    Duet 3 Tool Board
    Order discussion
    16
    44
    3.1k
    • mundsenundefined
      mundsen @dc42
      @dc42 all 4 wires from duet 3 connected or only 1 and 2
      A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
        A Former User @mundsen
        @mundsen said in Duet 3 Tool Board:
        does this answer the question?
        https://raw.githubusercontent.com/Duet3D/Hardware/master/Duet3/Duet3_MB6HC_schematic_v1.0.pdf
          dc42 administrators @mundsen
          If using one tool board: connect pins 3 and 4 (the middle 2 pins) of the RJ11 connector on the Duet to pins 4 and 3 of the tool board, making sure you get them the right way round i.e. CAN1_H in the Duet to CANH on the tool board, and connect a 120R termination resistor between pins 1 and 2 of the connector on the tool board. [Pins 2 and 4 of the tool board are interchangable, as are pins 1 and 3.] Don't connect anything to pins 2 and 5 of the RJ11 connector on the Duet.
          To clarify this, I've uploaded the tool breakout (distribution) board schematic to:
          https://github.com/Duet3D/Duet3-Tool-Distribution-Board/tree/master/Tool Distribution v0.5
          (edited by T3P3Tony to point to new locations for Duet 3 Schematics)
            A Former User @dc42
            To clarify this, I've uploaded the tool breakout (distribution) board schematic to https://github.com/Duet3D/Hardware/tree/master/Duet3.
            And in case anyone is wondering why a resistor is required. have a read of the following link Terminal Resistor
            • Danalundefined
              Danal
              @CaLviNx I originally read you "wondering why... " as just "why...". You linked to a good source!
              I'll add this thought to re-enforce the potential effects!
              The resistors stop reflections at the end(s) of the cable. Often, on short cables, the bus will seem to run OK without them.
              However... Suppose your printer works great, and unknown to you is right on the edge of signal reflection corrupting the CAN bus. Then days or even months down the road, the temperature/humidity changes, or the connection changes (maybe it gets better)... and, bang, the printer starts acting completely flakey and unreliable.
              • tekkydaveundefined
                tekkydave
                Anyone old enough to remember SCSI hard disk? They had a SIP resistor pack in the last drive on the 50w ribbon cable.
                ~ tekkydave ~
                D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                FreeCAD, PrusaSlicer
                Dougal1957undefined timcurtis67undefined 2 Replies Last reply Reply Quote 1
                • Dougal1957undefined
                  Dougal1957 @tekkydave
                  @tekkydave More than old enough lol and still work on kit that use SCSI Buses so well aware of bus terminations
                  • timcurtis67undefined
                    timcurtis67 @tekkydave
                    @tekkydave said in Duet 3 Tool Board:
                    I must be old, I remember the IDE drives and even 5 1/4" floppies... 😀
                    But I never used the big 8" stuff... 😀 😀
                    Dougal1957undefined dc42undefined 2 Replies Last reply Reply Quote 0
                      Dougal1957 @timcurtis67
                      @timcurtis67 you never worked PDP11's then? Mind I can go back even further to the times of an IBM 1130 which used EBCDIC punched cards or a frantic Argos 500 with handlers and punched tape.
                      • mundsenundefined
                        mundsen
                        Anyone having the stp files for the 3 and 4 pin JST ZH + the 6 pin (stepper output) + the button?
                        I`m making a simple (not 100% accurate) ToolBoard 3D model that I can use in my designs + when designing a housing for it
                          dc42 administrators @timcurtis67
                          @timcurtis67 said in Duet 3 Tool Board:
                          I did! [Cue "You were lucky!" spoken with a Yorkshire accent].
                          I also remember when we asked one of our customers for a copy of their backup disks (this was before email) so we could diagnose the issue they reported. Next day it arrived by post... a perfect photocopy of a pair of 8" floppy disks!
                          zaptaundefined daaveryundefined 2 Replies Last reply Reply Quote 2
                          • zaptaundefined
                            zapta @dc42
                            @dc42 said in Duet 3 Tool Board:
                            A page with pixels and a 8"" floppy represent about the same number of bits. 😉
                            Seriously, I may missed it, what are the dimension of this board?
                              dc42 administrators @zapta
                              @zapta said in Duet 3 Tool Board:
                              As shown at https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board.
                              • daaveryundefined
                                daavery @dc42
                                @dc42 https://www.dropbox.com/s/eh33zxsda53bvhv/2020-02-21 13.56.06.jpg?dl=0 look familiar?
                                https://www.dropbox.com/s/oamu8uhdz134qj6/2020-02-21 13.55.32.jpg?dl=0 from our antique computing pile at work
                                  dc42 administrators @daavery
                                  @daavery said in Duet 3 Tool Board:
                                  Double sided 8 inch floppy? Luxury!
                                  daaveryundefined 1 Reply Last reply Reply Quote 0
                                  • daaveryundefined
                                    daavery @dc42
                                    @dc42 double sided double density 1.2M
                                    • gtj0undefined
                                      gtj0
                                      @dc42 Although I don't see a statement to the effect, I'm assuming IO0 is meant for the Z probe and IO1 the filament sensor yeah? Can IO1 be used as an X endstop instead?
                                      • blarblesundefined
                                        blarbles
                                        Am I understanding correctly that having 4 tool boards would allow up to 10 stepper motors to be controlled (6 from the Duet3 and 4 additional from the tool boards)?
                                          deckingman @blarbles
                                          @blarbles said in Duet 3 Tool Board:
                                          I'd say that is correct - providing those additional 4 motors are all extruders. Funnily enough, @dc42 has just posted something on his WordPress site to that effect https://miscsolutions.wordpress.com/2020/03/02/converting-the-e3d-tool-changer-to-duet-3-with-hemera-tools-part-1/
                                            A Former User @gtj0
                                            @gtj0 said in Duet 3 Tool Board:
                                            afaik the only special function is IO0 needs to be used if connecting a PanelDue, beyond that you can configure any input to be a end stop or z probe or whatever.
