    Another Predator
    204
    14.8k
    • Danalundefined
      Danal
      Did I read somewhere that you switched to Hyaden Mag arms? (Which are great, by the way). What was printed on the stickers that came on the arms?
      Carloundefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal
        @Carlo said in Another Predator:
        ; homedelta.g
        ; called to home all towers on a delta printer
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 15 2020 19:14:10 GMT+0000 (Greenwich Mean Time)
        G91 ; relative positioning
        ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
        G1 H1 X450 Y450 Z450 F1800 ; move all towers to the high end stopping at the endstops (first pass)
        ;G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
        ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
        ;G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
        ;G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
        G90 ; absolute positioning
        ;G1 X0 Y0 F6000 ; move X+Y to the centre
        I see one problem immediately. A bunch of commands in homedelta.g have been commented out. There are two problems with that:
        First, the "second pass" slow home is commented out. This means that tower height, and therefore indirectly bed height, is dependent only one a single bang into the upper switches that occurs at F1800. This is not very repeatable or accurate.
        Second, after that single bang, there is not a slight downward move (it is commented out). This means the carriages and effector are "trapped" up against all three switches and cannot adjust for tower offsets or angles. This will produce all kinds of bizarre behaviors. The macro just ends with the carriage sitting there up against the stops. Depending on what the next move is, various weird things are going to happen.
        Your homedelta.g should be:
        ; homedelta.g
        Or very similar...
        I will keep looking.
        Carloundefined 1 Reply Last reply Reply Quote 1
        • Danalundefined
          Danal
          I notice there is an "m501" near the end of config.g. This loads /sys/config_override.g. Please either post that file, and/or consider taking the M501 out until we get this all straight.
          • Danalundefined
            Danal
            M665 L440.470:440.470:440.470 R232.245 H422.803 B185.0 X-0.054 Y-0.244 Z0.000
            That looks really odd to me. Can you post a couple of pictures of the printer? Preferably with the effector as close to X0Y0Z1 as you can get without damaging anything, and then one or two different photo angles at X0Y185Z1.
            Thanks!
            • Carloundefined
              Carlo @Danal
              @Danal
              Hi Danal,
              Yes I did fit Haydn mag arms length 440.47 mm
              Thanks
              • Carloundefined
                Carlo @Danal
                @Danal
                Hi Danal,
                These are commented out in the home file for Delta Calibration as per the documentation they are not always commented just at the point of posting.
                Thanks
                • Carloundefined
                  Carlo @Danal
                  @Danal said in Another Predator:
                  X0Y0Z1
                  Hi Danal,
                  Pictures as requested,
                  X0Y0Z1
                  X0Y185Z1
                  IMG_1351.jpg IMG_1350.jpg IMG_1349.jpg ![IMG_1348.jpg](/assets/uploads/files/1584435825406-img_1348.jpg
                  Cheers
                  • Carloundefined
                    Carlo @Danal
                    @Danal
                    I did an M500 this is the result from config_override.g and now removed M501 from the config.g file
                    ; config-override.g file generated in response to M500 at 2020-03-17 08:37
                    ; Delta parameters
                    M665 L440.470:440.470:440.470 R221.526 H414.033 B185.0 X0.120 Y0.069 Z0.000
                    M666 X0.008 Y-1.014 Z1.006 A0.00 B0.00
                    ; Heater model parameters
                    M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
                    M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    G10 L2 P1 X0.00 Y0.00 Z0.00
                    G10 L2 P2 X0.00 Y0.00 Z0.00
                    G10 L2 P3 X0.00 Y0.00 Z0.00
                    G10 L2 P4 X0.00 Y0.00 Z0.00
                    G10 L2 P5 X0.00 Y0.00 Z0.00
                    G10 L2 P6 X0.00 Y0.00 Z0.00
                    G10 L2 P7 X0.00 Y0.00 Z0.00
                    G10 L2 P8 X0.00 Y0.00 Z0.00
                    G10 L2 P9 X0.00 Y0.00 Z0.00
                    Cheers
                    • Danalundefined
                      Danal
                      Thanks, excellent stuff, I will take a look at all of that.
                      • Danalundefined
                        Danal @Carlo
                        Just to triple confirm: The running file on the printer is going to end with the carriages (approximately) 5mm below the endstop switches, correct?
                        • Carloundefined
                          Carlo @Danal
                          @Danal
                          Hi Danal,
                          That's what it's supposed to do but I cant confirm as it homes to the below error so it doesn't bounce.
                          It used to do as intended but I rolled the firmware back redid the configs via the online tool since these errors.
                          Note* the height Z-50 is myself trying to move the effector after homing.
                          Not sure this helps.
                          Thanks I know its a lot to scan through it is appreciated.
                          Danalundefined boldnutsundefined 2 Replies Last reply Reply Quote 0
                          • Danalundefined
                            Danal @Carlo
                            We will get it going. I appreciate your patience in re-posting stuff for the "new guy" looking into this.
                            • boldnutsundefined
                              boldnuts @Carlo
                              @Carlo Your active high endstops are incorrect, should be M574 X2 Y2 Z2 S1 ; Set active high endstops.
                              It also looks like you have both RR3 and RR2 configs in your config.g ? file
                                droftarts administrators @boldnuts
                                @boldnuts said in Another Predator:
                                Good catch! Though you mean 'high end' endstops, as in their position on the printer; the S parameter is for active high/low (describes how the microswitch works).
                                • boldnutsundefined
                                  boldnuts
                                  yes correct, which version of the firmware is being used? as it's confusing
                                  • Carloundefined
                                    Carlo @droftarts
                                    @droftarts said in Another Predator:
                                    M574 X2 Y2 Z2 S1
                                    Great stuff homing now works and endstops offsets now look... correct also
                                    Quick calibrate returns:
                                    M665
                                    Diagonals 440.470:440.470:440.470, delta radius 221.612, homed height 414.196, bed radius 185.0, X 0.073°, Y 0.055°, Z 0.000°
                                    M666
                                    Endstop adjustments X-0.03 Y-0.29 Z0.32, tilt X0.00% Y0.00%
                                    Thank you!
                                    • Carloundefined
                                      Carlo @boldnuts
                                      @boldnuts
                                      Hi Ian,
                                      M115
                                      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-12-13b1
                                      If that still needed.
                                      Thanks
                                      boldnutsundefined 1 Reply Last reply Reply Quote 0
                                      • boldnutsundefined
                                        boldnuts @Carlo
                                        @Carlo can we see your start gcode from your slicer?, you using G32 (calibrate) before printing?, maybe G29 S1 to load the bed mesh?
                                        • Carloundefined
                                          Carlo @boldnuts
                                          @boldnuts
                                          I have no start code yet having failed to get a layer down yet didn't want to add any complications,
                                          However I have been doing G92 Z0 with paper G32 before attempting aprint ..I never home after probe and always with heated bed and nozzle, bed @ 70c nozzle @ 220c.
                                          I have done the mesh but don't use it .. more to know it's flat..ish I think?? height maps are above in previous post.
                                          If that help ?
                                          Thanks
                                          • boldnutsundefined
                                            boldnuts
                                            You need to run G32 in your start gcode before every print and it might be a good idea to run G29 to load the bed mesh as well, then recall it with G29 S1
                                            Danalundefined Carloundefined 2 Replies Last reply Reply Quote 0
