    heater fault when print starts
    1.4k
    • Vetiundefined
      Veti
      @Government_Bacon said in heater fault when print starts:
      M305 P2 T100000 B4725 C7.200000e-8 R4700 ; set thermistor + ADC parameters for heater 2
      e3d thermistor use
      B4725 C7.060000e-8
      Government_Baconundefined 1 Reply Last reply Reply Quote 0
      • Government_Baconundefined
        Government_Bacon @Veti
        @Veti i tryed this it did not work i have even replace the thermistor and autotune it and it still dose it (i had sock and fan on when i auto tuned and fan off when printing. it is as soon at the steppers start to move the temp starts to drop quickly
        M
        122
        Printing paused at X335.6 Y331.4 Z0.5
        12/31/2019, 12:21:26 AM M292 P1
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
        Board ID: 08DGM-917DA-G4MS8-6J9DJ-3SJ6R-KBVV9
        Used output buffers: 4 of 24 (22 max)
        Static ram: 25680
        Dynamic ram: 93696 of which 484 recycled
        Exception stack ram used: 424
        Never used ram: 10788
        Tasks: NETWORK(ready,524) HEAT(blocked,740) MAIN(running,3820) IDLE(ready,160)
        Owned mutexes:
        Last reset 00:13:36 ago, cause: reset button or watchdog
        Last software reset at 2019-12-30 22:03, reason: User, spinning module GCodes, available RAM 10824 bytes (slot 2)
        Error status: 0
        Free file entries: 9
        SD card longest block write time: 9.2ms, max retries 0
        MCU temperature: min 39.6, current 39.9, max 40.2
        Supply voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 2: ok, SG min/max not available
        Driver 4: standstill, SG min/max 0/327
        Date/time: 2019-12-31 00:20:24
        Cache data hit count 3181261680
        Slowest loop: 30.40ms; fastest: 0.08ms
        Hiccups: 0, FreeDm: 168, MinFreeDm: 142, MaxWait: 2ms
        === DDARing ===
        Scheduled moves: 109, completed moves: 107, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
        Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
        Heater 2 is on, I-accum = 0.3
        Segments left: 0
        Movement lock held by autopause
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        autopause is idle in state(s) 19
        Code queue is empty.
          deckingman @Government_Bacon
          @Government_Bacon Looking at your config.g file, it seems that you only have a single tool defined and that is tool#1. So my best guess is that your slicer puts a TO command in because tool 0 usually the default. Try either putting a T1 command in your slicer start code or better still, define your one and only tool to be TO instead of T1.
            Government_Bacon @deckingman
            @deckingman the tooling is set up right.
            • Vetiundefined
              Veti
              how quickly? can you show the graph?
                @Veti i think i have fixed it i droped the motor mA down and i has been stable
                a63c9c0c-6f12-411c-b240-80c34ce8db8d-image.png i guess not it still drops
                • Vetiundefined
                  Veti
                  M307 H2
                  Heater 2 model: gain 368.8, time constant 138.3, dead time 6.4, max PWM 1.00, calibration voltage 12.1, mode PID, inverted no, frequency default
                  Computed PID parameters for setpoint change: P10.5, I0.352, D46.9
                  Computed PID parameters for load change: P10.
                  where are you saving those values? there is no M501 in your config.
                    @Veti I noticed that it wasn't there and I tried adding it but didn't work is there a line of code I should put in?
                      Phaedrux Moderator @Government_Bacon
                      What didn't work?
                      After running the auto tune, send M500, then in config.g at the bottom of the file add M501.
                      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
                        Government_Bacon @Phaedrux
                        @Phaedrux i did that and this what i gotc37b1f06-5448-4660-b897-fed36cbda51f-image.png
                          That looks right for the first part. Now you need to edit config.g and add the M501 at the end.
                            @Phaedrux ok got the m500 to work and it still heater falted you can see at the end on the chart it drop really hard and then wasnt droping as hard 6287d8db-b772-4d2d-88fb-b7d3f7594d12-image.png
                              Just to verify can you post your config-override.g?
                              Is the part cooling fan running at all during that drop?
                              Did you run the tune with the part cooling fan on at normal print speeds?
                              What kind of hotend and thermistor are you using?
                              Have you physically checked the wiring?
                                @Phaedrux the cooling fan was running full blast on the auto tune and i have a sock on and the fan was off when printing
                                ; config-override.g file generated in response to M500 at 2019-12-31 16:54
                                ; Heater model parameters
                                M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                                M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H2 A363.5 C140.9 D4.4 S1.00 V12.1 B0
                                M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                G10 L2 P1 X0.00 Y0.00 Z0.00
                                G10 L2 P2 X0.00 Y0.00 Z0.00
                                G10 L2 P3 X0.00 Y0.00 Z0.00
                                G10 L2 P4 X0.00 Y0.00 Z0.00
                                G10 L2 P5 X0.00 Y0.00 Z0.00
                                G10 L2 P6 X0.00 Y0.00 Z0.00
                                G10 L2 P7 X0.00 Y0.00 Z0.00
                                G10 L2 P8 X0.00 Y0.00 Z0.00
                                G10 L2 P9 X0.00 Y0.00 Z0.00
                                  Government_Bacon
                                  i am using the bond tech cr-10 direct drive it has a e3d v6 and i have checked the wiring and my heat bed is independent from the main board
                                  Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  • Vetiundefined
                                    Veti @Government_Bacon
                                    what do you mean by independent of the main board?
                                      @Veti it is its own system you plug it in to the wall and set it manual
                                        What is the heater fault error message shown in the console?
                                          Government_Bacon
                                          it was printing fine and then just drop temp
                                            e3d v6
                                            Is the thermistor cartridge and heater cartridge secured firmly? Have you removed them to check them?
