Show me your duet 3 enclosures!
@gtj0 Impressive! Shielded stepper cables?
Planning to install a Pi once DSF is a little more stable. Curious what pins you connected from the D3 to the Pi. Interested in only using what’s necessary and leaving the rest for future GPIO.
PS Your bearing block on the Z lead screw is a great idea. Might have to steal that one
@mwolter check out the schematics. The required connections are listed there. If you supply an isolated external 5v (negating need for the +5V cores) to the Pi I'm not sure if it would be possible to save on a few of the negative connections too.
Edit: if you do use an external supply for the pi ensure the dc negative isn't directly linked to earth as you could set up an earth loop with considerable current if your main psu is earth tied.
@DocTrucker said in Show me your duet 3 enclosures!:
earth loop
drew up an isolator (back in January) but haven't had a chance to test it (nor decided weather to add a 3.3v ldo instead of a 3.3v header)
suppose could create a new topic to discuss if there is interest. (edit, changed to ADuM1200BR to allow 10mbps, ISO7721DR seems to be pin compatible and i'll do a test with that)
Moved it to a a less personal EasyEDA account, https://easyeda.com/bearer/duet36hc-isolator -
@bearer nice work!
@bearer isn't 1200 "not for new designs" replaced with 120n ?
@arhi said in Show me your duet 3 enclosures!:
quite possibly, I just picked what jlcpcb could assemble today (initially the 1mbps part because it was in the basic selection)
i would suspect any new parts to be pin compatible so not something i put much thought into tbh.
@bearer yeah 120n is pin compatible upgrade
@mwolter said in Show me your duet 3 enclosures!:
Yes. 2 pair 20ga STP
As @DocTrucker said, check out the schematic...
https://github.com/Duet3D/Duet3-Mainboard-6HC/blob/master/Duet3_Mainboard_v1.0/Duet3_MB_schematic_v1.0.pdf
I'd connect at least pins 20 and 25 for grounds. That keeps the pins needed in a group from 19-25.PS Your bearing block on the Z lead screw is a great idea. Might have to steal that one
Go for it!
Thanks @DocTrucker and @gtj0!
As mentioned in the above post I've quit thingiverse due to the latest spam/hack issues they have had, I've attached the STL's and wings3d files for the Modular Duet 3 case for anyone who wishes to use them, if there is a mod you would like let me know
Duet3 board case (power cable slot) V4 BL.stl
Duet3 board case (power cable slot) V4 BL board spin.stl
RPi4 side plate V2.stl
RPI3B+ side plate V2.stl
RPI3B+ side plate V2 mirrored.stl
Fan side plate.stl
Deep Fan side plate V3 40x40x20mm.stl
Deep Fan side plate V2.stl
blank side plate.stl
blank side plate upper.stl
blank side plate lower.stl
AXIS wiring side plate.stl
AXIS wiring side plate with spiggot.stl
AXIS wiring side plate with LRG spiggot PWR.stl
top V2.2 offset 80mm FAN NO guard Mirrored.stl
Duet3 board case top V2.2.stl
Duet3 board case top V2.2 80mm FAN with guard.stl
Duet3 board case top V2.2 80mm FAN NO guard.stlRegards Jim
Edit: formatting
I really like the modular approach you took and would like to mod your enclosure to fit my delta (and to add a Raspberry PI 7" screen to it. I tried loading in your files to FreeCad, but it struggled a bit to create a meaningful shape from the mesh.
What did you make them with?
Could
@jumpedwithbothfeet cant seem to get any of these to download. are they still viable? Trying to put together a 6hc+pi4+3eb enclosure so i can get my printer put together
@bam Which ones are you referring to?
@Phaedrux I ended up building my own, don’t know how to upload a picture here but it’s nearly done. Just need to either find or design a model to attach it to the psu
@bam said in Show me your duet 3 enclosures!:
On my computer I just drag or paste an image file into the message I edit to post. Should be simple.
@bam @sylvaindc Hi sorry I've not replied earlier, do you guys still need the files or some adjustments done?
This post is deleted! -
undefined NeoDue referenced this topic 17 Mar 2024, 11:52
