    Dual Z tilts after time (fast)
    22
    846
    • aidarundefined
      aidar @AS-3D Druck
      @AS-3D-Druck said in Dual Z tilts after time (fast):
      Thx, but does it work also if i connected both to the Z?
      No it does not.
      I thought i need that Expansion Board for a "second" Z Axis.
      You can use free driver on Duet, if you have one. Means for example, if you have only one extruder, connected to E0, then you can use E1 for second Z axis motor.
        deckingman @AS-3D Druck
        @AS-3D-Druck The reason why it tilts is because every time you apply power, the motors jump to the nearest full step which might be either forwards or backwards. Actually, I believe it's worse than that and it might actually be a difference of 4 full steps but I can't remember the reason why.
        You have two practical options that I can think of. The first is to drive each motor independently and use bed levelling but as @aidar has pointed out, for that to happen each motor has to be connected to a separate driver. The second option would be to drive both screws together via a single motor and continuous belt.
          dc42 administrators @deckingman
          @deckingman said in Dual Z tilts after time (fast):
          Or stick with 2 motors, but connect them with a belt. The belt needs to prevent one motor moving by 4 full steps relative to the other.
          • jens55undefined
            jens55
            Would you not get 'wind up' of the mechanics if you have two motors connected like that?
            deckingmanundefined 1 Reply Last reply Reply Quote 1
              deckingman @jens55
              @jens55 said in Dual Z tilts after time (fast):
              I would have thought so but perhaps it might not be significant?
              • AS-3D Druckundefined
                AS-3D Druck
                Ok i tryed the independent Leadscrews but it looks like 1mm correction isn't enough. 😲
                	G32 Error: Some computed corrections exceed configured limit of 1.00mm: -2.080 2.814
                Best regards
                AS-3D Druck / Andre
                • Vetiundefined
                  Veti
                  see
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M671_Define_positions_of_Z_leadscrews_or_bed_levelling_screws
                  S parameter
                  AS-3D Druckundefined 1 Reply Last reply Reply Quote 1
                    AS-3D Druck @Veti
                    @Veti Thx i tryed 5mm now and it works.
                    From now on i should use in my start Gcode before every Print G32 S2 right?
                    Best regards
                    AS-3D Druck / Andre
                    • Vetiundefined
                      Veti @AS-3D Druck
                      it depends on your bed.
                      if its perfectly flat yes.
                      if not use
                      G32 followed by G29
                        AS-3D Druck
                        Ok i don't know what happend but now my Homing has flipped from front left to back right. (Stall Detection)
                        I don't know why it worked yesterday and now not.
                        Best regards
                        AS-3D Druck / Andre
                        • Vetiundefined
                          Veti
                          do the normal moves are in the correct direction?
                          if yes -> check your homing file moves
                          if no -> change direction of motors in the config
                            AS-3D Druck
                            This is how it homes
                            This is how i home all:
                            ; Lift Z relative to current position
                            G91
                            G1 Z10 F6000 S2
                            G90
                            M913 X50 Y50						; reduce motor current to 50% to prevent belts slipping
                            G91							; use relative positioning
                            ; X
                            G1 S1 X-500 F4000					; move the X to max until it detects the min Point
                            G92 X0							; set X min Point
                            G1 S1 X30						; move X away from min Point
                            M400
                            ; Y
                            G1 S1 Y-500 F4000					; move the X to max until it detects the min Point
                            G92 Y0							; set X min Point
                            G1 S1 Y30						; move X away from min Point
                            G90							; back to absolute positioning
                            M913 X100 Y100 Z100					; motor currents back to normal
                            ; Z
                            G1 S1 X168 Y95 F2000 					; put head over the centre of the bed, or wherever you want to probe
                            G30            			    			; lower head, stop when probe triggered and set Z to trigger height
                            G91                					; relative mode
                            G1 Z10 F6000 S2       					; raise head 4mm to ensure it is above the Z probe trigger height
                            G90                					; back to absolute mode
                            config: https://pastebin.com/gFtv1wM7
                            Best regards
                            AS-3D Druck / Andre
                              @AS-3D-Druck Do the motors still move in the right correct directions? i.e. when you do G1 S1 X-500, does it still move to the left? And when you do G1 S1 Y-500, does it still move to the front?
                              AS-3D Druckundefined 1 Reply Last reply Reply Quote 0
                                AS-3D Druck @deckingman
                                It does not move at all in - only in+ but there is no room for any Movement so it cares in the Extrusion.
                                The coordinates are set wrong for some reason 😵
                                btw. i added on my Post before the config.g
                                Best regards
                                AS-3D Druck / Andre
                                • NitroFreakundefined
                                  NitroFreak
                                  You might want to consider joining the two leadscrews with a belt
                                  • Vetiundefined
                                    Veti
                                    this does not answer the question.
                                    move the extruder to the middle
                                    issue M564 H0
                                    and see if the movement are as expeded.
                                    ie x - goes left x+ goes right
                                      AS-3D Druck @Veti
                                      @Veti No it does nit everything in - isn't working except i use M564 H0 than i can manualy move it to the middle but homing does still not work anymore.
                                      Best regards
                                      AS-3D Druck / Andre
                                        @AS-3D-Druck Starting with the print head in the middle step through your homing fie one line at a time but you can ignore the Z axis for now. So send M913 X50 Y50 to reduce the motor currents. Then send G91 to set relative positioning. Then send G1 S1 X-500 F4000 and tell us if the head moves to the left as it should or does it do something else?
                                          Ok maybe i found the Issue here:
                                          ; X
                                          G1 S1 X-500 F4000
                                          I had to send 3-4 times this command until it started to move to the min point.
                                          Bevore that i heared only a tock after i send the command.... like there was already something that the stall detection noticed.
                                          I don't know my Motors are rated for 1.3A and i set them to 1A and reduced it to 50%.
                                          Now i played with M915 and increased the S Value from 3 to 8 to 10.
                                          It looks like that was the Problem.
                                          Thx alot for the help and i will try my next print with this new "Setup". 😊
                                          You're Guys are awesome. 👍
                                          Best regards
                                          AS-3D Druck / Andre
