    Configuring 12864 LCD on Maestro?
    79
    23.1k
    • PuterProundefined
      PuterPro @pixelpieper
      @pixelpieper Thanks! Nice explanation!!
      • pixelpieperundefined
        pixelpieper @PuterPro
        @puterpro My contrast improved significantly once I ran the Maestro board of 24V rather than USB. Seems to be an issue with the supply...
        Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
        Voron V0.250 / Duet 2 Maestro
        • PuterProundefined
          PuterPro
          @pixelpieper Thanks, that makes some sense as they do tend to be voltage sensitive, as anyone with YOUR screen name should know. LOL!
          My old setup was running 13.2v, new is an ATX @ 12.2v.
          I'm running without a display currently as I have a PC right next to it, it's on my list to handle but low priority right now. I'll get back to it and if it's too naughty I'll get a cheap one from China ...
          24v is on my Wish List but the Wife Finance Committee is currently recovering from shock from all the upgrades right now. 😉
            If you have the on-board 5V regulator enabled, then the contrast on the 12864 display can be expected to change when you switch from USB power to VIN power (or provide both - the VIN power will take over). This is because the 5V rail is only about 4.6V when powered from USB alone, but a true 5V when powered from VIN. However, increasing VIN from 12V to 24V shouldn't make any difference to the contrast.
            There are two places where the contrast pot may be:
            1. Mounted on the back of the LCD PCB (the green one), so the red PCB gets in the way of adjusting it. If you orient the unit so that you are looking into the SD card socket opening with the LCD on the underside, the pot is slightly behind and to the left of the back left corner of the SD card socket. Some of these display/encoder combos have a hole close to one corner of the SD card socket, to provide access to the pot.
            2. Mounted near the bottom left corner on the front of the red PCB. Most of the current listings on Amazon and eBay show it in this position.
            • 3ddevilundefined
              3ddevil
              I know this is an old topic but in case people are searching and relying on the information I tried to reconcile the different common styles with pictures of the LCD itself and cable, so it is easier to identify which ones you need. See the pictures in this post:
              Bottom line, if you don't know it's simple: if the LCD doesn't power on, flip one end of your LCD cables, cutting the keying feature if it's in the way.
              • abstraktlightingundefined
                abstraktlighting
                Whew . So I think I got it. I just want to clarify before i chop an end off my ribbon cable.
                Q: I CAN USE THE ORIGINAL 10 PIN RIBBON CABLE TO DO WHATS
                NEEDED TO BE FULLY FUNCTIONAL WHEN INSTALLING DUET WIFI
                INTO ENDER 3 BY FOLLOWING THE DIAGRAM ON PIXELPIEPERS
                2/4/2019 POST ABOVE?
                A: YES or NO?
                Thanks to all of you I'm brand new and just want to finally get to print some stuff. 🙂
                • Vetiundefined
                  Veti
                  @abstraktlighting said in Configuring 12864 LCD on Maestro?:
                  DUET WIFI
                  no the duet wifi is not supported
                  abstraktlightingundefined 1 Reply Last reply Reply Quote 0
                    abstraktlighting @Veti
                    This post is deleted!
                    • oliofundefined
                      oliof
                      By the way: no need to cut off anything, usually you can carefully lift the black plastic receptacle for the ribbon cable on the LCD and put it back on turned 180°.
                      • 4latheundefined
                        4lathe
                        I don't want to beat a dead horse but is there any way to use the 12864 lcd with a duet wifi? If not what about the tft28? Thx
                        • 4latheundefined
                          4lathe
                          Never mind the first question. Seems like thats still impossible without building hardware. But any thoughts on a tft28?
