    Duet 3 Mainboard 6HC - initial production run.
    243
    32.9k
      A Former User
      Much ❤
      @wilriker said in Duet 3 Mainboard 6HC - initial production run.:
      Fur example I have implemented a first version of an Object Skipper
        dc42 administrators @gtj0
        @gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
        Should the underside of the drivers and mosfets be completely soldered to the board or is there enough contact to dissipate the heat the way they are?
        The connectors should be soldered, but not the thermal vias under the stepper drivers and mosfets.
        • gtj0undefined
          gtj0
          So the partially filled vias are OK?
            Yes.
            • Cataundefined
              Cata
              Will there be a variant that does not use a raspberry?
              • gtj0undefined
                gtj0 @Cata
                @Cata said in Duet 3 Mainboard 6HC - initial production run.:
                The current 6HC board has an SD card slot and an ethernet port that allows you to use it in standalone mode.
                Cataundefined 1 Reply Last reply Reply Quote 1
                • Cataundefined
                  Cata @gtj0
                  @gtj0 Thanks, i re-read again the wiki and its fine for my use.
                  • gtj0undefined
                    gtj0 @Cata
                    No worries. There was some talk about the boards not having the SD card holder or the ethernet jack populated at first so there was a little confusion.
                      deckingman
                      For info, I've been running mine in "stand alone" mode without the RPi.
                      • gtj0undefined
                        gtj0
                        @T3P3Tony From the wiring diagram and from my testing it looks like the "reset" pin on the Duet3 has a pull-up resistor and is expecting to be pulled to ground for a reset. Can the pin be driven directly by an SBC GPIO? I.E. If I configure a GPIO as a simple active-low pin will the Duet3 be OK with 3.3v from the SBC also keeping it high?
                          T3P3Tony administrators @gtj0
                          @gtj0 yes that should work fine but i have not tested.
                            dc42 administrators @T3P3Tony
                            As the SBC and Duet will be powered from different 3.3V supplies, I recommend you use a resistor in series with the connection from the SBC. AFAIR the pullup on the Duet is 10K, so a 470R resistor should do.
                            • gtj0undefined
                              gtj0 @dc42
                              @dc42 Good point, thanks.
                              • gtj0undefined
                                gtj0
                                Another power question: Should the "SBC -> 5V" power option be working? With only that jumper installed, the Duet3 won't power up using 5V on pins 2 and 4 of the 26 pin connector. I've verified that the voltage is there and if i connect pins 4 and 6 on the SBC to the 5V and GND pins on the ATX header things work fine (with no jumpers).
                                  A Former User @gtj0
                                  @gtj0
                                  this is what tony said told me earlier: (not sure if changed since)
                                  you need both fitted this is the schematic. Its actually that the protection is between the 5V_INT and 5V_EXT circuits, the 5V_EXT to the 5V_SBC is just a jumper that connects those two rails. What really should happen is the "SBC->5V*" jumper is fitted and the 5V_EN jumper is removed...
                                  • gtj0undefined
                                    gtj0 @A Former User
                                    @bearer Ah thanks. I must have missed that.
                                    • Selecta_Motaundefined
                                      Selecta_Mota
                                      Any news on the ToolBoard?
                                      Would love to test it with my new printer and Hemera
                                        T3P3Tony administrators @Selecta_Mota
                                        @Selecta_Mota I expect we will announce the production pre order before Christmas for shipping either end of Jan or beginning of Feb.
                                        Selecta_Motaundefined 1 Reply Last reply Reply Quote 0
                                          jay_s_uk
                                          @T3P3Tony and now I'm going to have to order one of those too
                                            Selecta_Mota @T3P3Tony
                                            @T3P3Tony great to hear, thank you 🙂
