    Duet 3 Tool Board
    Order discussion
    16
    44
    3.1k
    • mundsenundefined
      mundsen
      I`m going to use Duet3 + ToolBoard
      Then I have to get a RJ11 cable (the cable kit includethe other wires I need?)
      Add a 5A (car fuse) for the power wires
      Terminate the CanBus using a 120 Ohm resistor? where? between pin 3-4?
        dc42 administrators @mundsen
        @mundsen said in Duet 3 Tool Board:
        Yes, between pins 3-4 of the 4-pin CAN connector on the Tool Board.
        mundsenundefined 1 Reply Last reply Reply Quote 1
          A Former User
          @T3P3Tony
          Is there a better picture of the connector pack available ?
          • mundsenundefined
            mundsen @dc42
            @dc42 all 4 wires from duet 3 connected or only 1 and 2
            A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
              A Former User @mundsen
              does this answer the question?
              https://raw.githubusercontent.com/Duet3D/Hardware/master/Duet3/Duet3_MB6HC_schematic_v1.0.pdf
                If using one tool board: connect pins 3 and 4 (the middle 2 pins) of the RJ11 connector on the Duet to pins 4 and 3 of the tool board, making sure you get them the right way round i.e. CAN1_H in the Duet to CANH on the tool board, and connect a 120R termination resistor between pins 1 and 2 of the connector on the tool board. [Pins 2 and 4 of the tool board are interchangable, as are pins 1 and 3.] Don't connect anything to pins 2 and 5 of the RJ11 connector on the Duet.
                To clarify this, I've uploaded the tool breakout (distribution) board schematic to:
                https://github.com/Duet3D/Duet3-Tool-Distribution-Board/tree/master/Tool Distribution v0.5
                (edited by T3P3Tony to point to new locations for Duet 3 Schematics)
                  A Former User @dc42
                  To clarify this, I've uploaded the tool breakout (distribution) board schematic to https://github.com/Duet3D/Hardware/tree/master/Duet3.
                  And in case anyone is wondering why a resistor is required. have a read of the following link Terminal Resistor
                  • Danalundefined
                    Danal
                    @CaLviNx I originally read you "wondering why... " as just "why...". You linked to a good source!
                    I'll add this thought to re-enforce the potential effects!
                    The resistors stop reflections at the end(s) of the cable. Often, on short cables, the bus will seem to run OK without them.
                    However... Suppose your printer works great, and unknown to you is right on the edge of signal reflection corrupting the CAN bus. Then days or even months down the road, the temperature/humidity changes, or the connection changes (maybe it gets better)... and, bang, the printer starts acting completely flakey and unreliable.
                    • tekkydaveundefined
                      tekkydave
                      Anyone old enough to remember SCSI hard disk? They had a SIP resistor pack in the last drive on the 50w ribbon cable.
                      ~ tekkydave ~
                      D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                      FreeCAD, PrusaSlicer
                      Dougal1957undefined timcurtis67undefined 2 Replies Last reply Reply Quote 1
                      • Dougal1957undefined
                        Dougal1957 @tekkydave
                        @tekkydave More than old enough lol and still work on kit that use SCSI Buses so well aware of bus terminations
                        • timcurtis67undefined
                          timcurtis67 @tekkydave
                          @tekkydave said in Duet 3 Tool Board:
                          I must be old, I remember the IDE drives and even 5 1/4" floppies... 😀
                          But I never used the big 8" stuff... 😀 😀
                          Dougal1957undefined dc42undefined 2 Replies Last reply Reply Quote 0
                            Dougal1957 @timcurtis67
                            @timcurtis67 you never worked PDP11's then? Mind I can go back even further to the times of an IBM 1130 which used EBCDIC punched cards or a frantic Argos 500 with handlers and punched tape.
                            • mundsenundefined
                              mundsen
                              Anyone having the stp files for the 3 and 4 pin JST ZH + the 6 pin (stepper output) + the button?
                              I`m making a simple (not 100% accurate) ToolBoard 3D model that I can use in my designs + when designing a housing for it
                                dc42 administrators @timcurtis67
                                @timcurtis67 said in Duet 3 Tool Board:
                                I did! [Cue "You were lucky!" spoken with a Yorkshire accent].
                                I also remember when we asked one of our customers for a copy of their backup disks (this was before email) so we could diagnose the issue they reported. Next day it arrived by post... a perfect photocopy of a pair of 8" floppy disks!
                                zaptaundefined daaveryundefined 2 Replies Last reply Reply Quote 2
                                • zaptaundefined
                                  zapta @dc42
                                  @dc42 said in Duet 3 Tool Board:
                                  A page with pixels and a 8"" floppy represent about the same number of bits. 😉
                                  Seriously, I may missed it, what are the dimension of this board?
                                    dc42 administrators @zapta
                                    @zapta said in Duet 3 Tool Board:
                                    As shown at https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board.
                                    • daaveryundefined
                                      daavery @dc42
                                      @dc42 https://www.dropbox.com/s/eh33zxsda53bvhv/2020-02-21 13.56.06.jpg?dl=0 look familiar?
                                      https://www.dropbox.com/s/oamu8uhdz134qj6/2020-02-21 13.55.32.jpg?dl=0 from our antique computing pile at work
                                        dc42 administrators @daavery
                                        @daavery said in Duet 3 Tool Board:
                                        Double sided 8 inch floppy? Luxury!
                                        daaveryundefined 1 Reply Last reply Reply Quote 0
                                        • daaveryundefined
                                          daavery @dc42
                                          @dc42 double sided double density 1.2M
                                          • gtj0undefined
                                            gtj0
                                            @dc42 Although I don't see a statement to the effect, I'm assuming IO0 is meant for the Z probe and IO1 the filament sensor yeah? Can IO1 be used as an X endstop instead?
