Dual Z tilts after time (fast)
@Veti Thx i tryed 5mm now and it works.
From now on i should use in my start Gcode before every Print G32 S2 right?
@AS-3D-Druck said in Dual Z tilts after time (fast):
it depends on your bed.
if its perfectly flat yes.if not use
G32 followed by G29 -
Ok i don't know what happend but now my Homing has flipped from front left to back right. (Stall Detection)
I don't know why it worked yesterday and now not.
do the normal moves are in the correct direction?
if yes -> check your homing file moves
if no -> change direction of motors in the config -
This is how i home all:
; Lift Z relative to current position G91 G1 Z10 F6000 S2 G90 M913 X50 Y50 ; reduce motor current to 50% to prevent belts slipping G91 ; use relative positioning ; X G1 S1 X-500 F4000 ; move the X to max until it detects the min Point G92 X0 ; set X min Point G1 S1 X30 ; move X away from min Point M400 ; Y G1 S1 Y-500 F4000 ; move the X to max until it detects the min Point G92 Y0 ; set X min Point G1 S1 Y30 ; move X away from min Point G90 ; back to absolute positioning M913 X100 Y100 Z100 ; motor currents back to normal ; Z G1 S1 X168 Y95 F2000 ; put head over the centre of the bed, or wherever you want to probe G30 ; lower head, stop when probe triggered and set Z to trigger height G91 ; relative mode G1 Z10 F6000 S2 ; raise head 4mm to ensure it is above the Z probe trigger height G90 ; back to absolute mode config: https://pastebin.com/gFtv1wM7
@AS-3D-Druck Do the motors still move in the right correct directions? i.e. when you do G1 S1 X-500, does it still move to the left? And when you do G1 S1 Y-500, does it still move to the front?
@deckingman said in Dual Z tilts after time (fast):
It does not move at all in - only in+ but there is no room for any Movement so it cares in the Extrusion.
The coordinates are set wrong for some reason
btw. i added on my Post before the config.g
config: https://pastebin.com/gFtv1wM7 -
You might want to consider joining the two leadscrews with a belt
this does not answer the question.
move the extruder to the middle
issue M564 H0
and see if the movement are as expeded.
ie x - goes left x+ goes right -
@Veti No it does nit everything in - isn't working except i use M564 H0 than i can manualy move it to the middle but homing does still not work anymore.
@AS-3D-Druck Starting with the print head in the middle step through your homing fie one line at a time but you can ignore the Z axis for now. So send M913 X50 Y50 to reduce the motor currents. Then send G91 to set relative positioning. Then send G1 S1 X-500 F4000 and tell us if the head moves to the left as it should or does it do something else?
Ok maybe i found the Issue here:
; X G1 S1 X-500 F4000 I had to send 3-4 times this command until it started to move to the min point.
Bevore that i heared only a tock after i send the command.... like there was already something that the stall detection noticed.I don't know my Motors are rated for 1.3A and i set them to 1A and reduced it to 50%.
Now i played with M915 and increased the S Value from 3 to 8 to 10.It looks like that was the Problem.
Thx alot for the help and i will try my next print with this new "Setup".
You're Guys are awesome.
