    Think its broken...
    1.4k
    • Shaunundefined
      Shaun @Phaedrux
      @Phaedrux said in Think its broken...:
      @Shaun said in Think its broken...:
      M350Z16 I0 ; configure microstepping without interpolation
      M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
      Unrelated, but you're missing a space between the M350 and the axis letter.
      I understand the frustration. Let's see if we can nail down the issue.
      The config looks ok.
      Can you send M587 by itself to get a list of saved SSIDs? This will confirm that the SSID has been properly added.
      The error message network scan failed would indicate that it's unable to identify a network SSID in range to connect to and it's given up. In your other thread we did identify that the signal strength was rather weak. In order to diagnose if this is in fact the case, I suggest temporarily relocating the wireless access point or the printer so that they are both in close proximity with very little obstruction and seeing if you can then in fact connect.
      Remembered networks:
      Spiffy IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
      ok
      Signal is 100%
      How do i clear any config for network. maybe a clean slate would be a good idea.
      • Shaunundefined
        Shaun
        I have redone the config.
        ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 09:04:56 GMT+0100 (British Summer Time)
        M550 P"CR10" ; set printer name
        M552 S0 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
        M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X300 Y300 Z400 S0 ; set axis maxima
        M574 X1 Y1 Z1 S1 ; set active high endstops
        M558 P0 H5 F0 T6000 ; disable Z probe but set dive height, probe speed and travel speed
        M106 P0 S0 I0 F300 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P1 S0 I0 F300 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          Phaedrux Moderator @Shaun
          From the previous thread:
          From the console can you please send the following:
          M552 S0
          M588 S"*"
          M587 s"Spiffy" p"Password1"
          M552 S1
          M122
          This will take the wifi module to idle, clear all saved SSIDs, re-add your SSID, and re-enable the module and hopefully connect. Then the diagnostic should show the connection stats.
          Shaunundefined 1 Reply Last reply Reply Quote 0
          • Shaunundefined
            Shaun @Phaedrux
            M552 S0
            M588 S"*"
            M552 S1
            M122
            I’ve done all of that, same problem. Ill set up my old router tonight and see if I can connect to that. Just in case it’s my current router.
            • themelleundefined
              themelle @Shaun
              Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
              Is it just me or are those 1.6-1.8V VIN indeed usable? 😮
                T3P3Tony administrators @themelle
                @themelle if just powering off USB (fine for WIFI tests) you don't need VIN
                themelleundefined 1 Reply Last reply Reply Quote 0
                • themelleundefined
                  themelle @T3P3Tony
                  @T3P3Tony Ah ok, I see 🙂
                  (I thought powering off USB would show up as VIN around 5V)
                  Thanks for clarifying!
                  • Shaunundefined
                    Shaun
                    OK so ive done the following.
                    Changed WiFi SID, no change
                    Changed WiFi Password. no change
                    Tried old router, no change
                    I get the same result each time.
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                    Board ID: 08DGM-9T6BU-FG3SN-6J9F4-3SD6R-TUZHF
                    Used output buffers: 1 of 24 (10 max)
                    Static ram: 25680
                    Dynamic ram: 93644 of which 0 recycled
                    Exception stack ram used: 256
                    Never used ram: 11492
                    Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3808) IDLE(ready,160)
                    Owned mutexes:
                    Last reset 00:08:56 ago, cause: power up
                    Last software reset at 2019-09-11 08:23, reason: User, spinning module GCodes, available RAM 11436 bytes (slot 2)
                    Error status: 0
                    Free file entries: 10
                    MCU temperature: min 34.9, current 35.9, max 36.1
                    Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                    Driver 0: ok, SG min/max not available
                    Driver 1: ok, SG min/max not available
                    Driver 2: ok, SG min/max not available
                    Driver 3: ok, SG min/max not available
                    Driver 4: ok, SG min/max not available
                    Cache data hit count 1062453510
                    Slowest loop: 46.87ms; fastest: 0.06ms
                    Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                    === DDARing ===
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is ready with "m122" in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 77.22ms; fastest: 0.00ms
                    HTTP sessions: 0 of 8
                    • WiFi -
                      Network state is changing mode
                      WiFi module is trying to connect
                      WiFi firmware version 1.23
                      WiFi MAC address 84:f3:eb:41:4e:f8
                      WiFi Vcc 3.39, reset reason Hardware watchdog
                      WiFi flash size 4194304, free heap 26560
                      ok
                    I am now totally exhausted.
                    • Shaunundefined
                      Shaun
                      Did i mention that im also getting this.....
                      Failed to change WiFi mode (code -7)
                      m587
                      M587: Failed to retrieve network list
                      ok
                        A Former User
                        Are you powering the board off USB now? If so what type of USB power supply are you using, could be its insufficient current from USB as the ESP8266 wifi module is somewhat power hungry.
                          T3P3Tony administrators @A Former User
                          @bearer don't think its that in this case, the ESP is reporting >3.3V VCC.
                          @Shaun thanks for the thorough investigation. What is not clear is if this is conducted from where it previously worked, or in your printer.
                          Nevertheless we should arrange a replacement, and test this board. Please can you submit a warranty request and reference this forum topic.
                          https://www.duet3d.com/warranty
                            dc42 administrators @Shaun
                            @dc42 said in Think its broken...:
                            Have you tried re-flashing the WiFi firmware?
                            DC i have, all went through fine. Was one of the 1st threads i read on here where you suggested that.
                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
                            That doesn't say anything about the WiFi firmware version. If you already have DuetWiFiServer.bin in /sys and it is dated this year, you can just send M997 S1 to re-install it (even better, download a fresh copy from https://github.com/dc42/RepRapFirmware/releases/tag/2.03). Preferably, send that command from PanelDue or from a PC running YAT, then you can watch the progress and verify that it completes successfully.
                            If you have already done this, no need to do it again, fill in the warranty form. The hardware watchdog reset message in the M122 report suggests either corrupt firmware or faulty hardware.
                            • Danalundefined
                              Danal
                              Board swap is on the table form Duet... and may be a good idea... just to possibly avoid the time/hassle, try hooking up VIN (in addition to USB) to a solid 12V or more supply, and re-flash wifi firmware, and re-test, with that power hooked up.
                              These guys know MUCH more than I... but... something is just itching my brain about power, flash, wifi module, etc, etc, etc. Probably I'm wrong, but it is something quick to try, before getting into a full board swap.
                              Shaunundefined 1 Reply Last reply Reply Quote 1
                              • Shaunundefined
                                Shaun @dc42
                                Hi
                                Ive actually re-installed the firmware, wifi and web a nuber of times in an attempt to get this working.
                                • Shaunundefined
                                  Shaun @T3P3Tony
                                  @T3P3Tony said in Think its broken...:
                                  Thank you Tony, believe me when i say i have tried everything i could find on the forums. I have tried this from every possible location including sitting right next to my router with my laptop. Like i said, im happy to try anything else you might suggest but i am now at a total loss.
                                  • Shaunundefined
                                    Shaun @Danal
                                    @Danal said in Think its broken...:
                                    Danal
                                    I have powered the board from the PSU, then connected the usb and plugged this into my laptop. Results are the same.
                                    • Danalundefined
                                      Danal @Shaun
                                      Danal
                                      Ahhh, well, it was worth a try.
