    DWC2 bug: heater names not displayed correctly
    Duet Web Control
    8
    23
    1.1k
      deckingman @wilriker
      @wilriker said in DWC2 bug: heater names not displayed correctly:
      I cannot see the issue. It looks OK to me. Can you explain a bit more what you are expecting to see?
      I agree that it's difficult to understand without more information but if the OP has assigned sensor names using M308 (RRF3) or M305 (RRF2) then the sensor name should display on the temperature chart rather than the default "Heater1 etc". It works for me using DWC 2.0.4 and RRF 3 so a little more information from the OP is needed.
      remopiniundefined 1 Reply Last reply Reply Quote 0
      • remopiniundefined
        remopini
        Actually, on RRF3, if you rename a heater (using M308), it fails to display correctly:
        Config:
        M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138
        M308 S1 P"e0temp" Y"thermistor" T100000 B4138
        Display:
        • remopiniundefined
          remopini @deckingman
          @deckingman If you look carefully at the OP image, you can see that the names are wrong (heater 1, heater 1, heater 2 instead of heater 1, heater 2, heater 3)
          • piperswundefined
            pipersw
            Same issue on RRF3, If I name Heater 0 and Heater 1, name is missing in Tools window
            • remopiniundefined
              remopini @pipersw
              @pipersw That is literally what I just wrote 😉
                deckingman @remopini
                @remopini Yes I know that DWC is showing the default names. The information that's missing is what names you have assigned and how you have made those assignments. The board, firmware and DWC versions that you are using would also help. For info, heater names are displaying correctly for me using RRF 3 and DWC 2 so I suspect that it might be a configuration issue rather than a bug.
                wilrikerundefined remopiniundefined 2 Replies Last reply Reply Quote 1
                • wilrikerundefined
                  wilriker @deckingman
                  @deckingman Hey Ian, I think the issue is that on the screenshot in the first post it shows "Heater 1" twice in the Tool box. Instead of "Heater 1" and "Heater 2". It is correct above the temperature chart.
                  But you are right that essential information on versions and related config is missing.
                  Manuel
                  My Tool Collection
                    @wilriker In that case, then we also need to know how the tool has been defined.
                    • remopiniundefined
                      @deckingman if you look at my screenshot and post, you can see what I configured. Using the latest available 3.0 firmware bundle from github.
                      • wilrikerundefined
                        wilriker @remopini
                        @remopini We still need to know what "platform" you run it on. Available candidates are
                        • Duet3 + SBC
                        • Duet3 or Duet2 (Wifi, Ethernet, Maestro) in standalone mode
                        Also a full config.g can never hurt.
                        Manuel
                        My Tool Collection
                        • remopiniundefined
                          remopini @wilriker
                          @wilriker Sure, here you go:
                          Board: Board: Duet Ethernet 1.04
                          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
                          DWC: Duet Web Control 2.0.4
                          Sanitized config.g:
                          M569 P0 S0                              ; physical drive 0 goes backwards (X)
                          M569 P1 S0                              ; physical drive 1 goes backwards (Y)
                          M569 P2 S1                              ; physical drive 2 goes forwards (Z)
                          M569 P3 S0                              ; physical drive 3 goes backwards (E0)
                          M584 X0 Y1 Z2 E3                        ; set drive mapping
                          M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
                          M92 X80.00 Y80.00 Z400.00 E450.00       ; set steps per mm
                          M566 X900.00 Y900.00 Z120.00 E120.00    ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z1800.00 E1200.00; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
                          M906 X600 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30                                 ; Set idle timeout
                          M208 X0 Y0 Z0 S1                        ; set axis minima
                          M208 X300 Y300 Z400 S0                  ; set axis maxima
                          M574 X1 S1 P"!xstop"
                          M574 Y1 S1 P"!ystop"
                          M574 Z1 S1 P"!zstop"
                          M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
                          M557 X20:280 Y20:280 S65                ; define mesh grid
                          G29 S1                                  ; read mesh grid from file
                          M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                          M307 H0 B0 S1.00                               ; disable bang-bang mode for the nozzle heater and set PWM limit
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                          M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                          M307 H1 B0 S1.00                               ; disable bang-bang mode for the nozzle heater and set PWM limit
                          M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P1 S0 I0 F500 H-1                  ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P2 S1 I0 F500 H1 T45               ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M563 P0 D0 H1 F1                        ; define tool 0 -> using FAN 1 (fritzed Fan 0)
                          G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                          G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                          M912 P0 S-3.2                           ; Calibrated MCU Temperature (reading is 3.2° too high)
                          M501                                    ; load saved parameters from non-volatile memory
                          config-override.g
                          M307 H0 A476.5 C791.3 D4.8 S1.00 V23.9 B0
                          M307 H1 A1167.0 C239.9 D8.4 S1.00 V23.5 B0
                          • SIamundefined
                            SIam
                            The same Problem here
                            Board: Duet WiFi 1.02 or later + DueX5
                            Version von Duet WiFi Server: 1.23
                            in dwc1 the names are shown correctly
                            in dwc2 the names are missing so its impossible to switch betwen on/aktiv/standby
                            config.g
                            ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Jan 05 2020 16:17:09 GMT+0100 (Mitteleuropäische Normalzeit)
                            G90                                                 ; send absolute coordinates...
                            M83                                                 ; ...but relative extruder moves
                            M550 P"hypercube"                                   ; set printer name
                            M667 S1                                             ; select CoreXY mode
                            M552 S1                                             ; enable network
                            M586 P0 S1                                          ; enable HTTP
                            M586 P1 S1                                          ; disable FTP
                            M586 P2 S1                                          ; disable Telnet
                            M569 P0 S0                                          ; physical drive 0 = X goes backwards
                            M569 P1 S0                                          ; physical drive 1 = Y goes backwards
                            M569 P2 S1                                          ; physical drive 2 = Z goes forwards
                            M569 P3 S1                                          ; physical drive 3 = E0 goes forwards
                            M569 P4 S1                                          ; physical drive 4 = Z goes forwards
                            M569 P5 S0                                          ; physical drive 5 = Z goes backwards
                            M569 P6 S1                                          ; physical drive 6 = E1 goes forwards
                            M584 X0 Y1 Z2:4:5 E3                                  ; set drive mapping
                            M671 X0:380:0 Y52:190:327 S3 F1.0; Leitspindeln links und rechts von der X-Achse ****
                            M350 X16 Y16 Z16:16:16 E16 I1                          ; configure microstepping with interpolation
                            M92 X200.60 Y200.60 Z797:797:797 E2666.67           ; set steps per mm
                            M566 X600.00 Y600.00 Z300.00 E40.00          ; set maximum instantaneous speed changes (mm/min)
                            M203 X30000.00 Y30000.00 Z1200.00 E4800.00     ; set maximum speeds (mm/min)
                            M201 X2000.00 Y2000.00 Z500.00 E120.00          ; set accelerations (mm/s^2)
                            M906 X1000 Y1000 Z1500.00 E500                        ; set motor currents (mA)
                            M84 S0                                              ; Disable motor idle current reduction
                            M208 X-1 Y0 Z-1 S1                                  ; set axis minima
                            M208 X400 Y370 Z450 S0                              ; set axis maxima
                            M574 X1 S1 P"xstop"                                 ; configure active-high endstop for low end on X via pin xstop
                            M574 Y1 S1 P"ystop"                                 ; configure active-high endstop for low end on Y via pin ystop
                            M558 P8 R0.4 C"^!zprobe.in+zprobe.mod" H5 F450 T6000 ;
                            G31 P500 X0 Y0 Z-0.25                                 ; set Z probe trigger value, offset and trigger height
                            M557 X15:390 Y15:370 S25                            ; define mesh grid
                            M308 S0 P"bedtemp" Y"thermistor" A"Heizbett" T100000 B3950      ; configure sensor 0 as thermistor on pin bedtemp
                            M143 H0 S100                                        ; set temperature limit for heater 0 to 100C
                            M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4276       ; configure sensor 1 as thermistor on pin e0temp
                            M950 F0 C"fan0" Q25500 ;H-1                              ; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S0 H-1 F25500 C"Bauteilkühlung"                                  ; set fan 0 value. Thermostatic control is turned on
                            M950 F1 C"fan1" Q75 T45 ;H1                              ; create fan 1 on pin fan1 and set its frequency
                            M106 P1 S1 H1 T45 F75 C"Hotend"                                    ; set fan 1 value. Thermostatic control is turned off
                            M950 F2 C"fan2" Q250 ;H-1                              ; create fan 2 on pin fan2 and set its frequency
                            M106 P2 S0 H-1 F250 C"LED"                                  ; set fan 2 value. Thermostatic control is turned off
                            M563 P0 D0 H1 F0                                  ; define tool 0              *****
                            T0                                                  ; select first tool
                            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                            Duet WiFi Server: 1.26
                            Duet Web Control 3.4.0beta4 (2021-09-27)
                            remopiniundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                            • remopiniundefined
                              remopini @SIam
                              @SIam You can still switch (by clicking on the blue "Bett" or "Werkzeug 0"), but it is highly annoying 🙂
                              • SIamundefined
                                SIam
                                ok you are right 😮
                                • wilrikerundefined
                                  wilriker
                                  OK, since in all cases there is no DuetSoftwareFramework in play this means it's a bug in either RRF or DWC. I'll take a quick look at it.
                                  EDIT: First result: DWC receives the list of correct names but fails to show them correctly in all places.
                                  Manuel
                                  My Tool Collection
                                  • DIY-O-Sphereundefined
                                    DIY-O-Sphere @SIam
                                    @SIam
                                    I have named tools (not the fans) and the heaters are clickable.
                                    ~~I see it that way, the fan names are displayed In the graph and the tool names are displayed in the menu. And they can differ.
                                    Maybe the graph should also display tools and not fans.
                                    Edit: The fan names are only displayed when no tool names are defined.~~
                                    (UTC+1)
                                    • remopiniundefined
                                      remopini @DIY-O-Sphere
                                      @DIY-O-Sphere It's not fans, it's heaters and showing tools instead of heaters in a temperature chart is a bad idea, because there isn't necessarily one heater for one tool (a tool could have 2 or more heaters or none).
                                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                        DIY-O-Sphere @remopini
                                        @remopini
                                        You are right. Forget about my post.
                                        I thought that are the fan names, but that is not correct. ace702ec-93cf-4618-8df5-8e403390ef69-grafik.png
                                        Who can read is clearly at an advantage. 👎
                                        (UTC+1)
                                        • SIamundefined
                                          SIam
                                          maybe another bug :
                                          on the page /Job/Status only one from two (*three) Fan's shown:
                                          here you see two fan's are enabled
                                          if i only disable the bauteilkühler then i get the message that there are no fans
                                          on the main page i think it's ok *because the third fan is for the hotend
                                          • chrishammundefined
                                            chrishamm administrators
                                            Can you please check if this is fixed in DWC 2.0.6?
                                            Duet software engineer
