    RepRapFirmware 3.01-RC3 released
    Beta Firmware
    22
    68
    4.3k
      I believe DC42 had mentioned the next full release will have all the files needed for a direct update.
      • CNCModellerundefined
        CNCModeller @dc42
        @dc42 said in RepRapFirmware 3.01-RC3 released:
        I suggest you upgrade to either 2.05.1 or 3.01RC3. The main benefits of 3.01 are more flexible pin allocation, and conditions and loops in GCode and macro files; but upgrading from 2.x to 3.x is more complicated than upgrading to 2.05.1.
        What is the upgrade procedure?
        If you want to upgrade to 3.01 from 2.x then you must first upgrade to 3.0, and from there to 3.01. You will also have to make a lot of changes to your config.g file.
        Hi All / @dc42
        Unfortunately I think I've made a foolish error with my Duet 2 Ethernet... after upgrading to RRF3 (R3 zip then R3.01) I decided that I needed to spend much more time learning the new config commands so re-uploaded the 2.05 firmware, unfortunately (I think) I forgot that V3 uses a newer web interface and now I cant connect to the board via the web interface.
        Is there any way for me to re-configure things on the SD card directly so I can get back to using my printer with 2.05 in the short term?
        Also is polar config supported in RR3? I know I should have checked before upgrading but I am having a "hard of thinking" day. I only ask as the home files being called by the web interface for x appear to be the xhome rather than the radiushome file.
        Any help would be much appreciated. 🙂
        Many Thanks
        Barry M
        Polar Duet3 Mini + 1HCL
        https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
        Wanhao D4S: Duet2
        https://forum.duet3d.com/post/296755
        K40 Laser, Duet2
        https://forum.duet3d.com/post/312082
        Wanhao D5S
        https://www.youtube.com/CNCModellerUK
          Phaedrux Moderator @CNCModeller
          @CNCModeller said in RepRapFirmware 3.01-RC3 released:
          You can place the 2.05 firmware file on the SD card in the /sys folder, connect via USB terminal, and send M997 to flash the firmware.
          While you've got the SD card in your PC, you can also replace the contents of the /www folder with the files from DWC 2.0.7 just to make sure it's all there.
          CNCModellerundefined 1 Reply Last reply Reply Quote 0
            CNCModeller @Phaedrux
            @Phaedrux said in RepRapFirmware 3.01-RC3 released:
            Thanks @Phaedrux,
            I'm thinking that the firmware is already installed so I'm hoping I just need to copy over the files to the WWW folder.
            Fingers Xed!!!
            Cheers
            BPM
            Wanhao D4S: Duet2
            K40 Laser, Duet2
            Wanhao D5S
              @CNCModeller You can send M115 to see what firmware is actually flashed.
                Cool thanks for the heads up...
                Wanhao D4S: Duet2
                K40 Laser, Duet2
                Wanhao D5S
                • DaBitundefined
                  DaBit
                  That daemon-task runs always? Also when the printer is idle or off?
                  So, in theory I could use that to generate the desired chargepump signal, albeit at only 0,5Hz?
                    dc42 administrators @DaBit
                    @DaBit said in RepRapFirmware 3.01-RC3 released:
                    You could run it faster than that if you use a loop within the daemon.g file.
                    • imrjundefined
                      imrj @A Former User
                      @bearer bossa crashes on my Mac running Movaje, and i dont have a laptop w Windows, so I would have to rip out the board and uncable it all, trying to avoid that......
                      I tried the file "Duet3_SDiap_MB6HC.bin" that someone posted the link for but it still wont take, it says soemthing about in-app error (i notices is a really small file of 55k vs. the usual 550k or so).....I dunno this shouldnt be that difficult....help!!
                      Danalundefined droftartsundefined dc42undefined 3 Replies Last reply Reply Quote 0
                      • DaBitundefined
                        DaBit
                        I suppose I could, but as long as I do not have to interface with existing boards the frequency is not that important.
                        How do we prevent the daemon task from taking away too much processing from the main G-code pipe? Is an endless while() harmful? Or is all that handled by priority in RRF?
                        Anyway, nice addition that daemon task!
                        I could use the daemon task to monitor the heaters for faulting, generate a chargepump signal when OK, quit generating the chargepump and send an M81 when failing.
                        • Danalundefined
                          Danal @imrj
                          @imrj said in RepRapFirmware 3.01-RC3 released:
                          Do you have a Raspberry Pi?
                          The instructions for bossa on Pi are on the dozuki, just below the instructions for Winders (<=Texas edition of WIndows)
                          imrjundefined 1 Reply Last reply Reply Quote 0
                          • imrjundefined
                            imrj @Danal
                            @Danal i do have plenty those, thanks, will give that a shot
                              droftarts administrators @imrj
                              See https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x
                                If using your own loop, then I recommend that you include at least one G4 command in it with a reasonable length of delay.
                                  dc42 administrators @imrj
                                  That's the new IAP file, used by RRF 3.0 and later to upgrade the firmware. It is not the firmware file itself, but it needs to be present in /sys when you want to upgrade the firmware using DWC or M997.
                                  • imrjundefined
                                    imrj
                                    I understand, but even with it present and the firmware file, still does nothing, it says is updating the firmware, but it remains the same in M115 afterwards, stuck at 3.0B12
                                      Phaedrux Moderator @imrj
                                      @imrj Try updating to 3.0 first, with the zip file from that release. Then try updating to this release.
                                      • imrjundefined
                                        imrj
                                        i was able to finally get it done with the DuetPI and using the virtual SD card, so its all good now...but this needs to be simplied a bit, too hard for just a firmware update
                                        now I have another issue but opened a new post for that one....thanks everyone
                                          @imrj Did you see my post about fixing bossa on Mac OS? https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x
                                          • imrjundefined
                                            imrj @droftarts
                                            @droftarts yea i did thanks, but by then i had already setup the DuetPi and got it working....but yea i will do this to my Macbook, but interestingly enough I did have brew already installed and using it for other things
