    Terrible print
    3D Printing General Chat
    print quality print quality
    12
    57
    3.1k
      droftarts administrators @apex2011
      @apex2011 can you do a video that shows the actual print? Off hand I’d say that that extruder is moving too slowly, but hard to tell because I can’t see the extrusion. Are you sure you haven’t set filament diameter to 3mm, rather than 1.75mm, in your slicer?
      I assume you had the printer working correctly with the original board, before fitting the Duet?
      apex2011undefined 1 Reply Last reply Reply Quote 0
      • apex2011undefined
        apex2011 @droftarts
        @droftarts I will do a video of the print this morning. I am also trying another slicer. I did verify that the filament is set to 1.75 in both Simplify 3D and now Cura.
        Yes, I had the printer working before switching to Duet.
          @apex2011 have you got the config from the old electronics you can share? Have you changed the extruder motor? I think the assumption has been it’s a 1.8 degree motor, but perhaps it’s a 0.9. Has it got a label on the extruder stepper motor? What does it say?
          Did you retune the extrusion distance? See https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
          • apex2011undefined
            apex2011 @droftarts
            @droftarts I thought I saved the config but I can't find it now that I'm looking for it. The extruder is stock for ender 3, 1.8 deg. I have done the celebration several times, it feeds 100mm of filament like it's supposed to. Although, now that I am thinking about it there have been a few changes made, it's worth checking again.
            I am sure I'm probably missing something really simple. Earlier this week I went right back to step 1 and walked through the entire setup.
            • apex2011undefined
              apex2011
              So, I think I was right that it was something simple....I moved the filament and it's printing FAR better. Still not perfect but much better. I'll post a picture when it finishes but I think 1/2 my issue was filament tension that I didn't notice....🤦
              • apex2011undefined
                apex2011
                it's definitely not perfect but, it printed!
                Thank you everyone! I think it's a matter of dialing things in now.
                  Phaedrux Moderator @Phaedrux
                  @Phaedrux said in Terrible print:
                  Tangled filament path?
                  • apex2011undefined
                    apex2011 @Phaedrux
                    @Phaedrux There didn't look to be but there must have been. I think I'm going to look into a different filament holder.
                      I prefer a filament holder that uses a bearing hub on the center of the spool so that it can rotate completely freely. I hate the ones that just hang it on a peg and force the extruder to yank on it.
                      https://www.thingiverse.com/thing:2334107
                      There is a mod for the Ender than moves the stock filament holder to the side closer to the extruder and more in line with it. I think that helps a bit.
                      https://www.thingiverse.com/search?q=ender+3+side+spool&dwh=835e6e667e47eca
                      For my ender I just use one of the holder that uses bearings to set the spool on. It's less stable, but it does rotate the spool more easily.
                      https://www.thingiverse.com/thing:2165694
                      • apex2011undefined
                        apex2011 @Phaedrux
                        @Phaedrux Thank you! One of these will be my next print
                          @apex2011 was the extruder skipping steps, or grinding away the filament? The first might have been overcome by increasing the motor current. If the second, better take the extruder apart and clean the teeth of the filament driver/hobbed insert.
                          • apex2011undefined
                            apex2011 @droftarts
                            @droftarts it didn’t look to be skipping. I took the gear out and cleaned it up as a preventative measure. There was some plastic “dust” in the gears, it all cleaned out with a quick blast of air.
                            • apex2011undefined
                              apex2011
                              Well, I thought I was onto good things. I tried to get a video but ti didn't work out very well. I was watching the print, it's almost like it forgets where z home is and tries to extrude too high part way through
                              • jens55undefined
                                jens55
                                Have you tried using babysteps to adjust the offset to z zero ?
                                Once you figure out the offset needed, you need to adjust the offset in your config.g file
                                • apex2011undefined
                                  apex2011 @jens55
                                  @jens55 Thank you, I will give that a try. What's odd to me is that it start off printing OK
                                  • jens55undefined
                                    jens55
                                    I am not seeing any area where it prints ok. The circumference lines clearly show that it is printing too high.
                                    • apex2011undefined
                                      apex2011
                                      reluctantly, I have given up on the duet board for now at least. I spent countless hours trying to dial in the settings and have not been able to get it to work properly. Sent it into a repair shop, they were also not able to get it to work properly. I have gone back to the stock wiring and Ender 3 board to find out why it is not extruding properly.
                                      theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                                      • jens55undefined
                                        jens55
                                        I am sorry to hear that .... such a shame ....
                                        Hopefully there will come a time in the future when you can give things an other go as a Duet controller is really a much superior product compared to a standard Creality (or virtually all other) controller board.
                                        The learning curve can be steep ..... but oh the rewards when you've climbed it and look back at your travels ....
                                        • theruttmeisterundefined
                                          theruttmeister @apex2011
                                          @apex2011
                                          Skimming through the thread.
                                          Did you measure off 100mm of filament, mark it and then try extruding 100mm? If moving the spool about changed your prints, plus there was debris on the pinchwheel?
                                          My first guess is the extruder drive is slipping. I have no idea how the compression force is adjusted on that extruder drive, but your fails look exactly like what you used to get on the old Makerbot Mk7 extruders. They used a delrin plunger that wore away, once that happens the filament just slips.
                                          A good extruder drive should be able to drag a spool across the table, it needs to be able to exert a decent amount of force to extrude, even with a really good hotend.
                                          I certainly wouldn't be expecting the board to be causing such a severe failure, not without a really obvious other symptom.
                                          Isolate, substitute, verify.
                                            theruttmeister @theruttmeister
                                            @theruttmeister
                                            Answered my own question:
                                            https://www.youtube.com/watch?v=FFCo5P0iQAI
                                            I'd check your drive lever. Looks like a fundamentally flawed design. No wonder there are lots of upgrades on the market.
                                            If they had just made that hole 4mm and used a shoulder bolt...
                                            Guess that's how you get to a $300 printer.
