Duet 3 Tool Board
@tekkydave More than old enough lol and still work on kit that use SCSI Buses so well aware of bus terminations
@tekkydave said in Duet 3 Tool Board:
Anyone old enough to remember SCSI hard disk? They had a SIP resistor pack in the last drive on the 50w ribbon cable.
I must be old, I remember the IDE drives and even 5 1/4" floppies...
But I never used the big 8" stuff...
@timcurtis67 you never worked PDP11's then? Mind I can go back even further to the times of an IBM 1130 which used EBCDIC punched cards or a frantic Argos 500 with handlers and punched tape.
@timcurtis67 said in Duet 3 Tool Board:
I did! [Cue "You were lucky!" spoken with a Yorkshire accent].
I also remember when we asked one of our customers for a copy of their backup disks (this was before email) so we could diagnose the issue they reported. Next day it arrived by post... a perfect photocopy of a pair of 8" floppy disks!
@dc42 said in Duet 3 Tool Board:
A page with pixels and a 8"" floppy represent about the same number of bits.
Seriously, I may missed it, what are the dimension of this board?
@zapta said in Duet 3 Tool Board:
As shown at https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board.
@dc42 https://www.dropbox.com/s/eh33zxsda53bvhv/2020-02-21 13.56.06.jpg?dl=0 look familiar?
https://www.dropbox.com/s/oamu8uhdz134qj6/2020-02-21 13.55.32.jpg?dl=0 from our antique computing pile at work
@daavery said in Duet 3 Tool Board:
Double sided 8 inch floppy? Luxury!
@dc42 double sided double density 1.2M
@dc42 Although I don't see a statement to the effect, I'm assuming IO0 is meant for the Z probe and IO1 the filament sensor yeah? Can IO1 be used as an X endstop instead?
Am I understanding correctly that having 4 tool boards would allow up to 10 stepper motors to be controlled (6 from the Duet3 and 4 additional from the tool boards)?
@blarbles said in Duet 3 Tool Board:
I'd say that is correct - providing those additional 4 motors are all extruders. Funnily enough, @dc42 has just posted something on his WordPress site to that effect https://miscsolutions.wordpress.com/2020/03/02/converting-the-e3d-tool-changer-to-duet-3-with-hemera-tools-part-1/
@gtj0 said in Duet 3 Tool Board:
afaik the only special function is IO0 needs to be used if connecting a PanelDue, beyond that you can configure any input to be a end stop or z probe or whatever.
@bearer said in Duet 3 Tool Board:
Yeah, that's on the main board but I know in the past there have been restrictions around having an axis's endstop on the same board as the stepper driver(s) so I wanted to make sure that if the axes motors were on the main board that the tool board's IO1 could be used as an X endstop.
Verify by trying it, but reading all the release notes, this should work.
@Danal said in Duet 3 Tool Board:
I don't have one and can't use one if it doesn't work
@Dougal1957 said in Duet 3 Tool Board:
I have fond memories of the 1130. I can still remember the great sounds the card reader and line printer made in unison when a coldstart card was read.
I just remembered the sound of cash registers of that era as well. Things are so damn quiet now.
I have one main board (6HC), two expansions (3HC) and four tool boards (1HC). I'd be happy to give it a try for you. If you don't mind, could you describe the "test cases" you wish to see?
That would be great! In my case, I have all of my motion (CoreXY) motors on the main board and while the Y endstop is fixed on the frame, the X endstop (actually it's a dc42 IR sensor) is on the tool carriage and senses when the tool carriage approaches the far left.
Right now it's wired back to the main board along with the Z probe, temp sensor, and extruder heater. I just want to make sure that if the IR (or any) sensor was connected to IO1 on a tool board (actually it's just an "I" since there's no "out" pin) that it will work as an X endstop.
