    RepRapFirmware 3.01-RC3 released
    Beta Firmware
    22
    68
    4.3k
      Phaedrux Moderator @CNCModeller
      @CNCModeller said in RepRapFirmware 3.01-RC3 released:
      Is there any way for me to re-configure things on the SD card directly so I can get back to using my printer with 2.05 in the short term?
      You can place the 2.05 firmware file on the SD card in the /sys folder, connect via USB terminal, and send M997 to flash the firmware.
      While you've got the SD card in your PC, you can also replace the contents of the /www folder with the files from DWC 2.0.7 just to make sure it's all there.
      CNCModellerundefined 1 Reply Last reply Reply Quote 0
      • CNCModellerundefined
        CNCModeller @Phaedrux
        @Phaedrux said in RepRapFirmware 3.01-RC3 released:
        Thanks @Phaedrux,
        I'm thinking that the firmware is already installed so I'm hoping I just need to copy over the files to the WWW folder.
        Fingers Xed!!!
        Cheers
        BPM
        Polar Duet3 Mini + 1HCL
        https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
        Wanhao D4S: Duet2
        https://forum.duet3d.com/post/296755
        K40 Laser, Duet2
        https://forum.duet3d.com/post/312082
        Wanhao D5S
        https://www.youtube.com/CNCModellerUK
          @CNCModeller You can send M115 to see what firmware is actually flashed.
            Cool thanks for the heads up...
            Wanhao D4S: Duet2
            K40 Laser, Duet2
            Wanhao D5S
            • DaBitundefined
              DaBit
              That daemon-task runs always? Also when the printer is idle or off?
              So, in theory I could use that to generate the desired chargepump signal, albeit at only 0,5Hz?
                dc42 administrators @DaBit
                @DaBit said in RepRapFirmware 3.01-RC3 released:
                You could run it faster than that if you use a loop within the daemon.g file.
                • imrjundefined
                  imrj @A Former User
                  @bearer bossa crashes on my Mac running Movaje, and i dont have a laptop w Windows, so I would have to rip out the board and uncable it all, trying to avoid that......
                  I tried the file "Duet3_SDiap_MB6HC.bin" that someone posted the link for but it still wont take, it says soemthing about in-app error (i notices is a really small file of 55k vs. the usual 550k or so).....I dunno this shouldnt be that difficult....help!!
                  Danalundefined droftartsundefined dc42undefined 3 Replies Last reply Reply Quote 0
                  • DaBitundefined
                    DaBit
                    @dc42 said in RepRapFirmware 3.01-RC3 released:
                    I suppose I could, but as long as I do not have to interface with existing boards the frequency is not that important.
                    How do we prevent the daemon task from taking away too much processing from the main G-code pipe? Is an endless while() harmful? Or is all that handled by priority in RRF?
                    Anyway, nice addition that daemon task!
                    I could use the daemon task to monitor the heaters for faulting, generate a chargepump signal when OK, quit generating the chargepump and send an M81 when failing.
                    • Danalundefined
                      Danal @imrj
                      @imrj said in RepRapFirmware 3.01-RC3 released:
                      Do you have a Raspberry Pi?
                      The instructions for bossa on Pi are on the dozuki, just below the instructions for Winders (<=Texas edition of WIndows)
                      imrjundefined 1 Reply Last reply Reply Quote 0
                      • imrjundefined
                        imrj @Danal
                        @Danal i do have plenty those, thanks, will give that a shot
                          droftarts administrators @imrj
                          See https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x
                            If using your own loop, then I recommend that you include at least one G4 command in it with a reasonable length of delay.
                              dc42 administrators @imrj
                              That's the new IAP file, used by RRF 3.0 and later to upgrade the firmware. It is not the firmware file itself, but it needs to be present in /sys when you want to upgrade the firmware using DWC or M997.
                              • imrjundefined
                                imrj
                                I understand, but even with it present and the firmware file, still does nothing, it says is updating the firmware, but it remains the same in M115 afterwards, stuck at 3.0B12
                                  Phaedrux Moderator @imrj
                                  @imrj Try updating to 3.0 first, with the zip file from that release. Then try updating to this release.
                                  • imrjundefined
                                    imrj
                                    i was able to finally get it done with the DuetPI and using the virtual SD card, so its all good now...but this needs to be simplied a bit, too hard for just a firmware update
                                    now I have another issue but opened a new post for that one....thanks everyone
                                      @imrj Did you see my post about fixing bossa on Mac OS? https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x
                                      • imrjundefined
                                        imrj @droftarts
                                        @droftarts yea i did thanks, but by then i had already setup the DuetPi and got it working....but yea i will do this to my Macbook, but interestingly enough I did have brew already installed and using it for other things
                                          @imrj it's not just brew, you need to 'brew install wxwidgets'.
                                          • TurtlePrintundefined
                                            TurtlePrint
                                            When sending the M112 command the printer turns off and then starts the hot end fan "fan1" at full speed. I'm hoping to use the new daemon.g file to monitor a rotor stuck alarm wire on the hot end fan and send an M112 if its detected. So the fan continuing to spin after M112 is problematic if it's in a known stuck position.
                                            Printer is running:
                                            Duet2Wifi w/Duex5 running RRF RC3
                                            config.g snippet
                                            M950 F0 C"Fan0"						;Define the Parts Blower Fan connected to Fan0
                                            M106 P0 S0 C"Parts Blower" H-1 		;Name the fan, turn off thermistic control and turn the fan off if it was running
                                            M950 F1 C"Fan1"						;Define the Tool Fan connected to Fan1
                                            M106 P1 T40 H1						;Enable Thermostatic Control to turn fan on 40 degrees
                                            Edit: After some experimentation it appears that any fan with thermostatic control enabled is set to 100% after an M112 command. Is this the intended behavior?
                                            dc42undefined c310undefined 2 Replies Last reply Reply Quote 0
