    Another Predator
    204
    13.2k
    • Carloundefined
      Carlo @Danal
      @Danal
      Thanks Phaedrux
      Hi Danal,
      Appreciate you having a look,
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-12-13b1
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 15 2020 19:14:10 GMT+0000 (Greenwich Mean Time)
      M550 P"Street Predator" ; set printer name
      M665 L440.470:440.470:440.470 R232.245 H422.803 B185.0 X-0.054 Y-0.244 Z0.000
      M666 X-0.263 Y0.223 Z0.040 A0.00 B0.00
      M551 P"" ; set password
      M552 P192.168.0.25 S1 ; Enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z80.00 E867.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X1 Y1 Z1 S1 ; set active high endstops
      M558 P5 R0.4 H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P100 X0 Y0 Z-0.08 ; set Z probe trigger value, offset and trigger height
      M557 R175 S20 ; define mesh grid
      M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 X200 ; configure PT100 for heater 1
      M143 H1 S400 ; set temperature limit for heater 1 to 400C
      ; homedelta.g
      ; called to home all towers on a delta printer
      G91 ; relative positioning
      ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
      G1 H1 X450 Y450 Z450 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      ;G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
      ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
      ;G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
      ;G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      ;G1 X0 Y0 F6000 ; move X+Y to the centre
      3/16/2020, 11:42:51 PM M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-917DA-G4MSJ-6J1FJ-3S86N-TBN3A
      Used output buffers: 3 of 24 (8 max)
      Static ram: 25712
      Dynamic ram: 92244 of which 380 recycled
      Exception stack ram used: 272
      Never used ram: 12464
      Tasks: NETWORK(ready,628) HEAT(blocked,1176) MAIN(running,3728) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:06:01 ago, cause: power up
      Last software reset at 2020-03-16 19:20, reason: User, spinning module GCodes, available RAM 12304 bytes (slot 0)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 32.5, current 38.0, max 38.2
      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2020-03-16 23:42:50
      Cache data hit count 703568711
      Slowest loop: 10.47ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 30.44ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      3/16/2020, 11:41:17 PM M115
      Thanks
        droftarts administrators @Carlo
        @Carlo said in Another Predator:
        Just a thought... If you're setting the axis limit with M208 to Z0, you can't go further down with babystepping. I have my M208 to M208 Z-0.2 S1, which allows for quite a lot of adjustment of the first layer with babystepping. As you're having particular problems with getting the first layer low enough, I wonder if this settings also impacts setting the Z datum.
        • Carloundefined
          Carlo
          Hi Ian,
          I’ll make that change and recalibrate 1st thing
          That makes sense.
          Appreciate the help.
          Cheers
          • Danalundefined
            Danal
            Did I read somewhere that you switched to Hyaden Mag arms? (Which are great, by the way). What was printed on the stickers that came on the arms?
            Carloundefined 1 Reply Last reply Reply Quote 0
            • Danalundefined
              Danal
              ; homedelta.g
              I see one problem immediately. A bunch of commands in homedelta.g have been commented out. There are two problems with that:
              First, the "second pass" slow home is commented out. This means that tower height, and therefore indirectly bed height, is dependent only one a single bang into the upper switches that occurs at F1800. This is not very repeatable or accurate.
              Second, after that single bang, there is not a slight downward move (it is commented out). This means the carriages and effector are "trapped" up against all three switches and cannot adjust for tower offsets or angles. This will produce all kinds of bizarre behaviors. The macro just ends with the carriage sitting there up against the stops. Depending on what the next move is, various weird things are going to happen.
              Your homedelta.g should be:
              ; homedelta.g
              Or very similar...
              I will keep looking.
              Carloundefined 1 Reply Last reply Reply Quote 1
              • Danalundefined
                Danal
                I notice there is an "m501" near the end of config.g. This loads /sys/config_override.g. Please either post that file, and/or consider taking the M501 out until we get this all straight.
                • Danalundefined
                  Danal
                  That looks really odd to me. Can you post a couple of pictures of the printer? Preferably with the effector as close to X0Y0Z1 as you can get without damaging anything, and then one or two different photo angles at X0Y185Z1.
                  Thanks!
                  • Carloundefined
                    Carlo @Danal
                    @Danal
                    Hi Danal,
                    Yes I did fit Haydn mag arms length 440.47 mm
                    Thanks
                    • Carloundefined
                      Carlo @Danal
                      @Danal
                      Hi Danal,
                      These are commented out in the home file for Delta Calibration as per the documentation they are not always commented just at the point of posting.
                      Thanks
                      • Carloundefined
                        Carlo @Danal
                        @Danal said in Another Predator:
                        X0Y0Z1
                        Hi Danal,
                        Pictures as requested,
                        X0Y0Z1
                        X0Y185Z1
                        IMG_1351.jpg IMG_1350.jpg IMG_1349.jpg ![IMG_1348.jpg](/assets/uploads/files/1584435825406-img_1348.jpg
                        Cheers
                        • Carloundefined
                          Carlo @Danal
                          @Danal
                          I did an M500 this is the result from config_override.g and now removed M501 from the config.g file
                          ; config-override.g file generated in response to M500 at 2020-03-17 08:37
                          ; Delta parameters
                          M665 L440.470:440.470:440.470 R221.526 H414.033 B185.0 X0.120 Y0.069 Z0.000
                          M666 X0.008 Y-1.014 Z1.006 A0.00 B0.00
                          ; Heater model parameters
                          M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
                          M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          G10 L2 P1 X0.00 Y0.00 Z0.00
                          G10 L2 P2 X0.00 Y0.00 Z0.00
                          G10 L2 P3 X0.00 Y0.00 Z0.00
                          G10 L2 P4 X0.00 Y0.00 Z0.00
                          G10 L2 P5 X0.00 Y0.00 Z0.00
                          G10 L2 P6 X0.00 Y0.00 Z0.00
                          G10 L2 P7 X0.00 Y0.00 Z0.00
                          G10 L2 P8 X0.00 Y0.00 Z0.00
                          G10 L2 P9 X0.00 Y0.00 Z0.00
                          Cheers
                          • Danalundefined
                            Danal
                            Thanks, excellent stuff, I will take a look at all of that.
                            • Danalundefined
                              Danal @Carlo
                              Just to triple confirm: The running file on the printer is going to end with the carriages (approximately) 5mm below the endstop switches, correct?
                              • Carloundefined
                                Carlo @Danal
                                @Danal
                                Hi Danal,
                                That's what it's supposed to do but I cant confirm as it homes to the below error so it doesn't bounce.
                                It used to do as intended but I rolled the firmware back redid the configs via the online tool since these errors.
                                Note* the height Z-50 is myself trying to move the effector after homing.
                                Not sure this helps.
                                Thanks I know its a lot to scan through it is appreciated.
                                Danalundefined boldnutsundefined 2 Replies Last reply Reply Quote 0
                                • Danalundefined
                                  Danal @Carlo
                                  We will get it going. I appreciate your patience in re-posting stuff for the "new guy" looking into this.
                                  • boldnutsundefined
                                    boldnuts @Carlo
                                    @Carlo Your active high endstops are incorrect, should be M574 X2 Y2 Z2 S1 ; Set active high endstops.
                                    It also looks like you have both RR3 and RR2 configs in your config.g ? file
                                      droftarts administrators @boldnuts
                                      @boldnuts said in Another Predator:
                                      Good catch! Though you mean 'high end' endstops, as in their position on the printer; the S parameter is for active high/low (describes how the microswitch works).
                                      • boldnutsundefined
                                        boldnuts
                                        yes correct, which version of the firmware is being used? as it's confusing
                                        • Carloundefined
                                          Carlo @droftarts
                                          @droftarts said in Another Predator:
                                          M574 X2 Y2 Z2 S1
                                          Great stuff homing now works and endstops offsets now look... correct also
                                          Quick calibrate returns:
                                          M665
                                          Diagonals 440.470:440.470:440.470, delta radius 221.612, homed height 414.196, bed radius 185.0, X 0.073°, Y 0.055°, Z 0.000°
                                          M666
                                          Endstop adjustments X-0.03 Y-0.29 Z0.32, tilt X0.00% Y0.00%
                                          Thank you!
                                          • Carloundefined
                                            Carlo @boldnuts
                                            @boldnuts
                                            Hi Ian,
                                            M115
                                            If that still needed.
                                            Thanks
                                            boldnutsundefined 1 Reply Last reply Reply Quote 0
