusiness.chron.com/patents-abandoned-65186.html explaining when a patent was abandoned, it can be used. A commecial produced product between abondent and new status active needs not to pay fees. 0_1567574389685_abandoned.jpg But as I said, I have little patent knowledge.
                          A Former User @JoergS5
                          @joergs5
                          good info but strange that the patent was only applied for in 2015 by auto desk.
                          further investigation is required I think.
                          • fmaundefined
                            fma
                            But AFAIK, a patent only prevents commercial use of something; I don't think it forbids someone to develop free sofware for personal use...
                            But I don't know if it is a problem for a university. It could also be a problem if Prusa Research implements something patented in their Slic3r fork...
                            Frédéric
                            • Vetiundefined
                              Veti
                              This post is deleted!
                                droftarts administrators
                                I don't know the status of the Autodesk patent, but there is at least some prior art in 3D printing:
                                Some other prior art to the March 2015 Autodesk patent, specifically 3D printing:
                                April 2013 - https://www.thingiverse.com/thing:75735
                                July 2016 - Hackaday article https://hackaday.com/2016/07/27/3d-printering-non-planar-layer-fdm/
                                Nov 2014 - Comment in Hackaday article https://hackaday.com/2016/07/27/3d-printering-non-planar-layer-fdm/#comment-3105340 leads to https://github.com/nick-parker/Bread first commit in github was Nov 2014.
                                • fmaundefined
                                  fma
                                  Note that 2 of these links are not the same technic: they just distort a part, and can't slice a non planar part...
                                  I plan to give a try to Bread.
                                  Frédéric
                                  • JoergS5undefined
                                    JoergS5
                                    An additional option and innovation to non planar printing: a nozzle which can rotate in all three axes so that the edges of the nozzle do not disturb the non-planar printing and the nozzle can be closer to the layer. Nozzle direction and hereby filament flowout of the nozzle is freely controllable.
                                    droftartsundefined NitroFreakundefined 2 Replies Last reply Reply Quote 0
                                      droftarts administrators @JoergS5
                                      @joergs5 Nozzle only needs to tilt in two axes (doesn't need to rotate), and it can be the bed that tilts, rather than the nozzle. Moving the nozzle in more than 3 axes (though think milling bit) is common in CNC milling machines, and more recently water jet and laser cutting.
                                      • JoergS5undefined
                                        JoergS5 @droftarts
                                        @droftarts well, yes, I thought of the possibility of concrete printing where the direction of the nozzle is important (and a nozzle where a Kevlar wire precedes the print). And I thought of printing walls and later the infill with a flexible nozzle also.
                                        • NitroFreakundefined
                                          NitroFreak @JoergS5
                                          @joergs5 said in Non planar layers:
                                          Before someone protects it by a patent, an additional option and innovation to non planar printing:
                                          The nozzle can be swivelled in all three axes so that the edges of the nozzle do not disturb the printing during non-planar printing and the nozzle can be closer to the layer. The controller controls the tilt of the nozzle. Nozzle direction and hereby filament flowout of the nozzle is freely controllable.
                                          Don´t get on the high horse, this type of 5 axis printing is already patented.
                                          https://patents.google.com/patent/US20190210286A1/en?q=multiple&q=axis&q=robotic&q=additive&oq=multiple+axis+robotic+additive
                                          By the way, you cannot patent a possibility or "can be", you can only patent the execution of that idea. More simply. it´s not WHAT is done, it´s HOW it´s done that´s patentable.
                                          Simple example: you cannot patent the process of boiling water, but you can patent HOW the water is boiled, for example you invented a water boiler that does this by using fusion energy. you would have to describe in detail how the fusion energy ends up in the water, and THEN you can patent it.
                                          • JoergS5undefined
                                            JoergS5 @NitroFreak
                                            @nitrofreak Thank you for explaining the patent process and the existing patent. The patent is not applicable, it is a process for preheating. But your information about what is patentable was useful, thank you.
