    RepRapFirmware 3.01-RC3 released
    Beta Firmware
    22
    68
    4.3k
    • imrjundefined
      imrj @A Former User
      @bearer bossa crashes on my Mac running Movaje, and i dont have a laptop w Windows, so I would have to rip out the board and uncable it all, trying to avoid that......
      I tried the file "Duet3_SDiap_MB6HC.bin" that someone posted the link for but it still wont take, it says soemthing about in-app error (i notices is a really small file of 55k vs. the usual 550k or so).....I dunno this shouldnt be that difficult....help!!
      Danalundefined droftartsundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • DaBitundefined
        DaBit
        @dc42 said in RepRapFirmware 3.01-RC3 released:
        You could run it faster than that if you use a loop within the daemon.g file.
        I suppose I could, but as long as I do not have to interface with existing boards the frequency is not that important.
        How do we prevent the daemon task from taking away too much processing from the main G-code pipe? Is an endless while() harmful? Or is all that handled by priority in RRF?
        Anyway, nice addition that daemon task!
        I could use the daemon task to monitor the heaters for faulting, generate a chargepump signal when OK, quit generating the chargepump and send an M81 when failing.
        • Danalundefined
          Danal @imrj
          @imrj said in RepRapFirmware 3.01-RC3 released:
          Do you have a Raspberry Pi?
          The instructions for bossa on Pi are on the dozuki, just below the instructions for Winders (<=Texas edition of WIndows)
          imrjundefined 1 Reply Last reply Reply Quote 0
          • imrjundefined
            imrj @Danal
            @Danal i do have plenty those, thanks, will give that a shot
              droftarts administrators @imrj
              See https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x
                dc42 administrators @DaBit
                @DaBit said in RepRapFirmware 3.01-RC3 released:
                If using your own loop, then I recommend that you include at least one G4 command in it with a reasonable length of delay.
                  dc42 administrators @imrj
                  That's the new IAP file, used by RRF 3.0 and later to upgrade the firmware. It is not the firmware file itself, but it needs to be present in /sys when you want to upgrade the firmware using DWC or M997.
                  • imrjundefined
                    imrj
                    I understand, but even with it present and the firmware file, still does nothing, it says is updating the firmware, but it remains the same in M115 afterwards, stuck at 3.0B12
                      Phaedrux Moderator @imrj
                      @imrj Try updating to 3.0 first, with the zip file from that release. Then try updating to this release.
                      • imrjundefined
                        imrj
                        i was able to finally get it done with the DuetPI and using the virtual SD card, so its all good now...but this needs to be simplied a bit, too hard for just a firmware update
                        now I have another issue but opened a new post for that one....thanks everyone
                          @imrj Did you see my post about fixing bossa on Mac OS? https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x
                          • imrjundefined
                            imrj @droftarts
                            @droftarts yea i did thanks, but by then i had already setup the DuetPi and got it working....but yea i will do this to my Macbook, but interestingly enough I did have brew already installed and using it for other things
                              @imrj it's not just brew, you need to 'brew install wxwidgets'.
                              • TurtlePrintundefined
                                TurtlePrint
                                When sending the M112 command the printer turns off and then starts the hot end fan "fan1" at full speed. I'm hoping to use the new daemon.g file to monitor a rotor stuck alarm wire on the hot end fan and send an M112 if its detected. So the fan continuing to spin after M112 is problematic if it's in a known stuck position.
                                Printer is running:
                                Duet2Wifi w/Duex5 running RRF RC3
                                config.g snippet
                                M950 F0 C"Fan0"						;Define the Parts Blower Fan connected to Fan0
                                M106 P0 S0 C"Parts Blower" H-1 		;Name the fan, turn off thermistic control and turn the fan off if it was running
                                M950 F1 C"Fan1"						;Define the Tool Fan connected to Fan1
                                M106 P1 T40 H1						;Enable Thermostatic Control to turn fan on 40 degrees
                                Edit: After some experimentation it appears that any fan with thermostatic control enabled is set to 100% after an M112 command. Is this the intended behavior?
                                dc42undefined c310undefined 2 Replies Last reply Reply Quote 0
                                • imrjundefined
                                  imrj @droftarts
                                  @droftarts ah ok got it, will do that
                                  • JuKuundefined
                                    JuKu
                                    M203 is set by mm/min, but reported back in mm/sec. (not a problem and as documented, just a bit odd. ?.)
                                      dc42 administrators @TurtlePrint
                                      @TurtlePrint said in RepRapFirmware 3.01-RC3 released:
                                      If readings from the sensor that control the thermostatic fan are not available, the firmware assumes that whatever it is supposed to cool might be hot, so it turns the fan on.
                                        There is a bug in the 3.01-RC3 firmware on Tool Boards. The symptom of this bug is that the motor doesn't move and M122 reports a large number of timeouts for Driver 0. I have put a fixed version of Duet3Firmware-TOOL1LC.bin at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. Tool board users, please use this version until I release 3.01-RC4.
                                        • arhiundefined
                                          arhi
                                          so far so good, duet2eth, one 6h print done flawlesly, second is 4h-38% in doing ok another 60% and change to go
                                          • c310undefined
                                            c310 @Danal
                                            @Danal said in RepRapFirmware 3.01-RC3 released:
                                            emergency stop
                                            on duetwifi i have upgraded from 3.0 and emergency stop now does not work at all (was buggy in 3.0: printer stopped but did not reload itself, i was cycling power off-on to finish emergency stop cycle 🙂
                                            current config
                                            M950 J1 C"e1stop"
                                            M581 P"e1stop" T0 C0
                                            3.0 config was
                                            M581 P"e1stop" T0
                                            what should i fix ?
