    Mosquito vs water cooling
    57
    4.0k
    • arhiundefined
      arhi @theruttmeister
      @theruttmeister how about some (silicone) glue instead of o-rings to make it water tight?
      • tech-ratonundefined
        tech-raton
        In an enclosure, a watercooling is the best solution for me. A chimera might very large for a single extruder. I drilled some blocks of aluminium used with the e3d heatbreak.
        No more heatcreap with a very small block 15936391776921731898753787276774.jpg
        All the parts in the watercooling are in aluminium
        The first block had a thermistor in it and the mesured temperature remains at 27deg in a 60deg enclosure.
        These blocks were made with a drill.
        • jens55undefined
          jens55 @tech-raton
          @tech-raton I am having a bit of a problem visualizing what you have done there. I see the heater and you say you use the E3D heat break so I am assuming that the heat break screws into your cooling block ? I am not sure what the red thing is in the square aluminum tube. How does the filament get guided to the heat break during a filament change ? What is the path of the coolant in that block - is it simply a blind hole at the entrance and exit with a cross drilled path connecting the two blind holes that is then plugged with the bolt shown in the middle of the block side ?
          fmaundefined 1 Reply Last reply Reply Quote 0
          • fmaundefined
            fma
            Here is what I planned to do for a friend:
            The heatbreak is not the standard one, it is a full M6 thread, instead of the standard M6/M7 one.
            Frédéric
            jens55undefined tech-ratonundefined 2 Replies Last reply Reply Quote 0
            • fmaundefined
              fma @jens55
              @jens55 said in Mosquito vs water cooling:
              @tech-raton I am not sure what the red thing is in the square aluminum tube.
              A remote extruder, I think.
              @tech-raton, what is the hotend, on the delta? I like round the heat block... Is it a piezo, above the water cooling block?
              Frédéric
              • jens55undefined
                jens55 @fma
                @fma said in Mosquito vs water cooling:
                Herre is what I planned to do for a friend:
                OK so the water cooling block is a straight through drill and then a loop on the far side back into the cooler ? The ptfe tube goes straight to the heat break ? I assume the top thing is the ptfe coupling ?
                Is the nut captive somehow in the assembly ? How ?
                Sorry about all the questions ....
                  tech-raton
                  Yup the red thing is a remote extruder.
                  The watercooling on the corexy is just a 8mm aluminium part with 7 holes drilled
                  A m7 for the heatbreak
                  2 m5 for the pushfits
                  A m4 to connect the 2 m5 holes
                  3 m3 holes to attach on the carriage
                  On the delta, the hotend is a maxiwatt with a homemade silicon sock
                  And yes with a piezo as z probe
                  Why you heat
                  fmaundefined 2 Replies Last reply Reply Quote 0
                  • jens55undefined
                    jens55
                    Thanks for the clarification!
                      tech-raton @fma
                      @fma
                      Why have 4 pushfits?
                      You could make a u shape inside your watercooling.
                      It will reduce the flow but will increase the heat exchange.
                      • fmaundefined
                        fma @jens55
                        Exactly.
                        Yes.
                        No, this is the standard groove for hotends. It is designed for direct extruding. But you can modify this part (3D-printed) for Bowden, using a coupler thread.
                        The 3D-printed part is made in 2 parts (split along the vertical axis), and glued together (there are 2 holes to help aligning it. Here is a closer view:
                        You welcome! This design hasn't beed tested, and I would love to have feedback if you go that way.
                        Frédéric
                        • fmaundefined
                          fma @tech-raton
                          @tech-raton said in Mosquito vs water cooling:
                          Easier to do.
                          How? I only have a drill...
                          It is the same, as I use a small external tube to make the half turn.
                          Frédéric
                          tech-ratonundefined 1 Reply Last reply Reply Quote 0
                          • fmaundefined
                            fma @tech-raton
                            Thanks! I'll have a look at this block...
                            Frédéric
                            • jens55undefined
                              jens55
                              Ahh, clever! If the ptfe tube is captured by clamping pressure that seems to make clearing a clog kinda tough ???
                              • fmaundefined
                                fma @jens55
                                As said, I didn't test it, and it may not work as expected. A longer heat break should be better, but I'm not sure if we can find one... But yes, the PTFE tube has to be clampled down, with the above part (extruder or bowden push fit).
                                Frédéric
                                • jens55undefined
                                  jens55
                                  Well I think that it shows great promise!
                                  • fmaundefined
                                    fma
                                    The goal of this design was to be able to use it in a standard setup (groove), but if you can customize the extruder side, it might be improved...
                                    Another thing to check is if the 3D-printed part can handle the temperature. It should if the water flow is good, but better use PET-G or ABS.
                                    Frédéric
                                    • fmaundefined
                                      fma @tech-raton
                                      Do you have a CAD design of your setup, with Piezo? It is a nice and compact solution...
                                      Frédéric
                                        tech-raton @fma
                                        @fma
                                        With only a drill (and a screw), you could have a u shape.
                                          tech-raton @fma
                                          @fma yes i think i have it.
                                          What kind of files do you want?
                                          I work on catia
                                          • fmaundefined
                                            fma
                                            Ok, I see for the U. I will do that the next time!
                                            STEP is ok for the CAD files. Thanks!
                                            Frédéric
