    Duet 3 Mainboard 6HC - initial production run.
    243
    32.8k
    • whosrdaddyundefined
      whosrdaddy
      @dc42 , I currently have poor wifi connectivity to one of my duets (signal is great but my laptop gets around 50Mbit in the same place as the printer). I am acquiring a RPi4 next week, would it be feasible to hook it up to a Duet 2 Wifi? (I suppose I need to remove the wifi module?). And as I understand it, DSF only supports Duet 3 but it will support Duet 2 in the future, right?
        dc42 administrators @whosrdaddy
        @whosrdaddy, did you mean "signal is not great"? If so, and you are capable of removing the WiFi module without damaging the PCB, then your best option is probably to replace the WiFi module by the ESP-07S version and external antenna.
        There is no firmware build for Duet 2+RPi yet, and it will be at least a month before I can consider doing one.
        • mundsenundefined
          mundsen
          Planning my Duet 3 setup. Can Duet 3 power an rpi4 + 7 inch LCD + USB camera ++ ?
          TLASundefined 1 Reply Last reply Reply Quote 0
            A Former User @dc42
            @dc42 said in Duet 3 Mainboard 6HC - initial production run.:
            ESP-07S
            Thats the 4MB flash version, is that a requirement for the upgrade? Might be worth highlighting that
            • TLASundefined
              TLAS @mundsen
              @mundsen
              You could probably do the math by finding the amp usage of each component. WhenI ran it to determine the maximum number of LEDs I could drive while using a 7ā€ screen and it came out to about 10 when considering the load of the PI + LCD screen. I’m going to use an external power source for the PI (and connected components), and leave the PI in always-on mode. Then have a separate power button to boot up the Duet 3 and the rest of the system.
                A Former User @TLAS
                @tlas I've got my 24V supply in series with a mains relay hooked up to a unused GPIO pin on the Pi, so the Pi can turn on/off the Duet 3. One day I'll throw together a systemd script to handle it with dependencies to DuetSoftwareFramework.
                (Both the 24V and USB supply are also hooked up to a Wifi controlled socket so both can turned completely off from HomeAssistant:)
                • mundsenundefined
                  mundsen
                  My Duet 3 order have status = Completed
                  Does completed indicate that it has been shipped?
                  There is no tracking info
                    T3P3Tony administrators @mundsen
                    @mundsen nope, shipping will start soon (this week!) The shop software is a bit poor for pre-orders
                    mundsenundefined 1 Reply Last reply Reply Quote 0
                    • mundsenundefined
                      mundsen @T3P3Tony
                      @T3P3Tony so the first Duet 3 are fine ? Exited 😊
                      • Dougal1957undefined
                        Dougal1957
                        Tony Can you say if a connector kit will be included and also a cable for the SBC or do we need to source our own beforehand? if we do can you list what we need to obtain.
                        Doug
                          T3P3Tony administrators @Dougal1957
                          @Dougal1957 Connectors and a 26way to 40 way cable for the SBC (compatible with a Raspberry Pi 3 & 4) will be provided.
                          Also a SD card with the default image with DuetSoftwareFramework etc installed on it.
                          Dougal1957undefined TLASundefined 2 Replies Last reply Reply Quote 5
                            Dougal1957 @T3P3Tony
                            @T3P3Tony said in Duet 3 Mainboard 6HC - initial production run.:
                            Cheers for that
                            • TLASundefined
                              TLAS @T3P3Tony
                              @T3P3Tony
                              Kind of curious why the Duet stayed with the 40 pin connector instead of matching the 26? Was this to enable backwards functionality if used without a SBC? Enable custom expansion? Just too many 40 pin connects on hand?
                                A Former User @TLAS
                                @TLAS said in Duet 3 Mainboard 6HC - initial production run.:
                                I think you'll find its the other way around, the connector was reduced from 40 to 26 presumably to save board space.
                                (iircc the old duet 2 expansion is 50 pin(?), the new only needs 5 signals + ground and potentially 5v if so configured. however earlier raspberry boards aslo use a 26 pin connector, could be related)
                                  Dougal1957
                                  yep the Duet has the 26 and the pi is 40
                                  • JoergS5undefined
                                    JoergS5
                                    Aug 10th were some comments in this thread about to use other cables if necessary.
                                    • gtj0undefined
                                      gtj0
                                      @T3P3Tony Can we still use the link in the first post to order even though there might not be any available from the first run?
                                        T3P3Tony administrators @gtj0
                                        @gtj0 now just yet. I want to be able to say when the next batc will be available first
                                          Dougal1957
                                          Tony is there any chance any more from this first batch will become available I know at least one guy who is desperate to jump on the band waggon. I seem to remember you saying you had kept some back to allow for failures during testing
                                          Doug
                                          • PastThePointundefined
                                            PastThePoint
                                            I suppose there is no way to be notified when some stock is available? I have cash in hand for a D3 Mainboard, but missed the pre-order. I don't want to miss the chance to purchase on because I didn't check the website at the right time. So Doug told me to post a comment here as well.
                                            Looking forward to this!
