    heater fault when print starts
    1.4k
      deckingman @Government_Bacon
      @Government_Bacon Looking at your config.g file, it seems that you only have a single tool defined and that is tool#1. So my best guess is that your slicer puts a TO command in because tool 0 usually the default. Try either putting a T1 command in your slicer start code or better still, define your one and only tool to be TO instead of T1.
      Government_Baconundefined 1 Reply Last reply Reply Quote 0
      • Government_Baconundefined
        Government_Bacon @deckingman
        @deckingman the tooling is set up right.
        • Vetiundefined
          Veti
          @Government_Bacon said in heater fault when print starts:
          the temp starts to drop quickly
          how quickly? can you show the graph?
            Government_Bacon @Veti
            @Veti i think i have fixed it i droped the motor mA down and i has been stable
            a63c9c0c-6f12-411c-b240-80c34ce8db8d-image.png i guess not it still drops
            • Vetiundefined
              Veti
              M307 H2
              Heater 2 model: gain 368.8, time constant 138.3, dead time 6.4, max PWM 1.00, calibration voltage 12.1, mode PID, inverted no, frequency default
              Computed PID parameters for setpoint change: P10.5, I0.352, D46.9
              Computed PID parameters for load change: P10.
              where are you saving those values? there is no M501 in your config.
                @Veti I noticed that it wasn't there and I tried adding it but didn't work is there a line of code I should put in?
                  Phaedrux Moderator @Government_Bacon
                  What didn't work?
                  After running the auto tune, send M500, then in config.g at the bottom of the file add M501.
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
                    Government_Bacon @Phaedrux
                    @Phaedrux i did that and this what i gotc37b1f06-5448-4660-b897-fed36cbda51f-image.png
                      That looks right for the first part. Now you need to edit config.g and add the M501 at the end.
                        @Phaedrux ok got the m500 to work and it still heater falted you can see at the end on the chart it drop really hard and then wasnt droping as hard 6287d8db-b772-4d2d-88fb-b7d3f7594d12-image.png
                          Just to verify can you post your config-override.g?
                          Is the part cooling fan running at all during that drop?
                          Did you run the tune with the part cooling fan on at normal print speeds?
                          What kind of hotend and thermistor are you using?
                          Have you physically checked the wiring?
                            @Phaedrux the cooling fan was running full blast on the auto tune and i have a sock on and the fan was off when printing
                            ; config-override.g file generated in response to M500 at 2019-12-31 16:54
                            ; Heater model parameters
                            M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                            M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                            M307 H2 A363.5 C140.9 D4.4 S1.00 V12.1 B0
                            M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                            M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                            M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                            M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                            G10 L2 P1 X0.00 Y0.00 Z0.00
                            G10 L2 P2 X0.00 Y0.00 Z0.00
                            G10 L2 P3 X0.00 Y0.00 Z0.00
                            G10 L2 P4 X0.00 Y0.00 Z0.00
                            G10 L2 P5 X0.00 Y0.00 Z0.00
                            G10 L2 P6 X0.00 Y0.00 Z0.00
                            G10 L2 P7 X0.00 Y0.00 Z0.00
                            G10 L2 P8 X0.00 Y0.00 Z0.00
                            G10 L2 P9 X0.00 Y0.00 Z0.00
                              Government_Bacon
                              i am using the bond tech cr-10 direct drive it has a e3d v6 and i have checked the wiring and my heat bed is independent from the main board
                              Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • Vetiundefined
                                Veti @Government_Bacon
                                what do you mean by independent of the main board?
                                  @Veti it is its own system you plug it in to the wall and set it manual
                                    What is the heater fault error message shown in the console?
                                      Government_Bacon
                                      it was printing fine and then just drop temp
                                        e3d v6
                                        Is the thermistor cartridge and heater cartridge secured firmly? Have you removed them to check them?
                                          @Phaedrux yes the thermistor is brand new and the heater is good and both are mounted good
                                          • Vetiundefined
                                            Veti
                                            whats the resistance of the heater cartrige?
