    ferruled connectors
    27
    1.7k
    • Vetiundefined
      Veti
      the ferule connectors are for the cable for voltage in, the hotend and the heated bed
      • PaulHewundefined
        PaulHew
        Basically, anything with a screw down connection
        HTH
        • swrightlastundefined
          swrightlast
          Thanks for the speedy reply!
            The ferrules are important for the VIN power and heated bed. Less so for the hot end heater connection.
            • Dugeeundefined
              Dugee
              what size are these ferrules? I need to replace mine at the heated bad
                A Former User
                @Dugee Ferrules are sized for the wire, not the terminal.
                • Dugeeundefined
                  Dugee
                  One of the reasons I like the general 3d community is that you can ask the stupid/obvious question without being patronised or belittled. Everyone is always keen to help the beginner.
                  Many thanks.
                    T3P3Tony administrators
                    I have added a note about ferrules to the documentation:
                    https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Ferrules
                      A Former User
                      Risky business specifying size according to colour; while there are a few standards to choose from, you can also get almost any size in any colour. While it'll be correct for the ones supplied by Duet3d the end user can easily end up with a different size if ordering new ones based on colour.
                      T3P3Tonyundefined zaptaundefined 2 Replies Last reply Reply Quote 1
                        T3P3Tony administrators @A Former User
                        @bearer exactly why i have the mm^2 in the documentation.
                          A Former User @T3P3Tony
                          @T3P3Tony yes, maybe i should have been clearer; I'd put the size first to emphasize size instead of colour.
                            @bearer fair enough - I have updated it to make it clearer.
                            • mihaitinteaundefined
                              mihaitintea
                              But how do I correctly fit those ferruled connectors into the terminals ? Do I flatten them first with pliers before putting them into the terminals and tighten the terminals' screws, or do I put the ferruled connectors as they originally are ("cylindrical", not mechanically deformed -- flattened) into the teminals and force-screw the terminals's screws until they mechanically flatten the ferruled connectors ?
                              JoergS5undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • JoergS5undefined
                                JoergS5 @mihaitintea
                                This post is deleted!
                                • Vetiundefined
                                  Veti
                                  they are meant to be used with a ferrule crimp tool.
                                    Phaedrux Moderator @mihaitintea
                                    @mihaitintea Pliers don't really work very well. Ideally you'd use crimpers meant for ferrules that compress them in all directions to create a tight pinch. Pliers or vice grips can be used, but you risk damaging the wires or creating a poor mechanical crimp.
                                    https://www.google.com/search?q=crimping+bootlace+ferrules&oq=crimping+boot&aqs=chrome.1.69i57j0l5.6576j0j7&sourceid=chrome&ie=UTF-8
                                      I use a ferrule crimping tool that I bought from Maplin, who sadly went bust. A search on eBay UK turned up this https://www.ebay.co.uk/itm/Ferrule-Crimper-Cable-Tube-Crimping-Plier-Tool-1200X-Wire-Terminal-Connector-Set/392118937290 and several other listings for similar products.
                                        A Former User
                                        There is a wide range of types of crimping tools, while I tend to prefer the sort of D shaped dies the smallest terminals used on the Duet works best with square type of crimpers, and not the type that create extremely serrated sides.
                                        So the type dc42 links to is probably the best bet.
                                          swrightlast
                                          Bought a ferrule crimping tool.....problem solved.
                                            mihaitintea
                                            Hello
                                            Thanks for the answers but I believe I did not make myself very well understood.
                                            The ferrule connectors that I am talking about are already crimped to the wires, from the factory.
                                            I was talking about tightening the ferrule connectors into the Duet3D board terminal blocks.
                                            The out-of-the-box ferrule connector is a hollow tube. One end of this tube is factory-crimped to the wire, and the other end of this tube is free and goes into Duet's terminal blocks.
                                            Do I tighten this free end of the tube in the Duet board's terminal block until the tube gets mechanically deformed ? Or do I do the flattening myself (e.g., using pliers) until the connector gets shaped as a flat rectangle, and put that flattened end of the connector in Duet's terminal blocks and then tighten those screws ?
                                            Which way is best ? In time, which of these variants is the most reliable (i.e., does not need to be pereiodically verified and tightened again)
                                            Thanks and regards
                                            A Former User? grizewaldundefined 2 Replies Last reply Reply Quote 0
