RepRapFirmware road map as at 15 February 2020
39
2.6k
    dc42 administrators @garyd9
    @garyd9 said in RepRapFirmware road map as at 15 February 2020:
    There was talk in the past of adding support in RRF3 to redirect certain file system related gcodes to DSF so that PanelDue could be fully utilized with a Duet3 attached to DSF.
    Is this still on the road map?
    Yes I hope to implement that, but it needs support in DSF, which may not be implemented in time for 3.02.
      littlehobbyshop @dc42
      @dc42 said in RepRapFirmware road map as at 15 February 2020:
      • Triggers (M581) and wait-for-input (M587) supported on expansion and tool boards
      M587 is Add WiFi network. Do you mean M577? I would very much like a 'Wait for external trigger' function
      BLV MGN Cube w/Hemera, K8200, Sunlu S8
      undefined 1 Reply Last reply 26 Feb 2020, 07:54 Reply Quote 0
        bot
        dc42,
        I have an interest in beginning an effort to continue development on RRF 2 until end of life. RRF 2 in its current state is just splendid for me, and I see potential value in maintaining it as a sort of "long-term-support" firmware that users can rely on to always be available to troubleshoot or implement in mission critical machines.
        Do you have any thoughts about RRF 2.0 you could document before leaving it to the community? I think you did some seriously magnificent things with RRF 2, and you seem off to the races with RRF 3. A short-medium length debrief of your thoughts about how you left it and what you may have wished to implement had development continued would be super-welcomed.
        Thanks! You are literally one of the most important people in the RepRap community. I will continue directly supporting your products as long as you continue to produce them.
        *not actually a robot
          dc42 administrators @littlehobbyshop
          @littlehobbyshop said in RepRapFirmware road map as at 15 February 2020:
          Thanks for pointing that out. I have corrected it.
            deckingman @dc42
            Support switch-type Z probes on expansion and tool boards
            Bit confused by this on the road map for RRF3.02. I already have the Metrol switch that I use as a Z (nozzle) probe configured as a simple switch (using M574) and connected to an expansion board. Did you mean "non switch-type Z probes on expansion boards? Or did you mean add type 5 to M558 for expansion boards?
            undefined 1 Reply Last reply 26 Feb 2020, 09:30 Reply Quote 0
              dc42 administrators @deckingman
              @deckingman said in RepRapFirmware road map as at 15 February 2020:
              M574 configures it as an endstop switch, not a Z probe.
                chas2706
                I think it might be a good idea to concentrate on getting the dsf up to date on duet3 rpi first??
                I was referring to conditional gcode does not work on duet3 with SBC and anything regards console feedback e.g G32 does not either.
                  oozeBot
                  When will you have time to address the SD card connection issues with the PanelDue and Duet3 running from a RPi? Thanks
                  undefined 1 Reply Last reply 26 Feb 2020, 13:19 Reply Quote 0
                    dc42 administrators @oozeBot
                    @gfisher said in RepRapFirmware road map as at 15 February 2020:
                    See my earlier reply https://forum.duet3d.com/post/135146.
                    undefined 1 Reply Last reply 27 Feb 2020, 13:22 Reply Quote 0
                      copystring
                      Any plans for M80/M81 support for meanwell PSUs?
                      I know I asked this before. Like many other. Is this anywhere on a plan?
                      undefined undefined 2 Replies Last reply 26 Feb 2020, 20:29 Reply Quote 0
                        dc42 administrators @copystring
                        @copystring said in RepRapFirmware road map as at 15 February 2020:
                        Do you mean to invert the PS_ON signal, or something else?
                        undefined 1 Reply Last reply 26 Feb 2020, 20:45 Reply Quote 0
                          copystring @dc42
                          @dc42 Yes. This.
                            arhi @dc42
                            The high speed SPI bus is on the socket for the Ethernet module.
                            USB serial port not fast enough?
                            undefined 1 Reply Last reply 26 Feb 2020, 23:43 Reply Quote 0
                              gtj0 @arhi
                              @arhi said in RepRapFirmware road map as at 15 February 2020:
                              The idea was to keep the USB serial port free and the the SPI bus runs at 5MHz (depending on how you have it configured) and uses less resources on the Duet. Didn't make sense to develop 2 different ways to communicate between the Duets and SBC.
                              undefined 1 Reply Last reply 27 Feb 2020, 13:57 Reply Quote 0
                                tekkydave @dc42
                                @Danal said in RepRapFirmware road map as at 15 February 2020:
                                The Pi to Duet 3 interface is SPI. Duet 2 does bring SPI out to the expansion connector.
                                Pure speculation on my part... but I'd expect nothing will need to be removed, just hook up the SPI and run the correct firmware.
                                The plan in the short term is to use a Duet 2 Ethernet without the Ethernet module. The high speed SPI bus is on the socket for the Ethernet module.
                                Will Duet2 WiFi be useable with RPi?
                                ~ tekkydave ~
                                D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                                FreeCAD, PrusaSlicer
                                  oozeBot @dc42
                                  @dc42 Thank you. I’ve found this to make demoing our machines very challenging when taking them offsite.
                                    arhi @gtj0
                                    @gtj0 said in RepRapFirmware road map as at 15 February 2020:
                                    TBH I'd rather have my USB port taken out byt SBC (currently attached to that USB port) than lose the ETH port by SBC (that's currently using the USB port). As compared to the setup ATTM where SBC attached to USB and ETH attached to DUET (and SBC) I will lose any outside connection to Duet2 and have USB port free.
                                    Unfortunately, most MCU's have USB "hardware" that uses a lot of resources from MCU but I don't see how will it use more than what it is using right now. It is already implementing CDC that's one of the most resource-hungry ones.
                                    I have zero experience with SAM's (tried, found ERRATA too late, gave up) but I doubt it's much different from STM32 so there should be 12MHz USB support out there. With all the overhead USB creates it should match the 5MHz SPI or come at least close to it. A secondary benefit would be that code on the SBC would be tad more portable as accessing /dev/tty* is much more portable than accessing (and enabling) SPI port on the expansion port of a SBC (as for e.g. one wanna use opi and not rpi or maybe fully open source ROCK pi ).
                                    That makes sense, but duet3 have USB too IIRC. Anyhow, decisions are already made, so I'll shut up now 🙂
                                      gtj0
                                      The Duet2 does actually have 2 additional SPI ports on the temp daughterboard and 50pin connectors but based on @dc42's comment above, maybe he thinks they won't be fast enough.
                                        We chose dedicated SPI for the Duet 3 so that we can be sure it will be fast enough and won't suffer from contention on either the Duet shared SPI bus or the RPi USB interface (which may be handling webcam, keyboard, mouse/touch screen, ascanner and goodness knows what else). We're not planning to rewrite that for Duet 2. If you connect a RPi to a Duet, you don't need the Duet to provide a webserver, because that's already in the RPi.
                                        Currently we don't need high speed on the SPI bus, but that may change soon when DSF tracks the RRF object model and plugins need up-to-date values. The RPi to Duet SPI bus works reliably up to 20MHz, higher in some cases.
                                        Another reason the shared SPI bus isn't suitable is because the RPi is the bus master when talking to the Duet.
                                          DaBit
                                          Once Raspberry/DSF is supported on Duet2 I suppose we can also take off the Wifi module of the Duet2Wifi and hook up the SPI bus to J16?
                                          I think I would like that.
                                          Wouldn't it make sense business-wise to spend more development effort towards Duet3/DSF and less towards Duet2? If Duet2 gets all the shiny new features too I never have a good reason to upgrade, which is not good for the amount of food on your table 🙂
                                          ? undefined 2 Replies Last reply 27 Feb 2020, 17:42 Reply Quote 0
                                          24 out of 39
