    PETG - Brittle?
    3D Printing General Chat
    9
    32
    3.9k
      deckingman
      ......or it might be colour related. Do certain brands give problems with certain colours? The PET-G I used from 3dfilaprint was almost exclusively black. Did uses who had problems with PET-G from the same brand also use black or some other colour.? Could this be a combination of brand and pigment?
      • arhiundefined
        arhi @deckingman
        @deckingman said in PETG - Brittle?:
        the "crazy" issues I'm having with white ones are when petg concerned only this single white spool. as for the "black" one, I have experience with many materials (mostly ABS, HIPS, PC) where black required 5-10C more than any other color from same manufacturer to print identically. In some cases black behaves like glow in dark or metal filled or carbon tubes filled or wood filled filament... just like the black "ink" has larger particles than other ones... With PETG from same manufacturer, best comparison is between "deep, dark, non translucent black " and "translucent black". They behave like totally different filaments while both PETG translucent one is much stiffer, less runny, strings very little while darl non translucent/transparent black feels more like hdpe than petg. They also smell differently while printing.
        I sometimes have similar experience like with BLACK with WHITE, but those "snow white" ones, they behave identical like BLACK, require few more C, and behave like "filled" filaments. I assume 'cause those snow white ones use some strong pigments to get the whiteness. Never had those issues with regular whites.
        I also noticed with ABS, black one is waaaaaaaaay more resistant to UV than any other color. I expected opposite as black one, exposed to sunlight, get much hotter than other ones.
          deckingman @arhi
          @arhi said in PETG - Brittle?:
          .............I assume 'cause those snow white ones use some strong pigments to get the whiteness..........
          Highly doped perhaps? (Snow white getting too close to one of the 7 dwarves?)
          • arhiundefined
            arhi @deckingman
            I think it's a different types of additives to the pigments or different pigments, not the ammount of pigment. For e.g. I know that for clothing they will add some "glow in dark" stuff that makes whites brighter under uv and fluo lights (that's why you have to use flash when taking photos of the bride on the wedding even if you have a lot of lux of led light available, as with only led without flash the "white dress" looks gray and does not pop up)
            But that's just guess. I'd really love to ask ppl who actually make filament how different they are in making, what do they add to the pellets for each of them but I never seen any of them (filament makers) join in such conversations
            • DocTruckerundefined
              DocTrucker
              For completeness my materials are snow white from 3DFilaprint and clear rPETG from filamentive. Very difficult to directly compare due to the colour differences.
              I don't think temp is an issue here as I aim for the slight sheen on the part, and keep extrusion rates within recomended for the nozzle. In this case below 10mm3/sec for E3D V6 std with standard 0.4mm nozzle.
                DocTrucker
                If anything the shield printing has just encouraged me to shop around a bit. I don't do colour preference much, but like to stick to a constant colour and supplier. I am liking the finish on the grey filamentive rPLA parts ao may look thatbway in the future.
                  DocTrucker
                  Brand new spool and still got issues. Think I will attempt a return unless the purchase was too long ago.
                  PaulHewundefined 1 Reply Last reply Reply Quote 0
                  • PaulHewundefined
                    PaulHew @DocTrucker
                    @DocTrucker said in PETG - Brittle?:
                    Of what and where from DocTrucker?
                    • PuterProundefined
                      PuterPro @antlestxp
                      @antlestxp said in PETG - Brittle?:
                      The polymaker polylite is pretty good stuff along with the polymax. My go to is the fillamentum cpe. That stuff is fantastic but you can't leave it out too long.
                      PC-Max is one of my all time favs, it also doesn't like being left out. I haven't tried Fillamentum CPE, I'll put it on my list to try, thanks! They've changed PC-Max to PolyMax now, FYI.
                      • Danielundefined
                        Daniel
                        @DocTrucker
                        PETG and most polyesters are prone to hydrolysis when exposed to heat in presence of water. The ideal moisture content for PETG is below 300 ppm or parts per million (300 mg of water per kilogram of PETG). To make the problem worst, PETG is fairly hygroscopic (It likes to absorb water). Once you remove it from the bag and the dissecants, it will start the absorption process.
                        The good thing is that the process is reversible. Heating PETG in presence of Desiccants (Silica Gel) at about 70 Celsius (70 x 1.8+32) approx 158F for 10 hs would dry the polymer while preserving its mechanical properties.
                        However, if the filament was made with wet resin. We could do very little to save it, since the hydrolysis process already occurred before we processed. If you could return it to the manufacturers and get a fresh batch, life can be better.
                        Good printing
                        • arhiundefined
                          arhi @Daniel
                          @Daniel isn't filament going from the nozzle directly into the warm water bath ?! How does that affect the moisture content?
                          I recently watched some video (trying to figure out what's wrong with this XXL spool of white petg from dasfilament that print at 180C that strings like crazy) about filament making and guy said that the process starts by
                          1. put pellets, additives, pigments into the blender and mix and mix and mix
                          2. put the mixed content into the dryer and dry for at least 2 hours
                          and went on about if you don't dry for at least 2 hours the filament will be %$#@^&# quality...
                          I guess everyone making filament knows this and I doubt anyone is crazy enough not to dry the mixture before using up all the time and energy to convert that into filament.
                          • Danielundefined
                            Daniel
                            @arhi
                            That is a very good observation. Filaments are made by melting dry polymer in the extruded and pushing them through a die with the proper diameter and then immersed into a water bath to solidify.
                            The residence time in the bath is enough to chill the filament but not enough to to raise the internal moisture content above 300 ppm.
                            It takes time to make the moisture diffuse into the polymer.
                            • arhiundefined
                              arhi
                              @Daniel sounds interesting, I have no clue about how that part of the work is done, never looked much in to it before this issues with dasfilament white petg, so I started looking at the process and if anyone published recipes but info about it all is super scarce. Apart from few videos and few pictures info there's nothing out there. Easier to find a procedure to make extazy or heroin than to make filament 😞
                              Anyhows looks like the general course of action for any filament is the same - if something fishy, dry it first 🙂
                              • Danielundefined
                                Daniel
                                @arhi
                                I am attaching a link to a resin vendor for injection molders and other plastic processes containing a table for water content on different polymers as well as a reference on how to measure that.
                                https://omnexus.specialchem.com/polymer-properties/properties/water-absorption-24-hours
                                What filaments are interested in making?
                                • arhiundefined
                                  arhi @Daniel
                                  @Daniel thanks. No wish to make filament. I just wanted to understand what happened to the spool I had issues with 😄 ( saga is here https://forum.duet3d.com/topic/16111/6mm-e3dv6-stringing-petg-any-ideas?_=1589127397515 it's a XXL role of dasfilament petg white that behave weird imo)
                                  • zaptaundefined
                                    zapta @arhi
                                    I god a food dehydrator and tried a few time to dry filaments but I can't say I noticed any before/after difference.
                                      DocTrucker @PaulHew
                                      @PaulHew the filament I'm having issues with is the Snow White PETG filament from 3DFilaprint. Premium own brand. Emailed them for comment last week. Not heard back yet.
                                        deckingman @DocTrucker
                                        That's interesting - it was Snow White PET-G (but a different brand) that @arhi was having problems with in a different thread.
                                        • arhiundefined
                                          arhi @deckingman
                                          @deckingman mine is actually called just "white" but it is "whiter" than regular white I have from other brands.
                                            DocTrucker
                                            If anything there is a slight blue tint to the snow white PETG from 3D Filaprint. They tend to completely hude products on their website when out of stock so can't see any product data sheets to get any hints on who makes it. I was reading somewhere (perhaps here) that the snow white behaves a little like a filled material.
                                            No response from the first email to them. I will try again soon.
