Unsolved BL-Touch - multiple problems -
I homed z again. It's homing without triggering manual the BL.
Also when I go down with the z axis... doesn't care which amount and then homing z, the z motors are turning back always the same amount and it stops.
--> I hope that helps -
I'm not exactly sure what you mean.
Looking back over your config.g I notice two things on your M558 command that we can try changing.
M558 P9 C"^io7.in" H15 F120 1400
First, you're missing the T in front of the 1400 to define the travel speed between probe points.
Second, try removing the
from in front of io7.in. I think it's only zprobe.in that requires the pullup.I'd still like to see what the gcode console output is from sending M98 P"config.g" It should echo SOMETHING back.
M558 P9 C"io7.in" H15 F120 T1400 ----> doesn´t work
M98 P"config.g"
--> response to long, see consoleShould I buy a other sensor?
My motivation after a few days is down..... -
@barbarossa-cologne what does the console say? If you cannot read it, you can download it into a file:
https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_G_Code_Console -
M98 P"config.g"
Error: M569: Response timeout: CAN addr 1, req type 6018, RID=108
Error: M569: Response timeout: CAN addr 1, req type 6018, RID=109
Error: M569: Response timeout: CAN addr 1, req type 6018, RID=110
Error: M350: Response timeout: CAN addr 1, req type 6021, RID=111
Response timeout: CAN addr 1, req type 6021, RID=112
Response timeout: CAN addr 1, req type 6021, RID=113
Error: M906: Response timeout: CAN addr 1, req type 6017, RID=114
Response timeout: CAN addr 1, req type 6017, RID=115
Response timeout: CAN addr 1, req type 6017, RID=116
Error: M557: bad grid definition: Too many grid points; suggest increase spacing to 31.8mm
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 404C -
@barbarossa-cologne said in BL-Touch - multiple problems -:
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" H15 F120 1400 ; set Z probe type to bltouch and the dive height + speedsIf this is from your current config.g, you need to swap the lines round. M558 before M950
HTH
Paul
Mine from a DUET2 for comparison
M558 P9 C"^zprobe.in" H5 R1 F120 T6000 A5 S0.02 ;BLTouch connected to Z probe IN pin M950 S0 C"duex.pwm1" ;BLTouch Servo (S0) on duet pwm1 G31 X2 Y42 Z0.513 P25 ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
I checked it, from 15 to 650 are 21.16 points, so if it is rounded down to 21 it would reach the 441 limit of Duet 2 (limit of Duet 3 is not known to me). So reducing 650 a bit or S bigger than 30 would be the safe side.
The software is homing Z without triggering anything. That´s really confusing for me..
@PaulHew
Like this?
M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in; Z-Probe
M558 P9 C"^io7.in" H15 F120 T1400 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:650 Y15:650 S30 ; define mesh grid -
@barbarossa-cologne the CAN errors mean your Duet misses the expansion board.
You should set X and Y offsets for BLTouch in G31. This is described with an example in https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s231
G31 Z value means trigger height, 2.5 mm seens too low, please try a higher value. -
@JoergS5
Done.
In general I know About the settings. The main problem is that its not deploying or retracting. Also the software is crazily homing without triggerning the BL.
Selftest ist working -
@JoergS5
Trigger height - 4 --> not working.
Is it a big problem that I haven´t connect the expansion board? -
@barbarossa-cologne you can check the core position of BLTouch. This is the allen hex screw on top of the BLTouch. It is turnable by 180° to change deploy-retract distance.
https://www.antclabs.com/bltouch-v3
the picture " Correct position of Core (V3.x)" the black core's position can be changed by turning the screw with an inbus (Allen key).
@JoergS5
Is it a big problem that I haven´t connect the expansion board?I don't have this board, I don't know, it was only a comment about why the error message appeared.
@JoergS5
I tried to turn in almost 20 positions. Not working.... -
@barbarossa-cologne you posted the wiring as
Wiring:
BL ---------Duet
White - io7.in
Black - GND
Yellow - io7.out
Red - 5vbut the BLtouch has 5 cables, 2 for endstop and 3 for servo. You can check whether cabling is ok by controlling the match. In my experience the colors of the cables are sometimes wrong, so I would look the original positions on the 5-pin-connector *) on the BLTouch and compare them with yours, then check that they are connected correctly to the Duet 3 pins.
*) On my Smart 2.0, Smart 3.1 and Geetech clone: viewed from the back, pin down: from left to right brown-red-yellow-black-white. 3 servo + 2 endstop.
@JoergS5
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3I wired like this....
@barbarossa-cologne my experience is that the colors are sometimes wrong, better check the positions on the 5-pin-connector to be sure. I saw an image in the internet of the antclabs where black and white were exchanged. And the Creality ones cross a cable for the 3 pin connector.
