    Duet 3 Mainboard 6HC - initial production run.
    243
    32.8k
    • gtj0undefined
      gtj0
      Should the underside of the drivers and mosfets be completely soldered to the board or is there enough contact to dissipate the heat the way they are?
      • wilrikerundefined
        wilriker @mundsen
        @mundsen said in Duet 3 Mainboard 6HC - initial production run.:
        I got a question about duet 3 and pi - is the code transfered to the duet before the print Job starts or is it controlled real time by the pi during the print?
        It is controlled real time. This also allows to implement plug-ins to do arbitrary modifications while the print is in progress. For example I have implemented a first version of an Object Skipper, i.e. a plug-in that is given the information on how to identify a certain object in the GCode (many slicers put specific comments in the GCodes) and then will filter out any commands related to this object (or multiple).
        This allows for a print to continue where you have multiple objects on the platform but printing fails for whatever reason for one of them.
        I will probably release this early next week.
        Manuel
        My Tool Collection
        1 Reply Last reply Reply Quote 5
          A Former User
          Much ❤
          @wilriker said in Duet 3 Mainboard 6HC - initial production run.:
          Fur example I have implemented a first version of an Object Skipper
            dc42 administrators @gtj0
            @gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
            The connectors should be soldered, but not the thermal vias under the stepper drivers and mosfets.
            • gtj0undefined
              gtj0
              So the partially filled vias are OK?
                Yes.
                • Cataundefined
                  Cata
                  Will there be a variant that does not use a raspberry?
                  • gtj0undefined
                    gtj0 @Cata
                    @Cata said in Duet 3 Mainboard 6HC - initial production run.:
                    The current 6HC board has an SD card slot and an ethernet port that allows you to use it in standalone mode.
                    Cataundefined 1 Reply Last reply Reply Quote 1
                    • Cataundefined
                      Cata @gtj0
                      @gtj0 Thanks, i re-read again the wiki and its fine for my use.
                      • gtj0undefined
                        gtj0 @Cata
                        No worries. There was some talk about the boards not having the SD card holder or the ethernet jack populated at first so there was a little confusion.
                          deckingman
                          For info, I've been running mine in "stand alone" mode without the RPi.
                          • gtj0undefined
                            gtj0
                            @T3P3Tony From the wiring diagram and from my testing it looks like the "reset" pin on the Duet3 has a pull-up resistor and is expecting to be pulled to ground for a reset. Can the pin be driven directly by an SBC GPIO? I.E. If I configure a GPIO as a simple active-low pin will the Duet3 be OK with 3.3v from the SBC also keeping it high?
                              T3P3Tony administrators @gtj0
                              @gtj0 yes that should work fine but i have not tested.
                                dc42 administrators @T3P3Tony
                                As the SBC and Duet will be powered from different 3.3V supplies, I recommend you use a resistor in series with the connection from the SBC. AFAIR the pullup on the Duet is 10K, so a 470R resistor should do.
                                • gtj0undefined
                                  gtj0 @dc42
                                  @dc42 Good point, thanks.
                                  • gtj0undefined
                                    gtj0
                                    Another power question: Should the "SBC -> 5V" power option be working? With only that jumper installed, the Duet3 won't power up using 5V on pins 2 and 4 of the 26 pin connector. I've verified that the voltage is there and if i connect pins 4 and 6 on the SBC to the 5V and GND pins on the ATX header things work fine (with no jumpers).
                                      A Former User @gtj0
                                      @gtj0
                                      this is what tony said told me earlier: (not sure if changed since)
                                      you need both fitted this is the schematic. Its actually that the protection is between the 5V_INT and 5V_EXT circuits, the 5V_EXT to the 5V_SBC is just a jumper that connects those two rails. What really should happen is the "SBC->5V*" jumper is fitted and the 5V_EN jumper is removed...
                                      • gtj0undefined
                                        gtj0 @A Former User
                                        @bearer Ah thanks. I must have missed that.
                                        • Selecta_Motaundefined
                                          Selecta_Mota
                                          Any news on the ToolBoard?
                                          Would love to test it with my new printer and Hemera
                                            T3P3Tony administrators @Selecta_Mota
                                            @Selecta_Mota I expect we will announce the production pre order before Christmas for shipping either end of Jan or beginning of Feb.
                                            Selecta_Motaundefined 1 Reply Last reply Reply Quote 0
