    CR-10+Bondtech+Silicon Bed 450W+Microswiss...Help
    1.7k
    • Chrissundefined
      Chriss @Hélder Rocha
      @Hélder-Rocha
      Phaedrux describes stop.g here:
      https://forum.duet3d.com/topic/6760/stop-g/2
      I think that you do not have the "M0" in your endcode in your slicer. 😉 You can test your code fist by adding it the the endcode of your slicer for testing.
      Cheers, Chriss
      • Hélder Rochaundefined
        Hélder Rocha
        Tks Chriss.
        How you know, when we find ourselfs a bit lost, we have to solve one problem at the time. For now, i wold like to find what is making my printer so slow. On the web panel i find the speed between 8 and 12 mm/sec. I have Cura 4.6.1 and g.code is reprap flavor. Do you know how can i make the printing faster?
          Hélder Rocha
          This is my inicial g.code on the machine settings. However, in my cnfig is like this:
            Hélder Rocha
            M201 and M203 are complitly different!
            Chrissundefined 1 Reply Last reply Reply Quote 0
            • Chrissundefined
              @Hélder-Rocha
              I know how you feel.. I struggle with my CR10 a lot too. That blood thing behaves very strange but I have lost my motivation to debug that further. I will continue on mine after this weekend.
              M201 and M203 "must" be different. M203 set the maximum speed you printer can go. The acceleration (M201) is more the latency the head have when it accelerates. I would recommend to read the docu, it describes it better than I can.
              For your speed problem: Did you checked your speed setting in the cura profile?
              Mine look like that:
              Use them as reference only please! I work on them at the moment and my setup in guaranteed not very good. But I can tell you that this settings result in acceptable print speeds.
              Here is my current setup for the steppers:
              M350 E16 I1                                    ; Chriss - with interpolation
              M350 X16 Y16 Z16 I1                            ; Chriss - configure microstepping with interpolation
              M92 X80.00 Y80.16 Z400.00 E431.06              ; Chriss - set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00            ; Chriss - set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z800.00 E1200.00        ; Chriss - set maximum speeds (mm/min) Z180
              M201 X500.00 Y500.00 Z20.00 E250.00            ; Chriss - set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                        ; Set idle timeout
              Cheers, Chriss
              Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
                @Hélder-Rocha Remove the lines from the cura start gcode section. Your profile has inserted a bunch of speed settings that are overriding your config.g.
                  Hélder Rocha @Chriss
                  @Chriss my speed on cura looks like this:
                    Hélder Rocha @Phaedrux
                    @Phaedrux , those lines you are talking about are those from the g.code in the object i want to print, or can i erase the complet start g.code in the printer settings in cura?
                    • Chrissundefined
                      @Hélder-Rocha
                      Remove at least the M20X lines... They override .. Well as Phaedrux said....
                        Hélder Rocha
                        Well, in the next image i have 2 g.codes. one with the start gcode from cura and the other with out it.... will the second work?
                        • Chrissundefined
                          @Hélder-Rocha
                          Looks Good to me. As long as you keep the M20x in the config.g. There must me at least one place where you set some limits which should match your hardware and other settings.
                            @Chriss i beleave is there! Looks good?
                            Going now downstairs to the garage and try it
                            M569 P0 S0 ; Drive 0 goes backwards
                            M569 P1 S0 ; Drive 1 goes backwards
                            M92 X80.00 Y80.00 Z408.00 E820.00 ; Set steps per mm Z400
                            M566 X600.00 Y600.00 Z24.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
                            M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; Set maximum speeds (mm/min)
                            M201 X1000.00 Y1000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
                            M906 X750.00 Y1150.00 Z750.00 E1050.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                            M84 S300 ; Set idle timeout
                              Hélder Rocha
                              YESSSSSSSSSSSSSSSSSS... speed is normal now. Tks a lot guys... are you ready for the next problem i have? eh eh
                              Allright... my config for homeall with the bltouch. Is the original one, not replica. Is the smart bltouch 2020.
                              But first one question: i heve seen in some toturials that we should make a cut with a knife, because of the 3.3 v power or something like that!!! Is it needed to be done on this bltouch?
                              My config next:
                              ; homeall.g
                              ; called to home all axes
                              ; generated by RepRapFirmware Configuration Tool v2 on Wed Dec 26 2018 13:31:24 GMT+0000 (Hora padrão da Europa Ocidental)
                              G91 ; relative positioning
                              M98 Pdeployprobe.g ; deploy mechanical Z probe
                              G1 S1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                              G1 S1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
                              G90 ; absolute positioning
                              G1 X200 Y150 F6000 ; go to first bed probe point and home Z
                              ;G91 ; relative positioning
                              ;G1 S2 Z5 F100 ; lift Z relative to current position
                              ;G90 ; absolute positioning
                              M98 Pretractprobe.g ; retract mechanical Z probe
                              Ok... at the momment, i have the bltouch installed, but i am doing the home return with endstops swich. But first i tried this config and what apenned is that the printer does the x and y, but doesnt come down to make the measures!
                              Any sugestions?
                                No you don't have to cut any trace now.
                                Please post you config.g as text.
                                  @Phaedrux Good morning, sorry at the time i went to bed. My config is like this:
                                  M111 S0 ; Debugging off
                                  G21 ; Work in millimetres
                                  M555 P2 ; Set firmware compatibility to look like Marlin
                                  M550 P"Cr 10 - S" ; Set machine name
                                  M552 S1 ; Enable network
                                  ;*** Access point is configured manually via M587
                                  M586 P0 S1 ; Enable HTTP
                                  M586 P1 S0 ; Disable FTP
                                  M586 P2 S0 ; Disable Telnet
                                  M208 X300 Y300 Z400 S0 ; Set axis maxima
                                  M574 X1 Y1 S1 ; Set active high endstops
                                  M574 Z1 S2 ; Set endstops controlled by probe
                                  M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                                  M558 P9 H5 F120 T6000 A5 S0.02 ; Set Z probe type to bltouch and the dive height + speeds
                                  G31 P25 X-40 Y-10 Z1.20 ; Set Z probe trigger value, offset and trigger height
                                  M557 X50:250 Y50:250 S50 ; Define mesh grid
                                  M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                                  M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                                  M143 H1 S290 ; Set temperature limit for heater 1 to 290C
                                  M106 P0 S0 I0 F30 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P1 S0.5 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M563 P0 D0 H1 ; Define tool 0
                                  ; Automatic power saving
                                  M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                                  M912 P0 S-1 ; calibrate MCU Temp
                                  ; pressure advance
                                  M572 D0 S0.3 ; pressure advance
                                  M501 ; Load saved parameters from non-volatile memory
                                    Phaedrux Moderator @Hélder Rocha
                                    @Hélder-Rocha said in CR-10+Bondtech+Silicon Bed 450W+Microswiss...Help:
                                    Remove those parts from your homing file. You don't need to control the pin manually. It should deploy automatically with G30.
                                    Please test M401 and M402 to deploy and retract the probe, and post your retractprobe.g and deployprobe.g files.
                                    Also check your config-override.g file and look for an M307 H3 command that could be over writing your M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                                      @Phaedrux hello... tks a lot for your time and patience with my issues.
                                      ; deployprobe.g
                                      ; called to deploy a physical Z probe
                                      M280 P3 S10 I1
                                      ; retractprobe.g
                                      ; called to retract a physical Z probe
                                      ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
                                      M280 P3 S90 I1
                                      sorry but a think i dont have that config-hoverride.g
                                        That's fine.
                                        Did you test if M401 and M402 deploy and retract the probe pin?
                                        If that works, test the porbe as described here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                          @Phaedrux i havent test it yet... ill try tomorrow....
                                            Hélder Rocha
                                            Phaedrux, I finally got the time to dedicate myself a little to testing my duet. I've been taking advantage of my time off because of Covid to make some improvements at home, which has been taking up a lot of my time.
                                            I did what you told me, the M401 and 402, and it worked perfectly. Following the tests indicated in the link you sent me, when I insert the G30, in the dinamic test, nothing happens and I receive the following message: "Error - G30 Z probe already triggered at start of probing move" .
                                            When I turn on my duet, the bltouch performs its own tests, I don't know if that is what the error refers to.
                                            Tks a lot for the help
