    BondTech CR-10S Extrusion Problem
    569
      deckingman @Kaizer
      @Kaizer I can see why you need to set two Z drivers. You have defined the extruder to use drive 4 in your M584. By default the first extruder (extruder 0) would be drive 3 and the second extruder (extruder 1) would be drive 4. Now in your tool definition you use drive 0. So if you don't define drive 3 as anything, then the firmware reverts to it's default and sets extruder 0 as using drive 3 so your extruder on drive 4 would become extruder 1. In that case, your tool, definition (M584) should use D1 not D0.
      So you have several options. The simplest is to move the extruder to drive 3 and set the Z to only use drive 2. Or, if you really want to use drive 4, define the tool to use D1 not D0.
      As for no filament coming out when you print, you probably just need to have a T0 command somewhere to select a tool. Either at the end of your config.g or in the slicer start code.
      Kaizerundefined 1 Reply Last reply Reply Quote 1
      • boldnutsundefined
        boldnuts
        Do you your slicer set to relative extrusion and 1.75mm filament dia?
        • Vetiundefined
          Veti @Kaizer
          @Kaizer said in BondTech CR-10S Extrusion Problem:
          also you are most likely printing at the wrong temperature. B4138 is the default and most likely wrong for your thermistors.
          Kaizerundefined 1 Reply Last reply Reply Quote 0
          • Kaizerundefined
            Kaizer @deckingman
            @deckingman Thanks. It makes a lot of sense now.
            My Slicer start Gcode is only
            G28 ; home all axes
            G1 Z5 F5000 ; lift nozzle
            should i add T0 as u said? if yes can u give me an example of the completed code?
            • Kaizerundefined
              Kaizer @Veti
              @Veti i see, Im actually wondering about it too. but since i dont know much about it. i just leave it as is and do a temperature tower later on.
              Im using the stock Bed thermistor for CR-10S and E3D V6 Tube Thermistor for my hotend. i dont know what their names are so idk what to set my thermistor as. if you know, mind sharing it? thanks.
                deckingman @Kaizer
                @Kaizer Literally, it's just "TO" on a new line (without the quotes). So:
                G28 ; home all axes
                T0
                or put the T0 first if you need to heat the hot end before homing.
                Kaizerundefined 2 Replies Last reply Reply Quote 0
                • Kaizerundefined
                  Kaizer @deckingman
                  @deckingman Thanks alot. will give it a try now.
                  • Vetiundefined
                    Veti @Kaizer
                    E3D V6
                    if its a genuine E3D the settings are: B4725 C7.060000e-8
                    • Kaizerundefined
                      Kaizer @Veti
                      @Veti Thanks, so its gonna be
                      M305 P1 T100000 B4725 C7.060000e-8 ; set thermistor + ADC parameters for heater 1
                      • Vetiundefined
                        Veti
                        correct. the r parameter is not required as will be replaced by the correct one for your board.
                        • Kaizerundefined
                          Kaizer @Veti
                          @Veti what do u mean by r parameter? sorry i dont really understand programming language.
                          • Vetiundefined
                            Veti
                            R4700. That is optional and not required as its the default value.
                            • Kaizerundefined
                              Kaizer @Veti
                              @Veti i see, Thanks a lot.
                              • Kaizerundefined
                                Kaizer @deckingman
                                @deckingman Thanks for the help. it works fine now. 👍 👌
                                  deckingman @Kaizer
                                  @Kaizer Glad you are sorted. ☺
