    Mesh Bed Compensation not compensating?
    27
    4.4k
      Phaedrux Moderator @Argo
      @Argo said in Mesh Bed Compensation not compensating?:
      I think those limits are only for gcode commands and not for the firmware itself.
      But I'll test it anyway.
      That's correct. The firmware will be able to compensate below the 0 point provided it is physically able to do so. For baby stepping purposes it can be useful to have a slightly negative value for the Z minima because by default you're only able to move down an amount equal to the thickness of the first layer height.
      • RyanPundefined
        RyanP
        I find the same thing on my E5Plus. Even thought I do a fairly long and detailed bed process, I still find that I am having to babystep my way out of a disaster with most prints. Or worse, have to adjust the bed knobs. My regular ender5 and the CR10S (all running duets) don't seem to have this problem on such a consistent basis.
        I even switched the setup to independant z motors and perform a G32, and still find I have to watch the first layer and make sure the filament goes down properly.
        I perform a G28 to start, then a G32 to level the separate z axis, then do a G29 for the mesh. Still have issues. So either the G32 undoes itself, or it needs to be done after the G29...which does not make any sense.
        CR10S, August 2018
        Anycubic Photon S December 2019
        Ender 5 Feb 2020
        Ender 5 Plus May 2020
        Anycubic Photon Mono X Nov 2020
        https://3dimensiongames.com/
          Phaedrux Moderator @RyanP
          @RyanP said in Mesh Bed Compensation not compensating?:
          You may need to do the G32 a few times over, and you should do a single G30 at the center of the bed afterwards to redefine the Z0. Then the G29.
          • Argoundefined
            Argo @Phaedrux
            @Phaedrux
            I don't think the BLTouch mount has tilt but the pin looks slightly bend to the right.
            I temporarily disabled G32 in my start gcode and calibrated my axis by running against the Z endstops.
            Afterwards I did G29 mesh leveling and the result was a severe tilted bed (right side was higher).
            I suspect now that is has something to do with the BLTouch. Next thing I'll do is to replace the PIN and also print another more stable mount.
            For completion:
            homeall.g
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v2 on Tue Aug 06 2019 23:15:45 GMT+0200 (Central European Summer Time)
            M915 X S-6 F0 H400 R0		                ; Set X axis Sensitivity
            M915 Y S-1 F0 H400 R0		                ; Set y axis Sensitivity
            G1 Z6 F6000 H2          ; lift Z relative to current position
            G1 H1 X-255 F2600 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H1 Y-215 F2600 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X5 Y5 F6000          ; go back a few mm
            G1 H1 X-255 F2600  ; move slowly to X and Y axis endstops once more (second pass)
            G1 H1 Y-215 F2600  ; move slowly to X and Y axis endstops once more (second pass)
            G90                     ; absolute positioning
            G1 X15 Y15 F6000        ; go to first bed probe point and home Z
            G30                     ; home Z by probing the bed
            M915 X S3 F0 H400 R1		                ; Set X axis Sensitivity
            M915 Y S3 F0 H400 R1		                ; Set y axis Sensitivity
            bed.g
            ; bed.g
            G28 W ; home
            G30 P0 X35 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
            G30 P1 X240 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
            • Argoundefined
              Argo
              I just replaced the X axis rods (one was slightly bend) and printed another BL Touch mount and replaced the pin.
              Just as before the nozzle is too far away on the right side of the bed which results in the line not sticking together.
              Height Map:
              Print result (middle and right tile):
                Is there some skew in the bed rail?
                Also may want to move the probe point to the center of the bed.
                Argoundefined 1 Reply Last reply Reply Quote 0
                • RyanPundefined
                  RyanP
                  @Argo
                  You and I are experiencing the same thing, with the same brand (and model) of printer. Have you printed anything else? Like a simple box. Something with a flat surface. I print a lot of simple boxes for board games. The tend to have a number of flat solid layers. Picture a box with a open top, and solid bottom.
                  My layers tend to have this double line, gap, double line, gap. Just like your right hand square. I am starting to think it is a mechanical problem with Creality printers. I have three of them and this patters happens on them all. It isnt on every part, or in every area. I think a lot of it is based on the BL Touch in conjunction with a backlash or mechanical shifting of things in the X-Axis or Y-Axis.
                  I am currently printing a fairly intricate player box for the board game Scythe. When it is done, I will post a picture of its flat surfaces.
                  Keep me in the loop as to your findings as I am working through various solutions myself.
                  CR10S, August 2018
                  Ender 5 Feb 2020
                  • Argoundefined
                    Argo @Phaedrux
                    @Phaedrux
                    Sorry for not mentioning that I‘m already using your advice to probe with 0.005 accuracy and after G32 I probe the center to determine Z=0.
                    New observation: after leveling the bed with a crazy 12x12 grid I can see that there is something wrong with the bad. It is very bumpy and when I print with the 12x12 mesh my Z axis can’t keep up and I have small hiccups during fast travel moves.
                    Next thing I do is to disassemble the Y axis, check the rods and the Y carriage for their flatness.
                    Hopefully I don’t have to order both.
                    Crazy that so many thing all at once tend to break 😞
                    • Argoundefined
                      Argo @RyanP
                      @RyanP
                      I’m having a MK3s Prusa printer.
                      The lines got better but only with crazy accurate 12x12 mesh bed compensation. I suspect there is something terrible wrong with my y axis rods, bed or carriage or worst case: all at once.
                      • Argoundefined
                        Argo
                        Update:
                        Y-Axis rods and the bed look fine.
                        I just leveld my x axis (tilt) by slowly driving the x-axis against the Z endstops.
                        New height map (7x7 mesh leveling, with center Z probe and 0.005 accuracy):
                        Print picture is the same. Left side is too close, right side too far away.
                          Increase your Z jerk. M566 Z24.00 is very low. Try at least 60. That should solve the stutters.
                          • shirnschallundefined
                            shirnschall
                            I recently had a similar issue and the problem was that the z screw was turning but the nozzle was not moving accordingly.
                            1. Check if your Z leadscrews are turning when moving the nozzle from left to right (using gcode. Not by hand)
                            2. if the screws are turning check if there is any slop in the system. If possible measure how much the nozzle moves up and down
                            If the z screws are not turning it I would suspect a problem with the probing itself
                            My printer: DIY 2020 extrusion CoreXY with E3D Tool-changing and Duet3 (https://github.com/shirnschall/HS-Bot-Project)
                            • Argoundefined
                              Argo
                              I did a complete frame rebuild today which improved things but it’s still not perfect level. There are parts on the bed which are good and parts which aren’t.
                              I’d say the inaccuracy between perfect layer and what the BLTouch measures at some spots is around 0.020mm to 0.025mm.
                              I suspect the BLTouch measuring error comes from the fact that it is mounted too far away from the nozzle. The Y offset is -12mm from nozzle and the mount I’m using atm has even higher offset from Y.
                              Thereby every small inconsistency in printed parts gets magnified by the position from the BLTouch, it’s like a lever.
                              My extruder has a slot for the Prusa PINDA Mount which merely has an offset of 2mm on the y axis.
                              I’ll try to configure it today and see if that helps.
                              I never did so because only RRF 3 supports the probe’s thermistor.
                              • Argoundefined
                                Argo
                                Do give you guys an update and also for someone who might have the same issue:
                                Installing the probe (in my case PINDA 2) with almost no Y offset solved my probing problem.
                                My guess ist that any small difference (parts, rods, frame) gets amplified by the probe when the location has a big Y offset to the nozzle.
                                I also do not recommend using "True Bed Leveling" with a cartesian printer. This could tilt the X axis which does also add an angle to the nozzle and probe. I level my X axis (tilt) by running into the Z endstops.
                                New working height map (almost perfect first layer)
                                Z = 0 reference point is X10 / Y10.
                                And if anyone is interested in how in configured my PINDA:
                                ; Z-Probe PINDA
                                M574 Z1 S2 ; Set endstops controlled by probe
                                M558 P5 C"^zprobe.in" I1 H0.9 F1000 T6000 A20 S0.005 ; PINDA
                                G31 P1000 X23 Y5 Z1.025 ; PEI Sheet Offset
                                ;G31 P1000 X23 Y5 Z1.325 ; Textured Sheet Offset
                                M557 X24:221 Y10:195 P12 ; Define mesh grid
                                The probing is quite fast but the accuracy is quite good as the probe rarely needs more than 2 probes per point.
                                Next I need to figure out how to use the temperature compensation with the G31 command.
                                • fcwiltundefined
                                  fcwilt @Argo
                                  @Argo
                                  If you run the probing multiple times are the results fairly consistent?
                                  • Argoundefined
                                    Argo @fcwilt
                                    @fcwilt
                                    Yes they are but not the overall Z offest because of the rising temperature of the probe.
                                    • fcwiltundefined
                                      fcwilt @Argo
                                      @fcwilt
                                      Motivated by your posts I began testing if mesh compensation was having the expected benefits and the results have been surprising.
                                      I've used both of my printers to print many functional parts (as opposed to decorative) but the largest of them are under 50 x 50 (mm).
                                      I created some simple test models to try printing using the entire 150 x 100 area.
                                      I probed the bed using a 20 x 20 grid.
                                      The height map wasn't that bad (max deviations -0.056/+0.086, mean 0.008, RMS 0.031) although there are things I can do to improve that.
                                      Yet even with mesh compensation enabled I did not get good bed adhesion in all areas. It was inadequate to complete the print.
                                      I expected better results.
                                      More testing to be done and adjustments to be made.
                                      • Thaliosundefined
                                        Thalios
                                        This is exactly what I has having a while back.
                                        My IR probe was having issues reading my printed glass bed and I switched to a regular glass. Now it is much better but because it is much flatter.
                                        My bed has a slight lower in the upper left corner and I print nothing there as it won't stick because it is too far from nozzle (0.2mm difference)
                                        i have this line in config-override.g that helped too:
                                        M376 H10 					; Set bed compensation Taper
                                        Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                                        Heavily modified Ender 3 Pro (Duet 3 6HC)
                                        Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                                        CR-10S Pro V2 (Duet 3 Mini 5+)
                                        and a bunch of SLA printers..
