    Another Predator
    204
    14.8k
    • Danalundefined
      Danal
      @Carlo said in Another Predator:
      M665 L440.470:440.470:440.470 R232.245 H422.803 B185.0 X-0.054 Y-0.244 Z0.000
      That looks really odd to me. Can you post a couple of pictures of the printer? Preferably with the effector as close to X0Y0Z1 as you can get without damaging anything, and then one or two different photo angles at X0Y185Z1.
      Thanks!
      Carloundefined 1 Reply Last reply Reply Quote 0
      • Carloundefined
        Carlo @Danal
        @Danal
        Hi Danal,
        Yes I did fit Haydn mag arms length 440.47 mm
        Thanks
        • Carloundefined
          Carlo @Danal
          @Danal
          Hi Danal,
          These are commented out in the home file for Delta Calibration as per the documentation they are not always commented just at the point of posting.
          Thanks
          • Carloundefined
            Carlo @Danal
            @Danal said in Another Predator:
            X0Y0Z1
            Hi Danal,
            Pictures as requested,
            X0Y0Z1
            X0Y185Z1
            IMG_1351.jpg IMG_1350.jpg IMG_1349.jpg ![IMG_1348.jpg](/assets/uploads/files/1584435825406-img_1348.jpg
            Cheers
            • Carloundefined
              Carlo @Danal
              @Danal
              I did an M500 this is the result from config_override.g and now removed M501 from the config.g file
              ; config-override.g file generated in response to M500 at 2020-03-17 08:37
              ; Delta parameters
              M665 L440.470:440.470:440.470 R221.526 H414.033 B185.0 X0.120 Y0.069 Z0.000
              M666 X0.008 Y-1.014 Z1.006 A0.00 B0.00
              ; Heater model parameters
              M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
              M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              G10 L2 P1 X0.00 Y0.00 Z0.00
              G10 L2 P2 X0.00 Y0.00 Z0.00
              G10 L2 P3 X0.00 Y0.00 Z0.00
              G10 L2 P4 X0.00 Y0.00 Z0.00
              G10 L2 P5 X0.00 Y0.00 Z0.00
              G10 L2 P6 X0.00 Y0.00 Z0.00
              G10 L2 P7 X0.00 Y0.00 Z0.00
              G10 L2 P8 X0.00 Y0.00 Z0.00
              G10 L2 P9 X0.00 Y0.00 Z0.00
              Cheers
              • Danalundefined
                Danal
                Thanks, excellent stuff, I will take a look at all of that.
                • Danalundefined
                  Danal @Carlo
                  Just to triple confirm: The running file on the printer is going to end with the carriages (approximately) 5mm below the endstop switches, correct?
                  • Carloundefined
                    Carlo @Danal
                    @Danal
                    Hi Danal,
                    That's what it's supposed to do but I cant confirm as it homes to the below error so it doesn't bounce.
                    It used to do as intended but I rolled the firmware back redid the configs via the online tool since these errors.
                    Note* the height Z-50 is myself trying to move the effector after homing.
                    Not sure this helps.
                    Thanks I know its a lot to scan through it is appreciated.
                    Danalundefined boldnutsundefined 2 Replies Last reply Reply Quote 0
                    • Danalundefined
                      Danal @Carlo
                      We will get it going. I appreciate your patience in re-posting stuff for the "new guy" looking into this.
                      • boldnutsundefined
                        boldnuts @Carlo
                        @Carlo Your active high endstops are incorrect, should be M574 X2 Y2 Z2 S1 ; Set active high endstops.
                        It also looks like you have both RR3 and RR2 configs in your config.g ? file
                          droftarts administrators @boldnuts
                          @boldnuts said in Another Predator:
                          Good catch! Though you mean 'high end' endstops, as in their position on the printer; the S parameter is for active high/low (describes how the microswitch works).
                          • boldnutsundefined
                            boldnuts
                            yes correct, which version of the firmware is being used? as it's confusing
                            • Carloundefined
                              Carlo @droftarts
                              @droftarts said in Another Predator:
                              M574 X2 Y2 Z2 S1
                              Great stuff homing now works and endstops offsets now look... correct also
                              Quick calibrate returns:
                              M665
                              Diagonals 440.470:440.470:440.470, delta radius 221.612, homed height 414.196, bed radius 185.0, X 0.073°, Y 0.055°, Z 0.000°
                              M666
                              Endstop adjustments X-0.03 Y-0.29 Z0.32, tilt X0.00% Y0.00%
                              Thank you!
                              • Carloundefined
                                Carlo @boldnuts
                                @boldnuts
                                Hi Ian,
                                M115
                                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-12-13b1
                                If that still needed.
                                Thanks
                                boldnutsundefined 1 Reply Last reply Reply Quote 0
                                • boldnutsundefined
                                  boldnuts @Carlo
                                  @Carlo can we see your start gcode from your slicer?, you using G32 (calibrate) before printing?, maybe G29 S1 to load the bed mesh?
                                  Carloundefined 1 Reply Last reply Reply Quote 1
                                  • Carloundefined
                                    Carlo @boldnuts
                                    @boldnuts
                                    I have no start code yet having failed to get a layer down yet didn't want to add any complications,
                                    However I have been doing G92 Z0 with paper G32 before attempting aprint ..I never home after probe and always with heated bed and nozzle, bed @ 70c nozzle @ 220c.
                                    I have done the mesh but don't use it .. more to know it's flat..ish I think?? height maps are above in previous post.
                                    If that help ?
                                    Thanks
                                    • boldnutsundefined
                                      boldnuts
                                      You need to run G32 in your start gcode before every print and it might be a good idea to run G29 to load the bed mesh as well, then recall it with G29 S1
                                      Danalundefined Carloundefined 2 Replies Last reply Reply Quote 0
                                      • Danalundefined
                                        Danal @boldnuts
                                        YES!
                                        This is one of the big keys to running a delta. Let it find the bed, every time.
                                        • Carloundefined
                                          Carlo @boldnuts
                                          @boldnuts
                                          I'll try the mesh I do G32 before every print attempt.
                                          dc42 commented a well built delta doesn't need bed mesh so not wanted to ..because I want a well built delta printer 🙂
                                          Thanks
                                          • Carloundefined
                                            Carlo @Danal
                                            @Danal @boldnuts
                                            This is the height map it just finished ...is it ok?
                                            Thanks
