    Mosquito vs water cooling
    57
    3.9k
    • jens55undefined
      jens55
      I am doing testing this morning and the heatsink (chimera clone) is hovering around 40C with both extruders running. This is looking pretty good to me. I am currently running a test model that alternates between materials and I have not run into my previous issue.
      The issue before was that a single material was running for about 45 minutes before the second material came into play .... but thinking about it, it shouldn't (in theory) have caused issues because the standby temperature was pretty low.
      I also have a lot of material extruded during the time when one extruder goes to standby and the other extruder warms up (the 0.4 mm nozzle extrudes a string about 100 mm long !!!). I have yet to come up with a good way of getting that crap out of the way. In any which case, I do an extra prime with a nozzle switch to replenish this material and this was the point when the system had issues. This morning I reduced the feed speed from 15 mm/sec to 5 mm/sec during this extra prime phase and there is a good possibility that the speed caused the extruder to wear a divot into the filament and then subsequently not feed right.
      So far my test print is running fine and I am feeling optimistic about things.
      • mwolterundefined
        mwolter
        I've been using Mosquito's for about a year and have also been lucky enough to purchase a Mosquito Magnum Liquid and can offer some experience with heat creep with regard to the OP's question.
        First, yes the Mosquito does have less heat creep than a typical v6 heat break. So much less, that the small fan provided with the Mosquito combo is sufficient when not in a heated enclosure. My enclosure is only 65c and I was having severe consistency and clogging issues with the OEM fan. I've tried 40mm fans which are still not enough. I believe the Mosquito design relies heavily on the ambient temperature for cooling and the cooling fins are not large enough when a mosquito is used in an enclosure.
        That being said, they have changed the cooling fins (available on their site now) on the heat break. Not sure how the updated design works as I have the original version.
        My current project is to test the Mosquito Magnum Liquid. I think this will be perfect for use in my enclosure and should resolve the occasional inconsistencies and clogs. I've never designed a cooling loop so learning about galvanic corrosion, reservoirs, fittings, fluid types, flushing, and all that. Eventually, the cooling loop will be expanded or a second loop added to cool the steppers. Should be a fun project and hopefully help improve consistency.
        • jens55undefined
          jens55
          The Mosquito Magnum Liquid sounds like a wonderful addition! As I eventually want to go with a heated enclosure, I will look into this water cooled version.
            deckingman @theruttmeister
            @theruttmeister said in Mosquito vs water cooling:
            ...............You are already CNC'ing the parts......................
            No I'm not. My small milling machine and lathe are completely manual (but fitted with DROs). I have to produce 2D dimensioned drawings on paper for everything I make.
            theruttmeisterundefined 1 Reply Last reply Reply Quote 0
            • theruttmeisterundefined
              theruttmeister @deckingman
              @deckingman
              Ah.
              O-ring recesses in a hole is going to be a bit difficult then... maybe a press-fit plastic seal might be possible though.
              Isolate, substitute, verify.
              • arhiundefined
                arhi @theruttmeister
                @theruttmeister how about some (silicone) glue instead of o-rings to make it water tight?
                • tech-ratonundefined
                  tech-raton
                  In an enclosure, a watercooling is the best solution for me. A chimera might very large for a single extruder. I drilled some blocks of aluminium used with the e3d heatbreak.
                  No more heatcreap with a very small block 15936391776921731898753787276774.jpg
                  All the parts in the watercooling are in aluminium
                  The first block had a thermistor in it and the mesured temperature remains at 27deg in a 60deg enclosure.
                  These blocks were made with a drill.
                  • jens55undefined
                    jens55 @tech-raton
                    @tech-raton I am having a bit of a problem visualizing what you have done there. I see the heater and you say you use the E3D heat break so I am assuming that the heat break screws into your cooling block ? I am not sure what the red thing is in the square aluminum tube. How does the filament get guided to the heat break during a filament change ? What is the path of the coolant in that block - is it simply a blind hole at the entrance and exit with a cross drilled path connecting the two blind holes that is then plugged with the bolt shown in the middle of the block side ?
                    fmaundefined 1 Reply Last reply Reply Quote 0
                    • fmaundefined
                      fma
                      Here is what I planned to do for a friend:
                      The heatbreak is not the standard one, it is a full M6 thread, instead of the standard M6/M7 one.
                      Frédéric
                      jens55undefined tech-ratonundefined 2 Replies Last reply Reply Quote 0
                      • fmaundefined
                        fma @jens55
                        @jens55 said in Mosquito vs water cooling:
                        @tech-raton I am not sure what the red thing is in the square aluminum tube.
                        A remote extruder, I think.
                        @tech-raton, what is the hotend, on the delta? I like round the heat block... Is it a piezo, above the water cooling block?
                        Frédéric
                        • jens55undefined
                          jens55 @fma
                          @fma said in Mosquito vs water cooling:
                          Herre is what I planned to do for a friend:
                          OK so the water cooling block is a straight through drill and then a loop on the far side back into the cooler ? The ptfe tube goes straight to the heat break ? I assume the top thing is the ptfe coupling ?
                          Is the nut captive somehow in the assembly ? How ?
                          Sorry about all the questions ....
                            tech-raton
                            Yup the red thing is a remote extruder.
                            The watercooling on the corexy is just a 8mm aluminium part with 7 holes drilled
                            A m7 for the heatbreak
                            2 m5 for the pushfits
                            A m4 to connect the 2 m5 holes
                            3 m3 holes to attach on the carriage
                            On the delta, the hotend is a maxiwatt with a homemade silicon sock
                            And yes with a piezo as z probe
                            Why you heat
                            fmaundefined 2 Replies Last reply Reply Quote 0
                            • jens55undefined
                              jens55
                              Thanks for the clarification!
                                tech-raton @fma
                                @fma
                                Why have 4 pushfits?
                                You could make a u shape inside your watercooling.
                                It will reduce the flow but will increase the heat exchange.
                                • fmaundefined
                                  fma @jens55
                                  Exactly.
                                  Yes.
                                  No, this is the standard groove for hotends. It is designed for direct extruding. But you can modify this part (3D-printed) for Bowden, using a coupler thread.
                                  The 3D-printed part is made in 2 parts (split along the vertical axis), and glued together (there are 2 holes to help aligning it. Here is a closer view:
                                  You welcome! This design hasn't beed tested, and I would love to have feedback if you go that way.
                                  Frédéric
                                  • fmaundefined
                                    fma @tech-raton
                                    @tech-raton said in Mosquito vs water cooling:
                                    Easier to do.
                                    How? I only have a drill...
                                    It is the same, as I use a small external tube to make the half turn.
                                    Frédéric
                                    tech-ratonundefined 1 Reply Last reply Reply Quote 0
                                    • fmaundefined
                                      fma @tech-raton
                                      Thanks! I'll have a look at this block...
                                      Frédéric
                                      • jens55undefined
                                        jens55
                                        Ahh, clever! If the ptfe tube is captured by clamping pressure that seems to make clearing a clog kinda tough ???
                                        • fmaundefined
                                          fma @jens55
                                          As said, I didn't test it, and it may not work as expected. A longer heat break should be better, but I'm not sure if we can find one... But yes, the PTFE tube has to be clampled down, with the above part (extruder or bowden push fit).
                                          Frédéric
                                          • jens55undefined
                                            jens55
                                            Well I think that it shows great promise!
