    Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
    30
    3.9k
      A Former User
      Although don't know if the 5V/0.6A provided by the MKS PWC unit is sufficient for the Duet.
      This may shed some light on that:
      https://forum.duet3d.com/post/35264
      • CrazyCreatorundefined
        CrazyCreator
        First: You mean the Wiring from the first posting?
        This: https://user-images.githubusercontent.com/35586270/36057698-87f482dc-0df0-11e8-983e-dbaf89b09f5a.png
        Second:
        What mean: (and 5V/gnd ofc)?
        I don't understand the "ofc"
        And Last:
        I can use this wiring for the rest:
        http://www.crazycreatorcube.com
          A Former User
          Yeah, it has the S1 and S0 labels on the MKS PWC, they are the PS_ON output and PowerLoss input signals respectively.
            CrazyCreator
            Ok ... I read and hope I understand πŸ™‚
            For the rest of wiring I can use this picture too:
            I know the picture is for the MKS Gen 1.4, but I mean the routing for the other cables
            CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
            • thweundefined
              thwe
              if your goal is:
              • 24v supply on / off via gcode or dwc
              • emergency stop switch
              • reset
              try this:
              You only need : example for a opto low-level trigger-relay
              Thomas
              • Stephen6309undefined
                Stephen6309 @CrazyCreator
                @crazycreator Duet is able to resume after a power loss, if you set it up: https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
                For powering on/off: https://duet3d.dozuki.com/Wiki/Power_Wiring and
                  CrazyCreator @CrazyCreator
                  @thwe and @Stephen6309
                  My only concern is to have a 16mm button on the front of the printer, with this I want to turn on the printer.
                  If I can turn off the printer with this button, that would be nice, but it is not necessary. I can do that also via web interface
                  • ediikundefined
                    ediik
                    If anybody came accross the same thing πŸ˜ƒ i got a solution. now the baord turns ON with the front button.
                    Sidenote: it does not matter where you get the 5v from. The pins from the main extension ports are allready if use on my board (bltouch).
                    Meltexundefined 1 Reply Last reply Reply Quote 0
                      CrazyCreator
                      how locks your config.g now
                      ediikundefined 1 Reply Last reply Reply Quote 0
                      • ediikundefined
                        ediik @CrazyCreator
                        @CrazyCreator it does not matter. The lerdge board simply gets 5v from the duet and stays on for the time it has 5v connected. No cdg changes necessary. πŸ™‚
                          CrazyCreator
                          ok ... I would test it
                          • Meltexundefined
                            Meltex @ediik
                            @ediik Hi! I came across this thing. πŸ™‚ One question - why don't you use PS_ON signal for controlling Lerdge power module?
                            • ediikundefined
                              ediik @Meltex
                              @Meltex hi sorry for late reply. i honestly dont know how to wire it up the right way.
                              • bitminterundefined
                                bitminter
                                Don’t feel bad this module has beaten me as well for time being. I went to the solid state relay setup as highlighted above and was much simpler to get going with the same button. But... I really would like to figure this out too at some point lol.
                                  bitminter
                                  Little correction, for me, it’s the Makerbase MKS PWC V2.0 module. No matter what I tried, just couldn’t get it to work.
                                  • Richygoatundefined
                                    Richygoat
                                    Hello, did anybody the Lerdge Power Modul to work with the Duet. I want to try the same thing. Have a Lerdge Power Modul laying around here. What does the PS_ON pin on the Duet exactly? Act it like a 5v on and off switch?
                                      A Former User @Richygoat
                                      @Richygoat said in Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?:
                                      https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
                                        Richygoat
                                        Here is no answer to this question. I want to turn the PSU off with this modul. When it get 5v continuously from the Duet it stays always on. When there is 5v, GND an PS_ON on that connector how does it exactly work. I know this is 5v in. Does the PS_ON switch the 5V to PS_ON?
                                          Richygoat
                                          Ok the PS_ON pin will be connected to Ground when the PSU have to be enabled. Is there a way to get a 5v Signal to shut the Relay down? See the picture attached.dr6X10S.png
                                            Richygoat
                                            Is something like this possible?
