    New firmware 3.01-RC2 available
    Beta Firmware
    16
    45
    2.4k
    • spllgundefined
      spllg
      fyi: M308 S1 P"temp1" Y"thermistor" B4725 C7.06e-8 seems to be working in rc2
      • supernovaeundefined
        supernovae
        Updated on a CoreXY and no problems. Test cube looks great.
        • arhiundefined
          arhi
          so far so good 😄
          • Adrian52undefined
            Adrian52 @dc42
            @dc42 fan rpm showing up in dwc. Thank you very much.
              deckingman
              I haven't seen anything in the release notes so I guess the answer is still no, but is M303 heater tuning for remote heaters implemented yet?
                dc42 administrators @deckingman
                @deckingman said in New firmware 3.01-RC2 available:
                Not yet, however I now have an implementation plan for it.
                • arhiundefined
                  arhi
                  might found a bug:
                  all files uploaded since RC2 have N/A for "last modified" time/date
                  M905 show proper date/time on the board
                  • TurtlePrintundefined
                    TurtlePrint
                    The console is showing Stack Overflow errors when trying to deploy the BLTouch from a macro that that was started from a Trigger and calls another macro. The probe then fails to deploy.
                    Process:
                    A state change occurs on "e1stop" and trigger7.g is run. It calls "UnloadFilament.g" which then runs "CheckifHomed.g". During the homing operation the BL Touch probe fails to deploy and the bed crashes. The console shows 2 Stack Overflow errors when the probe attempts to deploy.
                    CheckifHomed.g - Runs fine when run on it's own
                    CheckifHomed.g - Runs fine when called from "UnloadFilament.g" if UnloadFilament was started from the macro menu
                    CheckifHomed.g - Runs fine when called from startcode.g
                    CheckifHomed.g - Runs fine when called directly from trigger7.g
                    If trigger7.g is moved to the Macro Folder and started manually everything works fine.
                    config.g Info
                    M950 J3 C"e1stop"		;Load Buton
                    M581 T7 P3  	;Runs trigger7.g file when pressed - First step of Unload process
                    Please let me know if you need any more information.
                      dc42 administrators @arhi
                      @arhi said in New firmware 3.01-RC2 available:
                      might found a bug:
                      Strange, it's working for me, I just tested uploading to Duet WiFi and to Duet 3 in standalone mode. Are you using DWC 2.0.7? Which Duet?
                        dc42 administrators @TurtlePrint
                        @TurtlePrint said in New firmware 3.01-RC2 available:
                        Looks like you are exceeding the maximum allowed stack depth. Every macro file called (including homing macros and the Z probe deploy/retract macro) uses one level. I can increase it in the next RC.
                        TurtlePrintundefined 1 Reply Last reply Reply Quote 0
                        • arhiundefined
                          arhi @dc42
                          @dc42 said in New firmware 3.01-RC2 available:
                          might found a bug:
                          Board: Duet Ethernet 1.02 or later
                          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC2 (2020-02-18b1)
                          Duet Web Control 2.0.7
                          but looks like when I upload from DWC (upload gcode file button) it works ok but when I curl it to the duet
                          @echo off
                          for %%a in (%1) do (
                              set filepath=%%~dpa
                              set filename=%%~na
                              set extension=%%~xa
                          set if=%filepath%%filename%%extension%
                          G:\bin\curl-7.50.3-win64-mingw\bin\curl.exe -G --data-urlencode gcode=M30"%filename%%extension%" http://ender5.local.lan/rr_gcode
                          G:\bin\curl-7.50.3-win64-mingw\bin\curl.exe  --data-binary "@%if%" "http://ender5.local.lan/rr_upload?name=gcodes/%filename%%extension%"
                          the datetime is not there
                            There is an additional parameter to the rr_upload command that specifies the date/time to use for the time stamp.
                            What was the latest version of RRF for which the time stamp was set when you uploaded files using curl?
                            EDIT: I just ran the following:
                            curl.exe --data-binary "@symarchive.bat" "http://192.168.1.126/rr_upload?name=gcodes/symarchive.bat"
                            and it did set the time stamp on the uploaded file.
                            Note, you need to have connected to the Duet with DWC before you do the upload using curl, otherwise the date/time will not be set on the Duet. Or you can pass the time stamp as an extra parameter, like this:
                            C:\Eclipse\Firmware>curl.exe --data-binary "@symarchive.bat" "http://192.168.1.126/rr_upload?name=gcodes/symarchive.bat&time=2013-04-05T11:12:13"
                            arhiundefined 1 Reply Last reply Reply Quote 1
                              TurtlePrint @dc42
                              @dc42 Is it possible to have the Duet "Emergency Stop" when a Stack overflow occurs?
                                I can quite easily make it abandon the current print job.
                                • arhiundefined
                                  arhi @dc42
                                  ah, didn't know that
                                  The update to the RRF and script for s3d came roughly at the same time so I started using CURL when I updated to RC2
                                  That's the missing link! Thanks, that solved the problem 😄
                                  Apologies for the false alarm.
                                  Will modify the script to send proper time value, thanks for example.
                                  Is there a way to tell DWC to refresh file list using curl?
                                    Not AFAIK, but @chrishamm might know otherwise.
                                    • Luke'sLaboratoryundefined
                                      Luke'sLaboratory
                                      Hey - will state.previoustool be persistent through power cycle/M999?
                                      It would be nice if there could be a condition check on homing to make sure that the previous tool is re-docked before attempting a home, to prevent damage to tool (especially from inattentive tinkerers)
                                      Luke
                                      http://lukeslab.online
                                        dc42 administrators @Luke'sLaboratory
                                        @Luke-sLaboratory said in New firmware 3.01-RC2 available:
                                        The only things that persist across a restart are data stored in config-override.g when you run M500, and the software reset data.
                                        For tool changers I suggest using microswitches to detect when tools are docked, or a microswitch to detect when a tool is loaded.
                                        TCundefined 1 Reply Last reply Reply Quote 0
                                        • TCundefined
                                          TC @dc42
                                          @dc42 Talking about tool changes... is it possible also to have a nexttool object? That would make it possible to already preheat the next tool to be used.
                                            dc42 administrators @TC
                                            @TC said in New firmware 3.01-RC2 available:
                                            A facility to read the GCode stream ahead so that tools can be preheated and filament mixes changed in advanced is planned for Duet 3. There probably isn't enough RAM to fit it in Duet 2.
