    BL-Touch - multiple problems -
    Firmware installation
    2.5k
    • PaulHewundefined
      PaulHew
      Mine from a DUET2 for comparison
      M558 P9 C"^zprobe.in" H5 R1 F120 T6000 A5 S0.02  ;BLTouch connected to Z probe IN pin
      M950 S0 C"duex.pwm1"				             ;BLTouch Servo (S0) on duet pwm1
      G31 X2 Y42 Z0.513 P25                            ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
      duttiundefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @dutti
        @barbarossa-cologne said in BL-Touch - multiple problems -:
        Error: M557: bad grid definition: Too many grid points; suggest increase spacing to 31.8mm
        I checked it, from 15 to 650 are 21.16 points, so if it is rounded down to 21 it would reach the 441 limit of Duet 2 (limit of Duet 3 is not known to me). So reducing 650 a bit or S bigger than 30 would be the safe side.
        • duttiundefined
          dutti
          @JoergS5
          I reduced the amount...
          @PaulHew
          I changed it. Same problem.....
          • duttiundefined
            dutti
            The software is homing Z without triggering anything. That´s really confusing for me..
            • duttiundefined
              dutti @PaulHew
              @PaulHew
              Like this?
              M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
              M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
              M558 P9 C"^io7.in" H15 F120 T1400 ; set Z probe type to bltouch and the dive height + speeds
              M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
              M557 X15:650 Y15:650 S30 ; define mesh grid
              • JoergS5undefined
                JoergS5 @dutti
                @barbarossa-cologne the CAN errors mean your Duet misses the expansion board.
                You should set X and Y offsets for BLTouch in G31. This is described with an example in https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s231
                G31 Z value means trigger height, 2.5 mm seens too low, please try a higher value.
                duttiundefined 2 Replies Last reply Reply Quote 0
                • duttiundefined
                  dutti @JoergS5
                  @JoergS5
                  Done.
                  In general I know About the settings. The main problem is that its not deploying or retracting. Also the software is crazily homing without triggerning the BL.
                  Selftest ist working
                  • duttiundefined
                    dutti @JoergS5
                    @JoergS5
                    Trigger height - 4 --> not working.
                    Is it a big problem that I haven´t connect the expansion board?
                    • JoergS5undefined
                      JoergS5 @dutti
                      @barbarossa-cologne you can check the core position of BLTouch. This is the allen hex screw on top of the BLTouch. It is turnable by 180° to change deploy-retract distance.
                      https://www.antclabs.com/bltouch-v3
                      the picture " Correct position of Core (V3.x)" the black core's position can be changed by turning the screw with an inbus (Allen key).
                      • JoergS5undefined
                        JoergS5 @dutti
                        @JoergS5
                        I don't have this board, I don't know, it was only a comment about why the error message appeared.
                        • duttiundefined
                          dutti @JoergS5
                          @JoergS5
                          I tried to turn in almost 20 positions. Not working.... 😕
                          • JoergS5undefined
                            JoergS5 @dutti
                            @barbarossa-cologne you posted the wiring as
                            Wiring:
                            BL ---------Duet
                            White - io7.in
                            Black - GND
                            Yellow - io7.out
                            Red - 5v
                            but the BLtouch has 5 cables, 2 for endstop and 3 for servo. You can check whether cabling is ok by controlling the match. In my experience the colors of the cables are sometimes wrong, so I would look the original positions on the 5-pin-connector *) on the BLTouch and compare them with yours, then check that they are connected correctly to the Duet 3 pins.
                            *) On my Smart 2.0, Smart 3.1 and Geetech clone: viewed from the back, pin down: from left to right brown-red-yellow-black-white. 3 servo + 2 endstop.
                            • duttiundefined
                              dutti @JoergS5
                              @JoergS5
                              https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3
                              I wired like this....
                              • JoergS5undefined
                                JoergS5 @dutti
                                @barbarossa-cologne my experience is that the colors are sometimes wrong, better check the positions on the 5-pin-connector to be sure. I saw an image in the internet of the antclabs where black and white were exchanged. And the Creality ones cross a cable for the 3 pin connector.
                                • duttiundefined
                                  dutti @JoergS5
                                  @JoergS5
                                  Without seeing the picture I thougth the same. I´ll try it on sunday.
                                  Thanks for your help!!
                                    At this point I think you should try swapping from io7 to io4 or io5 just to try a different connection. Update the config as needed to point to the new connection.
                                    And if that still doesn't work I would try connecting the BLTouch directly to the board with the short leads straight from the BTouch without the extension.
                                    If that still doesn't work I would get another BLtouch to test with.
                                    • duttiundefined
                                      dutti @Phaedrux
                                      @Phaedrux
                                      Ok. I'll do it on Sunday!
                                      I have a cheap Chinese BL fake at home. Should I take this BL at last try?
                                      Is there any other sensor you can recommend if it's not working?
                                      The duet one?
                                        The BLtouch is a good probe when it's working. It's surface agnostic and a contact probe and it's quite accurate and repeatable when configured correctly. It's the most popular option for a reason.
                                        The IR Probe is also very good, but your print surface must be compatible with the IR sensor.
                                        • duttiundefined
                                          dutti
                                          @Phaedrux
                                          ok. Then I´ll do everything to become the BL to work.
                                          • duttiundefined
                                            dutti
                                            @JoergS5
                                            Changing the cable order wasn´t helpful.
                                            There is also the problem that the duet homes the z axis. Also when the BL isn´t connected.
                                            @Phaedrux
